Compatibility of the EK-FB ASUS Z270I Strix RGB Monoblock with Z370-I - Overclock.net - An Overclocking Community
post #1 of 56 (permalink) Old 10-03-2017, 03:56 PM - Thread Starter
ForScience's Avatar
Rep: 1
Hello,
I noticed that on the compatibility of the Z270I monoblock has been updated to include the upcoming Z370-I motherboard from ASUS. However it says that the "Inductor coils won't make contact with the monoblock.", can you elaborate on how deterimental this is and whether something like getting thicker thermal pads can solve the issue entirely. (If so, it would be great if you could advise on what thickness needs to be obtained).
Thanks in advance
ForScience is offline
post #2 of 56 (permalink) Old 10-04-2017, 12:32 PM
Linux Lobbyist
Fediuld's Avatar
Rep: 13
Originally Posted by ForScience View Post
Hello,
Thanks in advance
Yeah good notice mate.
Fediuld is offline
post #3 of 56 (permalink) Old 10-10-2017, 10:47 AM
akira749 is offline
post #4 of 56 (permalink) Old 10-17-2017, 07:49 AM
TGHaworth's Avatar
Rep: 3
Would really like the answer to this.
TGHaworth is offline
post #5 of 56 (permalink) Old 10-19-2017, 05:42 AM
dejoris's Avatar
Rep: 0
Originally Posted by akira749 View Post
I'll try to know what it implies
Any update?
The EKWB site claims that they did a "visual" check.
Surely they should be able to do a physical one now?
dejoris is offline
post #6 of 56 (permalink) Old 10-22-2017, 05:31 AM
Apoll's Avatar
Rep: 3
@akira749 any news on this? Seems there is a new batch of those monoblocks coming out November 3rd according to EKWB website.
Are there any changes on the block to cover the inductors?
If not, does anyone else knows how thick the pads have to be? It is more than 2mm, which is the maximum thickness of the Minus Pad8?
Apoll is offline
post #7 of 56 (permalink) Old 10-22-2017, 05:36 AM
dejoris's Avatar
Rep: 0
Seems like this can be solved with thicker thermal pads.
Discussion about same topic at lts: https://linustechtips.com/main/topic/841657-cooling-of-motherboard-inductor-coils/
dejoris is offline
post #8 of 56 (permalink) Old 10-22-2017, 07:51 AM
Apoll's Avatar
Rep: 3
Actually isn't "resolved", because the discussion ended when someone proposed to use 5mm thick pads, with no feedback back. But is 5mm pad needed?
5mm is very big gap, which means Asus chopped almost half of the inductors height? Is crazy even to think about it. Because nothing else has changed, only the inductors cooling.
And it would be better to know the exact thickness needed, because if it is up to 2mm, we can use far superior Minus Pad 8, and not some silicon based, of unknown quality pad.
Apoll is offline
post #9 of 56 (permalink) Old 10-22-2017, 08:04 AM
dejoris's Avatar
Rep: 0
Nobody said "resolved".
Seems like someone is just going to have to buy both things and check to be honest.
Hopefully it will be EK doing that but either way no point going further based on visuals imo.
dejoris is offline
post #10 of 56 (permalink) Old 10-27-2017, 10:54 AM
Hardware Rep
akira749's Avatar
Rep: 279
Sorry for the delay guys.
The inductors height has changed and it's not making contact with the block anymore but it won't affect any performances and there's no need to add thicker pads over them.
Of course, if you really want, you could fill the gap with thicker pads. I just don't know the height difference though.
akira749 is offline
