EK-MLC Phoenix Expandable AIO Club & Discussion Thread - Page 3 - Overclock.net - An Overclocking Community
Old 12-13-2017, 05:18 PM - Thread Starter
KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about KedarWolf has a spectacular aura about
KedarWolf's Avatar
Originally Posted by jamexman View Post
Originally Posted by swingarm View Post
I'm kinda new to this part of water cooling and I'm intrigued by the Phoenix product but have a couple of pre-sale questions:
1. I want to be sure I get the right GPU waterblock for my EVGA 1080 Ti SC Black Edition, what model should I use?
2. Are the GPU waterblocks full coverage?
Originally Posted by KedarWolf View Post
SC Blacks are reference PCBs so a standard MLC 1080 TI EKWB block will work. smile.gif
Yes, they are full coverage but definitely get a backplate as well. thumb.gif
If you want to go all out replace the stock thermal pads with:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=fujipoly+17+w%2Fmk
Nooo, be careful though. The SC black edition has a reference pcb, however it has a dvi connector whereas the ref doesn't. Per ek compat list, the reference 1080ti block will not fit these. You have to use the Titan X pascal block though.
Good catch! Rep +1
KedarWolf -- Intel i9 [email protected] CPU/4.7GHZ Cache -- Gigabyte Aorus Xtreme Motherboard -- CPU Offset Voltage .150v AC Loadline 1, DC Loadline 0. LLC Medium -- G.Skill Ripjaws 5 CL14 3200MHZ 4x8GB 17-17-17-32 2T @ 4133MHZ 1.44v Eventual -- VCCIO 1.23v -- SA 1.23v -- Gigabyte 1080 Ti Founders Edition - XOC No Power Limit BIOS -- 2x 512GB RAID 0 Samsung 960 Pro M.2 System/Game Drive -- 4TB Hitachi 7200RPM Storage Drive -- PSU- Corsair AX1500i -- Logitech G903 Wireless Mouse -- Logitech Lightspeed Mouse Pad
EKWB Water Cooled i9 9900k @ 5.1 GHZ CPU - 4.7 GHZ cache - +1.50 Offset - 1 AC Loadline, 0 DC Loadline, 1.314v CPU VR VOUT Prime95
Gigabyte Aorus Xtreme 16 Phase Motherboard
Gigabyte 1080 Ti FE Watercooled 2038 Core/6142 Memory
G.Skill Ripjaws 5 CL14 3200 @ 4133MHZ 17-17-17-32 2T 1.44v - SA 1.23/VCCIO 1.23
Samsung 960 Pro M.2 x2 RAID 0
Hitachi 4TB Hard Drive
Optical Drive
LG Electronics WH14NS40 BD-RW
Corsair AX1500i
EKWB Predator 360 With QDCs EKWB Supremacy EVO CPU Waterblock.
EKWB MLC 360 With QDCs EKWB 1080 Ti FE Full Cover Waterblock And Backplate
Thermaltake Core X9
Operating System
Microsoft Windows 10 LTSC 2019
Acer XB280HK 4K G-Sync
Acer 1080p Second Screen
Keyboard
Logitech Orion Spark G910
Mouse
Logitech G903 Lightspeed Wireless Gaming Mouse
Mousepad
KedarWolf is offline
Old 12-13-2017, 05:51 PM
Earthsiege Level 1
Earthsiege's Avatar
Oh shoot, are you sure? The EK-MLC configurator gives both the Titan X and 1080 TI blocks as compatible. Apparently the Titan X blocks are EOL though, as I couldn't add it to my cart.
Earthsiege is offline
Old 12-13-2017, 05:57 PM - Thread Starter
KedarWolf's Avatar
The FE block works according to this.
https://www.ekwb.com/configurator/step1_complist?gpu_gpus=3784
Optical Drive
Corsair AX1500i
Thermaltake Core X9
Operating System
Keyboard
Mouse
Mousepad
Old 12-16-2017, 05:55 AM
jamexman Level 1
jamexman's Avatar
Yep, that one too (it's the regular GTX 1080 block, not the Ti specific one, since it has the space for the DVI connector.) The ones not compatible are the Ti FE specific blocks.
