EVGA 1080 TI SC2 - Page 2 - Overclock.net - An Overclocking Community
EVGA 1080 TI SC2
post #11 of 54 (permalink) Old 07-28-2017, 02:45 AM
Romrommm Level 1
Romrommm's Avatar
someone try to remove the fan header and mount the FE waterblock?
Romrommm is offline
post #12 of 54 (permalink) Old 07-29-2017, 09:48 PM
gillza Level 1
gillza's Avatar
Originally Posted by akira749 View Post
We don't plan on making a block for this card.
Well that's rather disappointing. I came here in search of information regarding the waterblock to use. I am sure there will be more people buying these cards, please reconsider.
gillza is offline
post #13 of 54 (permalink) Old 08-12-2017, 09:39 AM
westpz Level 1
westpz's Avatar
Now that we have more people with SC2 cards, there should be a full cover block...
westpz is offline
post #14 of 54 (permalink) Old 08-22-2017, 09:26 AM
gillza Level 1
gillza's Avatar
Nvidia sells hydro copper version of this card. How hard is it to offer the waterblock for sale for those who already bought a card??...
gillza is offline
post #15 of 54 (permalink) Old 08-22-2017, 09:45 AM
westpz Level 1
westpz's Avatar
I contacted the EVGA support regarding this matter and I'm waiting for a reply. I'll post it here.
westpz is offline
post #16 of 54 (permalink) Old 08-22-2017, 09:50 AM
gillza Level 1
gillza's Avatar
good luck.
https://forums.evga.com/GTX-1080-TI-SC2-Waterblock-only-m2701274.aspx
Honestly, if they are refusing to release a block I'll just de-solder that fan connector and use the EK FE block instead as is seems to match the layout bar the connector.
gillza is offline
post #17 of 54 (permalink) Old 08-28-2017, 01:44 PM
Romrommm Level 1
Romrommm's Avatar
I can not understand this reasoning of not wanting to get a waterblock for this card and suddenly oblige those who buy it to integrate it in their watercooling configuration, to resell it to buy a sc black or FTW3 ....
Romrommm is offline
post #18 of 54 (permalink) Old 08-28-2017, 03:17 PM
gillza Level 1
gillza's Avatar
I am not sure I understood your reply correctly, but I assume you are asking why I did not get a card with a waterblock from the beginning? Well Let's say I made a mistake. I was thinking the hybrid cooling solution (for me) would be ideal. But after looking around these forums I realized I would like to try and build my own custom loop. Thus unfortunately i'm facing the issue with waterblock now.
Whats frustrating is that nvidia does have a waterblock for this card as evidenced by them selling hydrocopper version. However I suspect the hydrocoper version of the SC2 card actually comes without that fan header so that the can use the standard waterblock on it. That's why they don't want to sell it separately, it would not be compatible with unmodded card. Just my opinion...
gillza is offline
post #19 of 54 (permalink) Old 08-29-2017, 12:27 AM
Romrommm Level 1
Romrommm's Avatar
No I was not talking about you but rather the choice of EK not wanting to do a waterblock for the 1080Ti Sc2
Romrommm is offline
post #20 of 54 (permalink) Old 08-29-2017, 01:54 PM
westpz Level 1
westpz's Avatar
This was my exact question to EVGA support. If or when this block is released, will it fit our SC2 cards as I think they just removed the second header and used the titan X block. So, let's wait and see.
westpz is offline
