GPUGrid - Overclock.net - An Overclocking Community
GPUGrid
post #1 of 14 (permalink) Old 03-14-2014, 07:28 PM - Thread Starter
⤷ αC
AlphaC's Avatar
Rep: 908 (Unique: 590)
http://www.gpugrid.net/forum_thread.php?id=3647
GPU was not using the Max Boost Mhz
You can run: nvidiaInspector.exe /?
... to see the list of command-line arguments.
To fix my particular problem:
1) I ran: nvidiaInspector.exe -forcepstate:2,2
Note: The first '2' is the GPU index, and in nVidia Inspector's dropdown, my Kepler is last in the list, with a (2), which is why I used 2 here.
2) In nVidia Inspector, on the P2 GPU Clock, I unlocked the Max, and set it to my Max Boost (1241 Mhz). I actually had to set it to 1242 here for it to work correctly.
crosslinked to https://www.overclock.net/t/1267918/guide-nvidia-inspector-gtx670-680-disable-boost-fixed-clock-speed-undervolting
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #2 of 14 (permalink) Old 05-28-2014, 08:41 AM
Finrond's Avatar
Rep: 55 (Unique: 42)
Ok, this won't apply to most of you but here is some sage advice. When running a project that uses SOME CPU cycles (GPU Grid), but not a fully loaded core alongside a non-overclocked CPU it is best to set your power settings to disallow SpeedStep. Otherwise, the WU wont push hard enough on the CPU to cause it to run at a high frequency and your GPU usage will suffer. Case in point, my 670 had steady-ish but still bouncy GPU usage running GPUGrid, and then I realized the CPU was running at low clockspeeds. Changed the power settings in windows, and now its running much better. I took a screen shot to show the difference:
You can see where in the graph the power settings were applied.
EDIT: This increased my PPD from ~350k -> ~400k.
Finrond is offline
post #3 of 14 (permalink) Old 04-03-2017, 09:51 AM
Finrond's Avatar
Looks like GPUGrid has some new long runs that are... quite long:
This is on a GTX 670
Finrond is offline
post #4 of 14 (permalink) Old 04-03-2017, 10:43 AM
Not new to Overclock.net
k4m1k4z3's Avatar
Rep: 243 (Unique: 187)
I have had some of the long ones take up to 12 hours on my 1080, but that is with me running 2 at a time.
k4m1k4z3 is offline
post #5 of 14 (permalink) Old 04-03-2017, 11:17 AM
mmonnin's Avatar
Rep: 283 (Unique: 135)
Hopefully the bonus is longer than 24 hours too.
mmonnin is offline
post #6 of 14 (permalink) Old 04-03-2017, 02:34 PM
Finrond's Avatar
Ended up taking a little over 31 hours for 449,250 points.
Finrond is offline
post #7 of 14 (permalink) Old 02-14-2018, 07:25 PM
2+2=5
tictoc's Avatar
There is no general thread for GPUGrid, so I am going to make this our GPUGrid thread.
@Finrond Is there some sort of secret handshake that has to be done in order to get tasks now? I was getting pretty consistent work in January, but I haven't been able to get a single task over the last 2+ weeks.
tictoc is offline
post #8 of 14 (permalink) Old 02-14-2018, 08:26 PM
mmonnin's Avatar
The licence for the Linux app expired so if you got any they just aborted instantly. Then some rare short tasks came out. Guess what, they aborted too. The only work available has been for GPUs on Windows and CPUs on Linux.
Just today they released the new version that should run on Linux. I haven't had received any though. There was mention of a new app with increased performance.
Edit: And as soon as I said that I received one on my 1070 in Linux.
mmonnin is offline
post #9 of 14 (permalink) Old 02-14-2018, 09:02 PM
2+2=5
tictoc's Avatar
So the secret handshake is... "Run it in Windows dummy"
I actually read that when I noticed I wasn't getting tasks. Between then and now I completely forgot that was the reason why I wasn't getting any tasks.
*Edit* Thanks for the reminder @mmonnin . I just loaded up some Collatz, but I'll be back to GPUGrid if the Linux app is running again.
tictoc is offline
post #10 of 14 (permalink) Old 02-14-2018, 09:27 PM - Thread Starter
⤷ αC
AlphaC's Avatar
@ Tictoc let me know if you want ownership of this thread or if you want me to add anything to OP
AlphaC is offline
