Compatibility of the EK-FB ASUS Z270I Strix RGB Monoblock with Z370-I - Page 6 - Overclock.net - An Overclocking Community
post #51 of 56 (permalink) Old 07-04-2018, 04:56 AM
Linux Lobbyist
Rep: 0
Can I hopelessly revive this thread, and ask how you got the CE280 in the front with the control panel still attached? I found your thread searching as I am doing a similar setup (Nano S / CE280).
I had to drill out both rivets on the front left side to get the radiator in flush against the front, however it blocks the slot for the control panel/USB headers in it.. what did you do to resolve that?
How did you mount your 140mm fans, as the radiator sits really high and offsets the holes too far?
Shellite is offline
post #52 of 56 (permalink) Old 07-09-2018, 06:05 AM
Linux Lobbyist
GrumpyBear17's Avatar
Rep: 7
I hope you aren't shy with using a dremel! I can't attach pics for some reason but I chucked them on imgur.
No chance this is possible with the audio and USB headers in - I am only using the board jumpers here. In hindsight, I would have relocated the power button elsewhere, I would definitely consider this if I were you man. Took me hours of careful grinding to get right.
In one of the pics you can see the opening I made for the wires to now go through, that's how I fixed that. There's enough give in them that you can do that.
PM me if you need a further hand with this!
https://imgur.com/s6u1RHb
https://imgur.com/WZwCM8M
https://imgur.com/vAGvypr
https://imgur.com/G3KfMuy
https://imgur.com/cbOeNGn
GrumpyBear17 is offline
post #53 of 56 (permalink) Old 07-09-2018, 06:43 AM
Linux Lobbyist
Rep: 0
Thanks for taking time to reply to this old thread, I certainly wasn't shy with the dremel... I will take some pictures tomorrow afternoon when I get home from work. I have the CE280 installed, with the audio/usb headers all in tact... have I gone too far?
Shellite is offline
post #54 of 56 (permalink) Old 01-09-2019, 01:04 AM
MaratRussian's Avatar
Rep: 4
Sorry for reviving an old thread but how this monoblock performs on z370i mobo, especially with no contact with inductors
I’m thinking to add a copper bar 3x10x50mm between inductors and the monoclock with liquid metal on the monoblock side and thermal pad on the inductors side. Or it is all fine and does not worth the effort?
MaratRussian is offline
post #55 of 56 (permalink) Old 01-09-2019, 05:47 AM
17.6 liters
WiSK's Avatar
Rep: 553
I don't believe it makes any difference to highest clocks you can achieve, maybe the lifespan of the chokes is improved.
If you are easily able to buy or make the correct sized copper bar, then it's pretty easy to add it. I would not recommend liquid metal, thin paste is fine between copper bar and block (if it's the right height). Several extra thermal pads are included with the block.
WiSK is offline
post #56 of 56 (permalink) Old 01-10-2019, 03:26 AM
Rep: 4
probabbly go that way, LM would be an overkill
I've already bought different thickness thermal pads starting drom 0.5mm -1mm 1.5mm and 2mm. The distance between the waterblock and the chokes is around 4mm (as I measured) so 3 mm copper would be enough. it costs around $5 from aliexpress delivered to my door) https://s.click.aliexpress.com/e/Tp9PW0i
