EK introduces EK-CryoFuel coolants - Overclock.net - An Overclocking Community
post #1 of 62 (permalink) Old 03-29-2017, 08:26 AM - Thread Starter
Hardware Rep
akira749's Avatar
Rep: 279 (Unique: 184)
EK Water Blocks, the market leader in high-end liquid cooling for PC products, is proud to introduce the EK-CryoFuel, the most chemically stable coolant that provides enthusiasts and gamers with the best possible level of performance, color stability, and thermal efficiency.
Introducing EK-CryoFuel
The EK-CryoFuel is a new revolutionary coolant for PC liquid cooling systems. Our mission was to deliver the most chemically stable coolant that would provide enthusiasts and gamers with the best possible level of performance and thermal efficiency with the emphasis on color stability. Designed specifically for computer liquid cooling systems, we found our inspiration for CryoFuel in cryogenic fuels that are used at extremely low temperatures to operate in space machinery.
EK-CryoFuel coolant is a pure, non-toxic coolant based on the patent pending chemical formula, which prevents the creation of any sediments in the liquid cooling loop. Liquid cooling users can rest assured that the EK-CryoFuel coolant, with its very low viscosity, will not clog or damage their water blocks and other parts of the loop when used with EK-DuraClear or EK-ZMT tubing.
EK-CryoFuel also contains synergistic corrosion inhibitors to protect metals commonly found in computer liquid cooling systems. It has been tested in accordance with BS5117 (ASTM D1384) and found to meet corrosion standards for copper, brass, aluminum and stainless steel. This coolant also contains scale and biological inhibitors to help prevent fouling – thus promoting long operational life and high thermal efficiency.
All EK-CryoFuel mixtures are biodegradable (90% in a period of 10 days) and will not remain in the environment or cause any bioaccumulation. EK-CryoFuel offers a 2-year shelf life from date of bottling.
EK-CryoFuel premixes
EK-CryoFuel is available as a premix and can be poured directly into any custom loop without any additional chemicals or kill coils. It comes as a Clear (transparent), Blood Red, Navy Blue, Lime Yellow and Acid Green color in a 900mL bottle.
The amount of a single premix is more than enough to run a typical custom loop with multiple water blocks and radiators. To calculate the exact amount of coolant needed for a custom loop, users can always check with Custom Loop Configurator.
Custom Loop Configurator features Coolant capacity calculation on the far left.
It shows the amount of coolant needed for a specific custom loop.
EK-CryoFuel concentrates
EK-CryoFuel is also available as a concentrate, available in a 100mL bottle and has to be mixed with distilled water in ratio 1:9 to form 1L of ready-to-use coolant. Like the premixes EK-CryoFuel concentrates are available in Clear (transparent), Blood Red, Navy Blue, Lime Yellow and Acid Green color.
To make the process of mixing the concentrates with distilled water easier, we are also introducing the filling bottle that comes with a special tube for reservoir opening. This makes loop filling process much easier!
Filling bottle to make filling your loop easier – sold separately!
EK-CryoFuel coolants are made in Slovenia, Europe and are already available for purchase through EK Webshop and Partner Reseller Network. In the table below you can find MSR prices with VAT included.
  • EK-CryoFuel Clear (Premix 900mL) 8.95€
  • EK-CryoFuel Clear (Concentrate 100mL) 6.95€
  • EK-CryoFuel Blood Red (Premix 900mL) 8.95€
  • EK-CryoFuel Blood Red (Concentrate 100mL) 6.95€
  • EK-CryoFuel Navy Blue (Premix 900mL) 8.95€
  • EK-CryoFuel Navy Blue (Concentrate 100mL) 6.95€
  • EK-CryoFuel Lime Yellow (Premix 900mL) 8.95€
  • EK-CryoFuel Lime Yellow (Concentrate 100mL) 6.95€
  • EK-CryoFuel Acid Green (Premix 900mL) 8.95€
  • EK-CryoFuel Acid Green (Concentrate 100mL) 6.95€
  • Filling Bottle (1000 mL) 6.99€
akira749 is offline
post #2 of 62 (permalink) Old 03-29-2017, 08:56 AM
Rep: 10 (Unique: 8)
Looks awesome! I just saw this in my email and wondered if anyone posted about it yet. I'd love to see some shots of the fluid itself in a res or tube but I imagine the color on the label gives you a fairly good idea of what to expect from the product.
deehoC is offline
post #3 of 62 (permalink) Old 03-29-2017, 09:05 AM
Eh, Wha?
Zero4549's Avatar
Rep: 719 (Unique: 531)
Anything actually new about these coolants or is this just another rebrand/relabel?
