EK-MLC Phoenix Expandable AIO Club & Discussion Thread - Page 35 - Overclock.net - An Overclocking Community
post #341 of 348 (permalink) Old 04-03-2019, 09:08 AM
bl4ckdot's Avatar
Rep: 14 (Unique: 13)
PSA : The screws on the MLC for the fans used are M4x6 DIN7984 - 9023
They are not 6-32 like their others radiators.
Build log : Hécate Mk I
Hécate Mk II
(21 items)
Intel i9 9900K
Asus ROG MAXIMUS XI EXTREME
Palit RTX 2080 Ti (380W - Samsung)
G.Skill F4​-3600C16Q-​32GTZKK
Intel Opta​ne 900p 48​0GB
Samsung 960 Pro 2TB
SanDisk Ultra II 960GB
Seasonic PRIME Titanium 1000W
EK MLC Phoenix [2x360]
Parvum Cus​tom-made
Operating System
Windows 10 Pro
Dell S2716DG
Dell UP2516D
Keyboard
Ducky One 2 TKL RGB
Mouse
Logitech G502 Lightspeed
Mousepad
HyperX FUR​Y S Pro
Audio
Focal Elea​r
Audio
Audeze Dec​kard
Audio
AT2035
Audio
Yamaha MG10XU
Other
Ensourced ​Custom Cab​les
bl4ckdot is offline
post #342 of 348 (permalink) Old 04-27-2019, 05:27 PM
Stock
hyp36rmax's Avatar
Rep: 144 (Unique: 122)
Anyone have the tubing size for those of us who want to replace it?
hyp36rmax is offline
post #343 of 348 (permalink) Old 04-30-2019, 02:59 PM
Martin778's Avatar
Rep: 14 (Unique: 14)
Would it be worth it to replace the H150i for the Phoenix and maybe add a second radiator module, if possible?
Nvm, the 360mm is apparently EOL...
Core i9 9900K @ 5.2 || EVGA Z390 DARK || 2x8GB G.Skill TridentZ RGB 4600 C18 @ 4266 C17 || GPU: EVGA Kingpin RTX2080Ti @ 2130MHz || Samsung 970PRO 1TB + 860EVO 2TB || Lian Li O11 Dynamic White || Corsair AX1600i || Screen: LG B8 OLED 55 and LG 34GK950F
Corsair H150i PRO + Noctua NF-A12x25
Martin778 is offline
post #344 of 348 (permalink) Old 05-02-2019, 11:52 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 0
Hey Guys! I still consider myself a noob when it comes to water cooling, even though I have been running AIOs for years now, I switched to the Phoenix Kit Shortly after it released and now run it on my 2700x Build. As many other have noted on this thread from time to time I heard air going through the pump. I have already topped it off, but unfortunately there is still air stuck in the loop, and you hear it move through the pump maybe once every few hours or so. You only hear the noise for a second or 2, but I would still prefer to burp the air out of the system.
The Way My Phoenix is mounted, I took my old school ass case that had no room for the 360MLC on the inside, Measured and Cut 2 Holes on the top of my Steel Case for both the Tubes to go into, and Mounted my Rad on Top of the case, Tube Side Down. So The Port I used to top it off is conveniently placed right there on the top of the RAD, and I noticed on the opposite side of the Rad, there is another Port. I am thinking it may be possible to burp the system from that port. Unfortunately this is where my inexperience with Custom Water Cooling Loops comes into play.
1) Is my assumption even correct that I could completely take off the "Fill" port I mentioned, and then maybe just give like a half of rotation turn to the port on the Rear of the Rad to Burp the system?
2) With Just like a half of Rotation turn on the Rear, would that be enough to have the fluid start leaking, making this a dumb lesson to learn?
This is a HUGE System, and not the easiest to pick up and move around to try to get the air out, and would be a pain in the AS* to completely remove. However as I will be dropping in a new Ryzen 3rd Gen Chip in the next few months when they launch I could just do it then if I have to remove the rad to properly burp the system, but I am concerned the air moving through the pump every so often will eventually hurt it.
Also, I was thinking about grabbing a DDC Pump and replacing the SDC Pump, it appears I could just drop it in, has anyone tried that? Would their be a noticeable difference in Performance with a DDC Pump, or is not Worth it when just cooling the CPU? (My 1080ti Is on a Separate loop)
Thank You guys for your Help, sorry for so Many Questions!
