EVGA 1080 TI SC2 - Overclock.net - An Overclocking Community
EVGA 1080 TI SC2
post #1 of 54 (permalink) Old 05-06-2017, 10:23 PM - Thread Starter
sharpy36's Avatar
Rep: 0
Is there any news about getting a water block for the EVGA 1080 TI SC2? (11G-P4-6593)
It doesn't use the reference PCB so none of the current blocks will work with it. I can't possibly be the only one wanting one.
sharpy36 is offline
post #3 of 54 (permalink) Old 05-19-2017, 03:57 PM
circuitbent's Avatar
Rep: 0
I have the same card, and would definitely be interested in a water block for this card.
circuitbent is offline
post #4 of 54 (permalink) Old 05-23-2017, 10:30 PM
WaterCooling Enthusiast
FastEddieNYC's Avatar
Rep: 20 (Unique: 17)
I compared pictures of the reference pcb to the SC2 and the Vrm section, mounting holes and 98% of the PCB are identical. They moved the voltage control chips to the back side and added 9 small Thermal Sensors. Since the ICX cooler is Identical for the SC Black(Ref board) and SC2 the water block should work. It's the back plate that might be a problem.
Asus Z97 Hero Delidded 4790K Swiftech block EVGA 1080 TI shunt modded Kryrographics black & backplate Custom Water 60mm 360 rad push/pull 2 240mm rads in push MCP50X pump Swiftech Res
FastEddieNYC is offline
post #5 of 54 (permalink) Old 05-24-2017, 06:22 AM
Hardware Rep
akira749's Avatar
Rep: 279 (Unique: 184)
I'll try to have a bit more info.
akira749 is offline
post #6 of 54 (permalink) Old 05-25-2017, 03:22 AM
Hardware Rep
akira749's Avatar
I received my info. On the picture below you'll see the second header on the left. This is what is blocking the compatibility.
akira749 is offline
post #7 of 54 (permalink) Old 05-25-2017, 10:33 AM
MaratRussian's Avatar
Rep: 4 (Unique: 4)
Here is a picture of new fe waterblock, looks like there is nothing important next to this fan header (near the ek sticker on the waterblock), it is possible to make it compatible with a simple mod to the waterblock or to the card
MaratRussian is offline
post #8 of 54 (permalink) Old 05-30-2017, 07:24 PM
PCNerd's Avatar
Rep: 430 (Unique: 256)
Thanks for looking into this! I was wondering what the difference was between this and the stock PCB/FE waterblock besides the fan header.
I currently have 2 of the SC2 cards but I'll probably swap them for the FTW3s once y'all release the water blocks for those.
PCNerd is offline
post #9 of 54 (permalink) Old 07-02-2017, 02:30 PM
Lektek's Avatar
Rep: 0
So is it just that fan header getting in the way? Is it a simple task to desolder and remove the header?
Lektek is offline
post #10 of 54 (permalink) Old 07-02-2017, 04:17 PM
Lektek's Avatar
Rep: 0
Lektek is offline