Systems: Fukurou | Prodigy | Tempest | ArcaneServers: Minecraft SMP | Logs: Build Log - Arcane | Video Logs: Project Arcane
Quote:Originally Posted by Zen00 https://www.overclock.net/img/forum/go_quote.gifZero, you are a master story teller, I am sleep now. http://files.overclock.net/images/smilies/thumb.gif
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
GIGABYTE GA-EX58-UD5
MSI GeForce GTX 1080TI DUKE
MSI GeForce GTX 680 Lightning
Kingston HyperX T1
Samsung 840 EVO
WD Caviar Black FASS
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Sony DVD Burner w/ Lightscribe
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Cooler Master HAF 932
Operating System
Windows 10 Pro (64)
X-Star DP2710
ASUS VK266H Black 25.5" 2ms LCD
Keyboard
X-Armor U9BL (Mech)
Mouse
Razer Deathadder Chroma
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Zalman Mic-1 (Clip-on Mic)
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Modded PS4, PS3, Xbox 360, and Logitech PC Controllers
Other
Thrustmaster T.16000M FCS HOTAS
Other
Rocketfish 720p Webcam
Other
Scythe "3-Foot Switch"
Ryzen 7 1700
MSI B350M Mortar Arctic
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Raijintek Aeneas White Window
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
WD Caviar Black AALS 640GB
WD Caviar Green EARS 2TB
Vertex Turbo 60GB (SSD)
Optical Drive
Samsung Blu-ray, Samsung DVD Burner
Seasonic X750 Gold
H50 (With push/pull nocturas)
CM690 II
Operating System
Windows 10 Professional 64
LG 47inch LED LCD
Keyboard
Saitek Eclipse Lite-touch Wireless
Audio
Passive bookshelfspeakers + amp.
Zero4549 is offline
post #4 of 62 (permalink) Old 03-29-2017, 10:07 AM
rolandos582's Avatar
Rep: 1 (Unique: 1)
Blood red seems like a sweet colour. Any samples how they would look like?
rolandos582 is offline
post #5 of 62 (permalink) Old 03-29-2017, 10:43 AM - Thread Starter
akira749 is offline
post #6 of 62 (permalink) Old 03-29-2017, 10:47 AM - Thread Starter
Hardware Rep
akira749's Avatar
It's new formula with new inhibitors. You can't even mix it with the old EVO coolants.
Like our EVO, this is a coolant of our own. Not like the Pastel line which is a partnership with Mayhems.
akira749 is offline
post #7 of 62 (permalink) Old 03-29-2017, 10:49 AM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 115 (Unique: 97)
Looks great. I'll be sampling some of the Blood Red. Although it doesn't look real dark in the picture. Looks like just "Red" to me.
Barefooter is offline
post #8 of 62 (permalink) Old 03-29-2017, 11:41 AM
Rep: 1 (Unique: 1)
True this, a mix of blood red looks black/red to me. Not like just standard red. rolleyes.gif
post #9 of 62 (permalink) Old 03-29-2017, 01:22 PM
Fluffy Fennec Foxes!
WhiteWulfe's Avatar
Rep: 167 (Unique: 123)
Name kind of feels like an energy drink ^_^
But the colours are kinda sexy.
I <3 Mechanical Keyboards | Member of OCN's Headphone club
Quote:Originally Posted by xxbassplayerxx
Don't mind Wulfe. He's writing his book one post at a time.
JägerWulfe
(19 items)
Gigadestroyer
Intel i7-4770K
Gigabyte Z87X-OC
MSI GTX 980 Ti Gaming 6G Golden Edition
G.Skill Triden-X 16GB DDR3-2400
Maxtor 2TB Black
Seagate 2TB SATA3
Optical Drive
LG DVD-RW
EVGA SuperNova 1000G2
Cryorig R1 ultimate
NZXT Phantom 820 Black
Operating System
Windows 7 Home Premium 64 bit
BenQ VP2210
BenQ VP2210
Keyboard
Razer BlackWidow Ultimate
Mouse
Steel Series Worgen
Mouse
Roccat Nyth
Audio
JDS Labs O2 + ODAC Rev.B
Audio
AKG K712
Audio
Audio Technica ATH-M50X
i7 3770k
Maximus V Formula
EVGA GTX 780 Classified
Corsair Dominator Platinum 1866MHz
Kingston 64GB SSDnow 200
EVGA 1000w G2
CoolerMaster MasterLiquid Pro 240
Open Bench Table
Operating System
Windows 7 64 Bit
Dell E2213H
Keyboard
Logitech G15 v2
Mouse
Corsair M95
Mouse
3' wide battle mat
AMD Phenom II X4 955 Black Edition
Asus Crosshair IV Formula
EVGA GTX 770 SuperClocked
4x Kingston Hyperx 4GB
Seagate 3TB
Fractal Designs Newton 600w
Arctic Cooling Freezer 13 Pro
Fractal Designs Define R4
Operating System
Dynex 32" television
Keyboard
Razer Black Widow Ultimate 2013
Mouse
Logitech G700
WhiteWulfe is offline
post #10 of 62 (permalink) Old 04-01-2017, 12:50 AM
Panzerfury's Avatar
Rep: 4 (Unique: 4)
Just ordered some Acid green for my upcomming watercooling. Looking forward to seeing it in real life.
Panzerfury is offline
