F4-3466C16Q-32GTZR B-Die ? Where to start for OC - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 05-30-2020, 04:56 AM - Thread Starter
Elric2a's Avatar
Rep: 0
Hi,
i can't find any info wether my Ram is B-die or not?
https://benzhaomin.github.io/bdiefinder/
https://www.hardwareluxx.de/communit...05-20.1161530/
Can someone help me?
Also i would like to set it up manually in bios and not use XMP and overclock but i am not sure where to start, does someone have those sticks and can help me?
Thanks
Elric2a is offline
post #2 of 13 (permalink) Old 06-01-2020, 04:59 AM - Thread Starter
Elric2a's Avatar
Rep: 0
Hi,
What is the safe temperature for DDr4 ? I have some Trident Z RGB,I've OC them a bit and I was wondering about temps on this kit. Went up to 48c during gaming
Also those are the results of the OC, managed to get it to 4000 but latency wasn't getting a lot more lower so I left it at 3733. Maybe the fact that I have 4 sticks is not helping?
Thanks
Name:	3733 timings.png
Elric2a is offline
post #3 of 13 (permalink) Old 06-01-2020, 06:09 AM
Hiikeri's Avatar
Rep: 8 (Unique: 7)
Thaipoon burner shows your memory specs: Read and choose 1 ram stick.
https://www.softpedia.com/get/Tweak/...n-Burner.shtml
If your RAM is Samsung B-Die chips, on that red area reads WB.
All B-die rams doest show it like my sticks also on that Die Density area. Those "WB" letters on 1st section part number is 100% truth.
Z390 Godlike | 9900K @5400 | 16Gb @4600 cl17 | 2080Ti @2000+ /16Gbps | 3xNVME + 512Gb 850Pro | Finland
Hiikeri is offline
post #4 of 13 (permalink) Old 06-01-2020, 06:09 AM
Arni90's Avatar
Rep: 87 (Unique: 80)
If tRFC 299 is stable (use testmem5 w/anta777 config), then it's definitely B-die.
Here's a link to some memory testing software, as well as a generally good tuning guide for memory: https://github.com/integralfx/MemTes...sting-software
4 DIMMs is optimal on the Z390 Aorus Master because it has a T-topology memory layout. Do note that the Z390 Aorus Master has a training issue above 3900 MHz memory speed, leading to worse performance in several cases unless you reach a really high memory speed like 4266 MHz or higher. My recommendation is to aim for 3866 MHz, and after that you start tightening down timings.
Main rig
(16 items)
9900k
Z390 AORUS MASTER
RTX 2080 Ti
4x 8GB B-die @4000 MHz 16-16-16-37-2T
960 EVO
860 EVO
ADATA SX8200 PRO 1TB
Optical Drive
No
Fractal Design ION+ 860W
MCP655
Alphacool RTX 2080 Ti full cover block
EKWB Supremacy EVO
3x 180mm radiator
SST-FT02
Operating System
Windows 10
EX3501R
Arni90 is offline
post #5 of 13 (permalink) Old 06-01-2020, 06:16 AM
Invalid Media
J7SC's Avatar
Rep: 79 (Unique: 31)
...According to the Hardwareluxx.de (and also given the stock primary timings), F4-3466C16Q-32GTZR is not Samsung-B die. Still, try to set '14-14-14-32' / 3400 MHz at 1.4v or below for the primary settings and see how that works via RAM stress testing.
I realize that you're not running Ryzen but Intel, yet I have used <> this tool as a 'dial-in' guide even for Intel based machines.
4 sticks are usually harder to 'oc' than 2 sticks, but it also depends on your CPU's memory controller bin. For example, I can run 4 Trident 3866 sticks at 4000+ on a 6700K w/o issues. Temp wise, I like to keep the DRAM sticks in the 30C range (ie with auxiliary fans if necessary, depending on case airflow), but definitely keep them below 50C
J7SC is offline
post #6 of 13 (permalink) Old 06-01-2020, 06:18 AM - Thread Starter
Elric2a's Avatar
Rep: 0
Thanks ! So the OC and the temps are ok?
Elric2a is offline
post #7 of 13 (permalink) Old 06-01-2020, 06:24 AM
Invalid Media
J7SC's Avatar
...re OC, you need to do stress testing (memtest and various other). Re. temps, they're a bit on the warm side at 48C but not in outright danger territory. Still, I would add an extra fan blowing air on the DRAM modules (which also helps with VRM etc)
J7SC is offline
post #8 of 13 (permalink) Old 06-01-2020, 06:25 AM - Thread Starter
Elric2a's Avatar
Rep: 0
I've done a memtest but not very long. for the extra fan it's not really possible
Elric2a is offline
post #9 of 13 (permalink) Old 06-01-2020, 07:56 AM - Thread Starter
Elric2a's Avatar
Rep: 0
Well i got a BSOD in game. I went back to XMP profile 3466 and noticed the temps are quite similar than at 3733.
Could it be the timings or maybe the cpu vcore which needed to be upped with the ram oc?
In red dead redemption 2, rams hitted 52c.
Elric2a is offline
post #10 of 13 (permalink) Old 06-01-2020, 10:13 AM
Arni90's Avatar
You need to stresstest your memory, use either Karhu, HCI, or testmem5 w/ anta777 config. Just setting random timings and clock speeds will never get you anywhere, be systematic and loosen out primary timings to find a maximum clock speed before trying to tighten timings.
3466 16-18-18 isn't a particularly good bin, but you should at the very least be able to tune the subtimings. It's probably Samsung B-die as tRFC ~300 @ 3733 MHz on Hynix CJR shouldn't be anywhere close to stable, but that doesn't instantly mean you are able to run tCL, tRCD/tRP, tRAS, and tRC at similar speeds as good bins of Samsung B-die.
You should lower your CPU and Cache/Ring OC while trying to find stable memory timings, the reason being that the increase in performance from memory timings might very well push your CPU over "the edge" stability-wise. Just go 200 MHz down temporarily, then try to raise it after completing the memory OC.
Main rig
(16 items)
9900k
Z390 AORUS MASTER
RTX 2080 Ti
960 EVO
860 EVO
Optical Drive
No
MCP655
EKWB Supremacy EVO
3x 180mm radiator
SST-FT02
Operating System
Windows 10
EX3501R
Arni90 is offline
