EK-MLC Phoenix Expandable AIO Club & Discussion Thread - Page 2 - Overclock.net - An Overclocking Community
post #11 of 331 (permalink) Old 12-08-2017, 12:54 PM
TheStayHomeDad
ACallander Level 1
ACallander's Avatar
Let's see those beautiful pictures!
Main Rig
Ryzen 1700
Asus ROG Crosshair VI Extreme
GeForce GTX 1080ti
Corsair Vengence
EVGA
EK Phoenix
AMD Wrath Cooler
Caselabs Bullet BH8
Operating System
Windows 10 Pro
Acer Predator 1440p G-Sync
Dell Ultrawide
Keyboard
Anne Pro
Mouse
Logitech G403
ACallander is offline
post #12 of 331 (permalink) Old 12-09-2017, 01:01 PM
xboxonesucks Level 1
xboxonesucks's Avatar
HELP please!!! I wasn’t able to upload pics. Sorry.
MK-MLC Phoenix 280mm AIO with intel cpu block. I hired a builder to build my pc.
I keep getting “CPU fan speed error detected”
Nothing is connected to the main cpu header on my mobo. I noticed that these are two pins and on the mother board it is 4 pins. The two 2 pin cables from the AIO is connected to the cpu opt and the slot next to that. Will the fans speed up if cpu gets hot the way it’s set up? Can anyone include pics if possible. Thanks!
8700k
1080ti ftw3 hybrid
Maximus x hero z370
xboxonesucks is offline
post #13 of 331 (permalink) Old 12-09-2017, 01:48 PM - Thread Starter
KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about
KedarWolf's Avatar
8700k
1080ti ftw3 hybrid
Maximus x hero z370
See this .pdf, you have the fan header installed wrong.
https://www.ekwb.com/shop/EK-IM/EK-IM-3831109863817.pdf
KedarWolf -- Intel i9 [email protected] CPU/4.7GHZ Cache -- Gigabyte Aorus Xtreme Motherboard -- CPU Offset Voltage .150v AC Loadline 1, DC Loadline 0. LLC Medium -- G.Skill Ripjaws 5 CL14 3200MHZ 4x8GB 17-17-17-32 2T @ 4133MHZ 1.44v Eventual -- VCCIO 1.23v -- SA 1.23v -- Gigabyte 1080 Ti Founders Edition - XOC No Power Limit BIOS -- 2x 512GB RAID 0 Samsung 960 Pro M.2 System/Game Drive -- 4TB Hitachi 7200RPM Storage Drive -- PSU- Corsair AX1500i -- Logitech G903 Wireless Mouse -- Logitech Lightspeed Mouse Pad
EKWB Water Cooled i9 9900k @ 5.1 GHZ CPU - 4.7 GHZ cache - +1.50 Offset - 1 AC Loadline, 0 DC Loadline, 1.314v CPU VR VOUT Prime95
Gigabyte Aorus Xtreme 16 Phase Motherboard
Gigabyte 1080 Ti FE Watercooled 2038 Core/6142 Memory
G.Skill Ripjaws 5 CL14 3200 @ 4133MHZ 17-17-17-32 2T 1.44v - SA 1.23/VCCIO 1.23
Samsung 960 Pro M.2 x2 RAID 0
Hitachi 4TB Hard Drive
Optical Drive
LG Electronics WH14NS40 BD-RW
Corsair AX1500i
EKWB Predator 360 With QDCs EKWB Supremacy EVO CPU Waterblock.
EKWB MLC 360 With QDCs EKWB 1080 Ti FE Full Cover Waterblock And Backplate
Thermaltake Core X9
Operating System
Microsoft Windows 10 LTSC 2019
Acer XB280HK 4K G-Sync
Acer 1080p Second Screen
Keyboard
Logitech Orion Spark G910
Mouse
Logitech G903 Lightspeed Wireless Gaming Mouse
Mousepad
KedarWolf is offline
post #14 of 331 (permalink) Old 12-09-2017, 07:04 PM
swingarm Level 1
swingarm's Avatar
I think I know the answer to this but just to be sure:
Are all the parts on the Phoenix replaceable including the pump?