Sent from my SM-G955U using Tapatalk
jamexman is offline
Old 12-16-2017, 05:59 AM
jamexman Level 1
jamexman's Avatar
Yes, 100% sure. Per Kedarwolfes last post, it's the Titan x Pascal and 1080 FE blocks the compatibles ones. You're just getting confused as you're thinking the *Ti* Fe blocks are the ones compatible, they're not (at Ti Fe doesn't have the DVI connector). It's the regular 1080 Fe (note the lack of Ti here).
jamexman is offline
Old 12-16-2017, 08:04 AM - Thread Starter
KedarWolf's Avatar
FE block listed compatible here as well.
Optical Drive
Corsair AX1500i
Thermaltake Core X9
Operating System
Keyboard
Mouse
Mousepad
Old 12-17-2017, 12:01 PM
jamexman Level 1
jamexman's Avatar
Yes, that is what I've been saying, those are good.
Ok lets clear it a little bit more. Those FE ones you're pointing out are generic ones that will fit FE (1080, 1080 ti, 1070 etc etc) and are fine, kind of one glove fit all.
The ones that don't fit are the Ti specific ones, like this one: https://www.ekwb.com/shop/ek-fc-1080-gtx-ti-nickel , thats is what I was trying to clarify to him as he pointed the "Ti" should be good too. Those will only fit the FE designs without a DVI connector. The SC black is FE board, however has a DVI connector. Just my 2 cents, with so many variations we gotta be careful lol.
jamexman is offline
Old 12-17-2017, 12:06 PM
jamexman Level 1
jamexman's Avatar
So, is it not recommended to mix a predator prefilled block with one of these MLC modules? Reason I ask is the difference in the coolant? Or will it be ok??
jamexman is offline
Old 12-17-2017, 12:50 PM
Maximum OCN
CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about
CptSpig's Avatar
Need to drain the Predator gpu block, flush and refill with the newer cryo fule coolant. thumb.gif
X299 RIG
(19 items)
X99 RIG
(17 items)
i9-7980XE
ASUS ROG RAMPAGE VI APEX LGA2066 DDR4 M.2 X299 EATX Motherboard
Nvidia TITAN Xp
G.SKILL TridentZ Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) Model F4-3600C16Q-32GTZKK
Samsung SSD 960 EVO NVMe M.2 500GB
Samsung SSD 850 Pro 2.5" SATAIII 512 GB
Corsair AX1500i Digital ATX Power Supply
EKWB EK-FC Titan X Pascal - Acetal+Nickel
EXC-800 Portable 800W Recirculating Liquid Chiller
Phobya G-Changer Xtreme NOVA 1080 radiator 60mm - Full Copper
CPU-390I Water Block, Nickel Top
EK-XRES 140 DDC 3.2 PWM Elite
PrimoChill Praxis Wet bench
Operating System
Windows 10 Pro 64 bit
ASUS ROG Swift PG279Q Gaming Monitor - 27" 2K WQHD (2560 x 1440) IPS, overclockable 165Hz, G-SYNC
Keyboard
Corsair Gaming K70 RGB Mechanical Gaming Keyboard — Cherry MX Red
Mouse
M65 PRO RGB FPS Gaming Mouse — Black
Mouse
SteelSeries QcK XXL
Audio
Corsair Vengeance 2100 wireless
i7-6950X Processor
MSI X99A GODLIKE GAMING CARBON
Nvidia TITAN X Pascal
Corsair Dominator Platinum Series 32GB (4 x 8GB) DDR4 DRAM 3200MHz C16 Memory Kit
Samsung SSD 850 PRO 2.5" SATA III 512GB
EVGA SuperNOVA 1000 G2 Power Supply
EK-XLC Predator 360 (incl. QDC) with DDC3.2 PWM pump upgrade with EK-DDC Heatsink Housing - Black
Koolance EXC-800 Portable 800W Recirculating Liquid Chiller
Operating System
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
CptSpig is offline
Old 12-17-2017, 01:48 PM - Thread Starter
KedarWolf's Avatar
Yes, the 1080 Ti FE version will not work with a 1080 TI SC Black. You need the Pascal Titan X or the regular GTX FE version.
I'd go with the Pascal Titan X myself.
Optical Drive
Corsair AX1500i
Thermaltake Core X9
Operating System
Keyboard
Mouse
Mousepad
