Upgraded Watercooling Loop to a Dual Radiator Setup, but temps are now hotter? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 13 (permalink) Old 12-21-2018, 04:29 AM
Ashcroft's Avatar
Rep: 80 (Unique: 63)
I would set both rads to intaking cool ambient air.
By having both rads intaking the coolant temp is as low as it can be, so the air going into the case is cooler. With one intake one exhaust the coolant temps are higher so the air going into the case is warmer and the overall air flow rate is lower too.
In testing most cases will work better with both rads intaking but I haven't seen the o11 specifically tested.
Its commonly suggested that rads intaking will cook the internal components but when you have two rads worth of airflow going through the chamber it provides more air to cool and its lower temp air too so heat can't really build up.
Ashcroft is offline
post #12 of 13 (permalink) Old 12-21-2018, 05:57 AM
cg4200's Avatar
Rep: 6 (Unique: 6)
Hey bud I have gtx dual rads360 420 not ek.. but I had that problem switching last case. I do now have a cheap power supply so after I installed everything before mounting cpu block on cpu with its tubes hooked up. and no power to motherboard in case it leaks.. I will run pump and tilt pc all the way back hear bubbles then forward sideways also I will lift up cpu block hold upside down for few seconds bam system is bleed used to take me longer.
Also not sure but on my rads I read if you all looking at both inlets have intake flow to rad the right one and fluid come out left one maybe that is just because the way duals are made …
And last tip I delided my 9900k so I know what direction chip is running I made sure when mounting (cpu block I looked at micro fin orientation and made sure running length of chip.. good luck
X99 Msi pro carbon
6850k 4.5- crucial oc 3200 14 14 14 34
Thermaltake x9
49'' wasabi mango 4k
2-evga 1080 ti WB 2075 +500 mem
2-Black Ice Nemesis 360GTX
I-Black ice 140
X299 msi sli plus
7800x 4.8
16 gb crucial ram
1 gigabyte 64 lc 1750 1150
1 xfx 56 vega 1680 1075
open custom bench
cg4200 is offline
post #13 of 13 (permalink) Old 12-21-2018, 09:02 PM
RichKnecht's Avatar
Rep: 4 (Unique: 4)
Check the cfm rating on the RGB fans. If I remember correctly, they have 1/2 the airflow as a non-RGB ML Pro. It's the reason I did not buy RGB fans.
Editing PC
(11 items)
7900X
Asus Rampage VI Extreme Omega
ASUS RTX 2060 Dual
Corsair vengence RGB 3466
Samsung 960 EVO 256GB
EVGA 1300W SuperNova Gold
EKWB PE360x2, XE360, Supremacy EVO RGB, Xres140 D5 RGB
Liam Li PC011 Air
Operating System
Windows 10 Pro 64bit
Dell U2412
BenQ 2700PT
RichKnecht is offline
Tags
8700k , delidded , dual radiators , higher temps