swingarm is offline
post #15 of 331 (permalink) Old 12-10-2017, 12:46 AM
Thank you sir. So, I called Asus earlier. Turns out the the 2 pin connected from the radiator was connected in the correct cpu fan heAder. The 2 pin from the AIO block was connected to a fan header instead of the AIO spot. So I switched that one to the AIO spot and I don’t get the error anymore. This is my first PC. I’m a total noob. What antivirus do you guys recommend? What temps are you guys getting with your EK-MLC? I idle at 29-31 C. Don’t know how to check temps when I’m gaming. If the cpu gets hot, the fans will increase rpm accordingly right? Thanks!!
post #16 of 331 (permalink) Old 12-10-2017, 07:12 PM
ccozmo Level 1
ccozmo's Avatar
I have a MLC 360 on my Predator 360 prefilled 1080 Ti GPU block and my CPU on my Predator 360 on separate loops.
I'm disappointed the pump doesn't have a standalone PWM header to control the pump alone. It seems to be integrated with the fans. redface.gif
If I wanted to replace the stock fans in push/pull what would people recommend for high CFM radiator fans.
Noise is not an issue, I use a headset and even my 3000 RPM system fans I can't hear currently. thumb.gif
I use these, and they are quite good. During normal temps they are quiet and get a bit noisy when turned up to 100%. The have very high static pressure
https://www.ekwb.com/shop/ek-furious-vardar-evo-120
I also have some of these on case for intake. They are quieter so I can run them at 100% 24/7. They have slightly lower static pressure
https://www.ekwb.com/shop/ek-vardar-f4-120er-type-p017-bulk
ccozmo is offline
post #17 of 331 (permalink) Old 12-12-2017, 10:33 AM
2 Easy
nyk20z3 Level 1
nyk20z3's Avatar
How do you think a MLC 360 kit will perform cooling a 8700K and 1080 Ti Strix ?
nyk20z3 is offline
post #18 of 331 (permalink) Old 12-12-2017, 10:51 AM
bl4ckdot Level 1
bl4ckdot's Avatar
Pretty nicely IMO
Build log : Hécate Mk I
Hécate Mk I
(21 items)
der8auer C​ore i7-870​0K Ultra​ Edition
Asus ROG MAXIMUS X FORMULA
NVIDIA Titan X (Pascal)
G.Skill F4​-3600C16Q-​32GTZKK
Intel Opta​ne 900p 48​0GB
Samsung 960 Pro 2TB
SanDisk Ultra II 960GB
Seasonic PRIME Titanium 1000W
EK MLC Phoenix [2x360]
Parvum Cus​tom-made
Operating System
Windows 10 Pro
Dell S2716DG
Dell UP2516D
Keyboard
Corsair K70
Mouse
Logitech G502 Proteus Core
Mousepad
HyperX FUR​Y S Pro
Audio
Focal Elea​r
Audio
Audeze Dec​kard
Audio
AT2035
Audio
Yamaha MG10XU
Other
Ensourced ​Custom Cab​les
bl4ckdot is offline
post #19 of 331 (permalink) Old 12-12-2017, 11:00 AM
swingarm Level 1
swingarm's Avatar
Thinking about getting a 280 for my 1080 Ti and 5960X. Would do a 360 but I would have redo my whole computer.
swingarm is offline
post #20 of 331 (permalink) Old 12-13-2017, 05:07 PM
jamexman Level 1
jamexman's Avatar
Originally Posted by swingarm View Post
I'm kinda new to this part of water cooling and I'm intrigued by the Phoenix product but have a couple of pre-sale questions:
1. I want to be sure I get the right GPU waterblock for my EVGA 1080 Ti SC Black Edition, what model should I use?
2. Are the GPU waterblocks full coverage?
SC Blacks are reference PCBs so a standard MLC 1080 TI EKWB block will work. smile.gif
Yes, they are full coverage but definitely get a backplate as well. thumb.gif
If you want to go all out replace the stock thermal pads with:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=fujipoly+17+w%2Fmk
Nooo, be careful though. The SC black edition has a reference pcb, however it has a dvi connector whereas the ref doesn't. Per ek compat list, the reference 1080ti block will not fit these. You have to use the Titan X pascal block though.
jamexman is offline