P.S. I am providing pictures to show where the Ports are, and the build in General. I just Thoroughly Cleaned and Dusted this Case just over a Month ago, but Live in Las Vegas, and Unfortunately the Dust Builds up FAST. I didn't realize until viewing the Pictures just now, how damn DUSTY this thing got ALREADY! I don't feel like retaking the Pics, so I am sorry, I know this is Sacrilege, I will take care of it in the morning, I promise! LOL!
Thank You For Your Help!
-MattTheTech
DodekaZen3000
(28 items)
Ryzen 9 3900x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo
WD Black 4TB
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 2 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is online now
post #345 of 348 (permalink) Old 06-20-2019, 07:47 AM
ROKUGAN's Avatar
Rep: 10 (Unique: 6)
10/16 mmm - it´s detailed in the instructions
I bought the tubing below together with some Quick-Disconnects to expand my loop with a non-MLC water block for my GPU and an independent EK-DDC pump+reservoir, as I find the EK-SPC Pump in the radiator module to be a bit too weak for larger loops. Specially since the Phoenix tubing is way too long.
https://www.ekwb.com/shop/ek-tube-zm...-black-16-10mm
Rokugan ROG Max
(20 items)
INTEL i9 9900K
ASUS ROG MAXIMUS X HERO
Palit RTX 2080 Ti GamingPro OC + HEATKILLER IV WB
G. Skill Trident Z RGB 64GB (4x16GB) DDR4 3600MHz CL16 RAM Memory
SAMSUNG 960 PRO M.2 1TB
SAMSUNG 850 PRO 1TB
Optical Drive
LG BH16NS55 Blu-Ray
CORSAIR AX1200i 1200W 80 Plus Platinum
EK MLC-PHOENIX 360 + 120
CORSAIR 780T
Operating System
WINDOWS 10 PRO
SAMSUNG HU9000 4K 55'
Keyboard
CORSAIR K95 RGB Platinum
Mouse
LOGITECH G502 Lightspeed
Mouse
CORSAIR MM800 RGB POLARIS
Mouse
LOGITECH Powerplay
Audio
CREATIVE SOUNBLASTER ZxR V6 Vivid
Audio
CREATIVE SOUNBLASTER EVO ZxR Wireless
Audio
SENNHEISER HD800 SDR
Audio
Monolith M1060 Vegan
ROKUGAN is offline
post #346 of 348 (permalink) Old 07-19-2019, 04:37 PM
Aussiejuggalo's Avatar
Rep: 65 (Unique: 47)
So is the MLC Phoenix still being made or has it been discontinued? I noticed all of the Phoenix stuff is in EK's clearance section on the website...
Humble SM5 MK2
(23 items)
AMD Ryzen 7 1800X
MSI B350M Mortar Arctic
MSI GTX 1070 ARMOR OC
G.Skill Trident Z F4-3200C14D-32GTZKW 32GB
Samsung 960 EVO NVMe M.2 250GB
Samsung 850 EVO 1TB
Western Digital Blue WD10EZEX 1TB
EVGA Supernova G2 850W
Corsair H100i V2
Corsair ML120 Pro x5
CaseLabs SM5
Operating System
Windows 10 Enterprise 2016 LTSB 64-Bit
Dell U2414H
Dell U2414H
Asus VG248QE
Keyboard
WASD CODE 87-Key - Cherry MX Clear
Mouse
Zowie FK1
Mousepad
Artisan ZERO MID Black Large Mouse Pad
Audio
JDS Labs Element
Audio
Sennheiser HD 599
Audio
Samson Q2U
Audio
Swan M50W Powered 2.1 System
Audio
Rode AI1
Aussiejuggalo is offline
post #347 of 348 (permalink) Old 07-20-2019, 11:41 AM
bl4ckdot's Avatar
Discontinued AFAIK. Its not even on the website anymore.
Hécate Mk II
(21 items)
Intel i9 9900K
Samsung 960 Pro 2TB
Parvum Cus​tom-made
Operating System
Windows 10 Pro
Dell S2716DG
Dell UP2516D
Keyboard
Ducky One 2 TKL RGB
Mouse
Mousepad
HyperX FUR​Y S Pro
Audio
Focal Elea​r
Audio
Audeze Dec​kard
Audio
AT2035
Audio
Yamaha MG10XU
Other
bl4ckdot is offline
post #348 of 348 (permalink) Old 07-20-2019, 11:54 AM
⤷ αC
AlphaC's Avatar
Rep: 872 (Unique: 575)
Probably phased out due to cost in favor of the EK Classic series kit.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
