RAM not overclocking to 2800MHz - Overclock.net - An Overclocking Community
post #1 of 21 (permalink) Old 01-20-2020, 09:37 AM - Thread Starter
basschilperoord's Avatar
Rep: 0
https://www.corsair.com/eu/en/Catego...6GX4M4A2800C16
So I got this set of RAM. It's 4x4GB and currently it is running at 2666MHz 1.2v, which is right now the farthest it can go.
My rig:
CPU - Intel Core i7 5820K (slightly overclocked to 4GHz)
MOBO - Gigabyte X99 UD4 (latest bios)
RAM - 16GB DDR4 Corsair Vengeance 2800MHz running at 2666MHz 1.2v
GPU - Gigabyte GeForce GTX 1080 Ti Gaming OC 11G (slightly overclocked using the OC mode)
PSU - Antec VP600P
Storage - Samsung 970 Pro 512GB / old OCZ Vertex 2 120GB / 3TB Toshiba HDD
A couple of fans
Sharkoon TG5 case
I wonder why it is not going over 2666MHz. Is it some kind of limitation? My motherboard supports speeds over 2666MHz, is what Gigabyte is saying on the website.
Maybe I have to tweak some kind of setting?
At 2800MHz the PC refuses to boot and gives me a couple of beeps, so not good.
basschilperoord is offline
post #2 of 21 (permalink) Old 01-20-2020, 10:04 AM
Overclocker in training
ThrashZone's Avatar
Rep: 131 (Unique: 85)
Hi,
x99 is general I don't think it likes hynix memory chips 16-18-18 tested latency frankly I've had issue using it too on 2666C15 4x4gb kit
Use this and hit Read post a screen shot
http://www.softnology.biz/files.html
I switched to trident-z 3200C14 4x8gb kit and it works perfectly so go figure.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 21 (permalink) Old 01-20-2020, 10:11 AM - Thread Starter
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
So here's the screenshot I took using Thaiphoon.
post #4 of 21 (permalink) Old 01-20-2020, 10:12 AM - Thread Starter
Rep: 0
Freakin' finally, jeezzz. I got my screenshot uploaded.
post #5 of 21 (permalink) Old 01-20-2020, 11:31 AM - Thread Starter
Rep: 0
Bump
post #6 of 21 (permalink) Old 01-20-2020, 11:34 AM
ThrashZone's Avatar
Hi,
Not much info besides the obvious :/
See what cpu-z has to say Memory and SPD sections
You can open two cpu-z windows to get both in the same screen shot.
http://www.cpuid.com/softwares/cpu-z.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #7 of 21 (permalink) Old 01-20-2020, 11:51 AM
Overclocker
icehotshot's Avatar
Rep: 147 (Unique: 125)
I would enable memory training or rather disable any settings that enable a "fast boot" where it skips the memory training in bios. I had to do this on my board to boot above 2666mhz.
5820k @ 4.4ghz 1.3v
MSI MPOWER X99S
$200 EVGA GTX 970 SSC @ 1505mhz
16GB G.SKIL @ 2666mhz 12-12-12-32-1T
960gb Sandisk Ultra II
SeaSonic X650 Gold
Corsair H100i v2
Obsidian Series® 750D Airflow Edition
Operating System
Windows 7 64-bit
Mouse
Zowie FK 2
icehotshot is offline
post #8 of 21 (permalink) Old 01-20-2020, 04:49 PM - Thread Starter
Rep: 0
Still not going above 2666MHz. It seems my mobo just doesn't like it and I'll have to stick with 2666MHz.
post #9 of 21 (permalink) Old 01-20-2020, 05:53 PM
ThrashZone's Avatar
Hi,
Did you increase dram voltage ?
2800 will need minimum 1.35v
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 21 (permalink) Old 01-21-2020, 07:09 AM - Thread Starter
Rep: 0
Hi,
Tried it, doesn't work. Thanks for all the help by the way.
Also, it is able to do 2800MHz with the XMP profile, but that would turn my BCLK to 127 and I don't like that. I only want to fiddle with the System Memory Multiplier and put that on 28, but it won't run that way.
