2x8gb RAM flareX bdie running at 3000mhz TRAS 28 vs TRAS 34 and it seems TRAS 34 win? - Page 8 - Overclock.net - An Overclocking Community
post #71 of 169 (permalink) Old 03-26-2020, 05:29 AM
OG AMD
Redwoodz's Avatar
Rep: 599 (Unique: 465)
Quote: Originally Posted by Bapt33 View Post
Still error, with these timings .... Gonna try up vcore now, dont know what can i do more, maybe try RTT NOM 34 or disabled
Too much vcore will give you the same thing. Same as too much SOCv. Same with too much DRAMv. A single error can be voltage slightly off. Have you tried lowering SOCv to 1.88v?
Single error also try tRFC adjustment.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #72 of 169 (permalink) Old 03-26-2020, 06:19 AM
Rep: 12 (Unique: 7)
Im right now to 1.05v soc, i was 1.1v before. Ive got single error even with TRC 73 and TRFC 560 (auto timings, see picture post above) dram voltage 1.35v.
Buiut it seems more i raise vcore, more error pop late, i was to 1.312v and now to 1.325v
These are my auto timings and not even stable with that, 1.1v soc, dram 1.35v
ProcODT 60 ohm is too much. Try 28 or 34 ohm.
AMD Bliss
(15 items)
Ryzen 7 3700X - 1900MHz FCLK
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-13-27-40 1T 1.5V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4 Push-Pull
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is online now
post #73 of 169 (permalink) Old 03-26-2020, 07:21 AM - Thread Starter
Rep: 1 (Unique: 1)
are you sure? for b-die 28 or 34? im actually to 53.3, i could try .
-R5 2600 4ghz 1.312v - 1080ti Gigabyte Aorus - FlareX 3200CL14 B-die 66ns - Asus Prime X370 Pro -
Cpu cooling : Coolermaster AIO Nepton 280L + corsair fan
gpu cooling : Corsair AIO H80i V2
Bapt33 is offline
post #74 of 169 (permalink) Old 03-26-2020, 02:39 PM
hazium233's Avatar
Rep: 3 (Unique: 3)
It will probably not boot that low on Zen+, that is more like Zen2 settings. With some Micron dies on some boards, maybe you can get down to ~36.9. 48-53 is about right on ProcODT for Zen+ most of the time.
Might need to attempt a few more RTT combos. May be a bit time consuming, but try to look at error rate and see if a pattern appears.
Since you already did 7-off-5, and 5-off-5, check 6-off-5.
If no luck then you can move to RTT Park and move it up or down a step. Then test with RTT Nom at different settings.
I might check RTT Park RZQ/4 (60) next, but the next one doesn't matter as much as being systematic.
edit: if you are just on 1.35V on the dimm, you might need to try 1.36 or so.
COL1
(3 items)
Ryzen 7 2700X
Asus Strix X370-F (4012)
Ballistix Sport AT 2666 (D9TZV)
hazium233 is offline
post #75 of 169 (permalink) Old 03-26-2020, 02:58 PM - Thread Starter
Rep: 1 (Unique: 1)
Thanks for this, im trying right nom RTT 7-off-5 with procodt 48 ohm, could try 6-off-5 after, and play with RTT park if still
EDIT : Error fast with procodt 48ohm, back to 53.3, RTT 7-off-4
Bapt33 is offline
post #76 of 169 (permalink) Old 03-27-2020, 02:12 AM - Thread Starter
Rep: 1 (Unique: 1)
Just passed 8 hour bench with RTT 7-off-6, interesting !
Bapt33 is offline
post #77 of 169 (permalink) Old 03-27-2020, 03:12 AM
rdr09's Avatar
Rep: 878 (Unique: 637)
Your procodt still at 53? Can you share the rest of your settings if you have time?
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #78 of 169 (permalink) Old 03-27-2020, 04:07 AM - Thread Starter
Rep: 1 (Unique: 1)
yes procodt still 53.3 and this my settings right now still stable
Bapt33 is offline
post #79 of 169 (permalink) Old 03-27-2020, 04:25 AM
rdr09's Avatar
Nice! Pretty tight too. Real test is use of a moth or so without issue. Looks like its enough to par your 3000 setting and get the speed you paid for. I say congrats and rep all around.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #80 of 169 (permalink) Old 03-27-2020, 04:46 AM - Thread Starter
Rep: 1 (Unique: 1)
Not sure to understand what you mean ^^'. If you mean run test an overnight, thats what ive done last night and no error
These timings are v1 profile safe preset from dram calculator, i wasnt stable with auto timings.
I need at least 3 days to call it stable, but yesterday with other RTT combo error was faster so rtt 7-off-6 seems a good way
Bapt33 is offline
