2x8gb RAM flareX bdie running at 3000mhz TRAS 28 vs TRAS 34 and it seems TRAS 34 win? - Page 7 - Overclock.net - An Overclocking Community
post #61 of 169 (permalink) Old 03-25-2020, 08:10 AM
Rep: 12 (Unique: 7)
Quote: Originally Posted by DAM20 View Post
Yo try this https://www.overclock.net/forum/1805...ash-b-die.html
Your rams are far better then this LPX kit, also there's a lot of tips in the comments
Anyway, to get always 100 bclk you have to disable spread spectrum, unfortunately is possible only on some x570 board :/
I guess it's on all X boards because I do use that setting and I've seen it on X370 & X570 at work.
AMD Bliss
(15 items)
Ryzen 7 3700X - 1900MHz FCLK
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-13-27-40 1T 1.5V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4 Push-Pull
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is online now
post #62 of 169 (permalink) Old 03-25-2020, 01:28 PM
hazium233's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by Bapt33 View Post
My bios is already to the latest version... and yes all timings on auto, mobo seems suck
There is a large thread on the X370-Pro here. The short of it is that it is difficult to stabilize 3200MT/s with one-dimm-per-channel on it with a Zen1 or Zen+.
Can start with one such blurb about this here.
There is at least one report in there where someone with Zen+ had more frequency with 4x8GB than 2x8GB.
COL1
(3 items)
Ryzen 7 2700X
Asus Strix X370-F (4012)
Ballistix Sport AT 2666 (D9TZV)
hazium233 is offline
post #63 of 169 (permalink) Old 03-25-2020, 03:38 PM - Thread Starter
Rep: 1 (Unique: 1)
Thanks for this i will take a look. SAdly i still get error with auto timings at 3200 which are over loosen ... so dram calculator timings not stable, and even on auto with TRFC 560 ...
this mobo is a nightmare for RAM ... look those timings, how it cant be stable ?? ...
Bapt33 is offline
post #64 of 169 (permalink) Old 03-25-2020, 08:38 PM
hazium233's Avatar
Rep: 3 (Unique: 3)
The timings are unlikely the problem (although too tight secondaries could be late / intermittent). It is very likely the signaling, with some influence from SOC voltage settings and core overclock.
It may be worth reverting the core settings to find the true ram ceiling.
Other than that, the first things I might mention would be similar to what Veii already said. The "normal" RTT for single rank, Samsung B-die would be 7-off-5 (34-off-48 in ohms), although Asus likes to default to off-off-5. CAD drive strength settings to 24-24-24-24 to start.
Besides turning down SOC voltage a little, I would roll back most, or all of the LLC. Too much voltage can increase error rate.
You can ballpark the required voltages using AIDA stress test with cache and memory checked (+/- FPU depending on cooling). Should run it at 30min to an hour at the beginning of the process. This is more or less one of the first steps in cm87's guide on computerbase.de.
Otherwise, here is a 3200MT/s result for a Zen+ on the X370-Pro using FlareX B-die, although it is under Pinnacle AGESA v 4011. In this case, working RTT was 5-off-5. Forum post was at hardwareluxx.de here, via google translate. Maybe that will work for you, but that can be board, bios version, combination specific.
COL1
(3 items)
Ryzen 7 2700X
post #65 of 169 (permalink) Old 03-26-2020, 01:32 AM - Thread Starter
Rep: 1 (Unique: 1)
Ok thanks for this, already tried raise vcore but no help (im sure my cpu is stable, passed intelburntest 10 pass many times, p95 small fft, large fft, never crash)
About the RTT value, that's interesting, ive tried RTT NOM 34/off RTT PARK 48 and RTT WR OFF, gonna try different combination of RTT and let's see. thanks
Im actually maximum LLC for SOC, it dont overvolt, it just flat, 1.1v idle like full load, no any drop, but i could down it 1.1v is a bit high i agree (auto voltage)
This is my new timings, i dont really think its gonan be stable, but let's try
-R5 2600 4ghz 1.312v - 1080ti Gigabyte Aorus - FlareX 3200CL14 B-die 66ns - Asus Prime X370 Pro -
Cpu cooling : Coolermaster AIO Nepton 280L + corsair fan
gpu cooling : Corsair AIO H80i V2
Bapt33 is offline
post #66 of 169 (permalink) Old 03-26-2020, 03:31 AM
rdr09's Avatar
Rep: 878 (Unique: 637)
Op, have you tried swithing your rams placements? Put one in A2 to B2 and the one in B2 to A2.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #67 of 169 (permalink) Old 03-26-2020, 03:55 AM
OG AMD
Redwoodz's Avatar
Rep: 599 (Unique: 465)
Might be worth trying the other 2 slots as well.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #68 of 169 (permalink) Old 03-26-2020, 04:54 AM - Thread Starter
Rep: 1 (Unique: 1)
Still error, with these timings .... Gonna try up vcore now, dont know what can i do more, maybe try RTT NOM 34 or disabled
Bapt33 is offline
post #69 of 169 (permalink) Old 03-26-2020, 05:16 AM
OG AMD
Redwoodz's Avatar
Too much vcore will give you the same thing. Same as too much SOCv. Same with too much DRAMv. A single error can be voltage slightly off. Have you tried lowering SOCv to 1.88v?
Single error also try tRFC adjustment.
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
TeamGroup Excalibur
AMD FX Vishera 8350
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
Optical Drive
Samsung BD
Zalman 9900MAX
Fractal Design R3
Operating System
AOC 22" LED
Keyboard
Logitech
Other
Redwoodz is offline
post #70 of 169 (permalink) Old 03-26-2020, 05:23 AM - Thread Starter
Rep: 1 (Unique: 1)
Im right now to 1.05v soc, i was 1.1v before. Ive got single error even with TRC 73 and TRFC 560 (auto timings, see picture post above) dram voltage 1.35v.
Buiut it seems more i raise vcore, more error pop late, i was to 1.312v and now to 1.325v
These are my auto timings and not even stable with that, 1.1v soc, dram 1.35v
Bapt33 is offline
