Overclocked Memory Advice - Overclock.net - An Overclocking Community
post #1 of 274 (permalink) Old 04-01-2020, 03:46 PM - Thread Starter
Rep: 0
Hi Guys,
New to this site nice to meet everyone. Have few queries regarding my overclock memory 4x8GB 3200MHZ which is overclocked to 3600MHZ.
Just wanting to know if i could get anymore out of it, 3600 is the best i can get it clocked for stability just wanting to know about timings and also maybe check my voltages are safe.
New to PC Gaming/building since July. I Know it ain't the best quality and dearest brands but all i do is game so should be okay.
Be great to hear back .
Thanks
Kevin
Below is a few screenshots of information.
KevyMatts is offline
post #2 of 274 (permalink) Old 04-02-2020, 04:08 AM - Thread Starter
Rep: 0
Also my DRAM voltage is set to 1.4 in bios. Anything after 1.45 it highlights red in bios
post #3 of 274 (permalink) Old 04-02-2020, 04:43 AM
Stock is too casual~
Veii's Avatar
Rep: 78 (Unique: 46)
Red means it can be in the high range but not overvolting range, 1.46-1.48 would be your recommended max for 18nm
1.46 you can push
fix your CLDO_VDDP to be 900mV
vSOC 1.05
try tRFC 448-333-205, if it posts put tRTP 7, tWR 14
SiSandra Inter-Core Bandwith 14nm Ryzen global #1 | Twitter
Personal Records
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #4 of 274 (permalink) Old 04-02-2020, 06:33 AM - Thread Starter
Rep: 0
1.46 you can push
vSOC 1.05
Thanks for the reply, somebody suggested maybe trying clocking to 3800 or would you reckon to stick to 3600?
post #5 of 274 (permalink) Old 04-02-2020, 07:34 AM
Veii's Avatar
Step by step - you have Hynix CFR kits
Don't make jumps when you don't know 2 things
- Voltage the kits like and dislike
- potent of your cpu even hitting 1900FCLK
Get your setup stable and test it stable, know the flaws of your kits
Know what your cpu likes later pushing FCLK under decoupled mode
And only then consider thinking about pushing memory
Likely memory would be the first part that gives up, before the CPU
Personal Records
Veii is offline
post #6 of 274 (permalink) Old 04-02-2020, 07:50 AM - Thread Starter
Rep: 0
Your right, think ill stick with 3600. Have tested stability with the settings up above with no issues over 18 hours all I do is game so 3600 should be enough.
Also on tRFC I can only change one value as rest also change.
Would you be happy with these timings etc
post #7 of 274 (permalink) Old 04-02-2020, 08:26 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
Would also help if you listed your exact memory.
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #8 of 274 (permalink) Old 04-02-2020, 08:39 AM - Thread Starter
Rep: 0
Thought the tiaphoon info would covered that in first post.
It's 2x TEAM GROUP VULCAN T-FORCE 16GB (2X8GB) DDR4 PC4-25600C16 3200MHZ DUAL CHANNEL
Have 4x8Gb which is 32GB in total.
post #9 of 274 (permalink) Old 04-02-2020, 09:20 AM
Back at it again.
Avacado's Avatar
Sorry, I didn't see any listed specs in your first post. Tracing your memory back to the manufacturer site doesn't really help. There are maximum voltages listed for the 2666/3000, but no the 3200. https://www.teamgroupinc.com/en/product/vulcan-z-ddr4
I would assume that it would be safe to use 1.5v. I use 1.5v on my G.Skills at XMP II settings and I have never had an issue, so yes, I would be happy with your results.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #10 of 274 (permalink) Old 04-02-2020, 10:50 AM - Thread Starter
Rep: 0
1.46 you can push
vSOC 1.05
I've set my SoC to 1.05 and also fixed my Vddp to 0.900. Will I keep my DRAM v at 1.4 and slowly Increase if I need to?
Also didn't post with tRFC at 448
Tags
hynix cjr , memory oc
