EK-FB ASUS PRIME X299 RGB Monoblock + thermaltake pump pr22 d5 plus - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 10-08-2018, 01:43 AM - Thread Starter
KIENAST's Avatar
Rep: 0
Dear All,
I hope this is the right place to post and get some help .
I am currently building my first custom loop using a EK-FB ASUS PRIME X299 RGB Monoblock and a combo thermaltake PR22-d5 as pump and reservoir .
I have an issue with a big air bubble always coming back in the top left corner of the monoblock .
When I removed it , the bubble comes back at the excat same place the day after .
The knoob speed of my pump is currently set to 3 among 5 different possibilitiy , the maximum being 5 .
Would you know what the potential issue could be and how can I get rid of the bubble ?
thanks
Da
Name:	air bubble.jpg
KIENAST is offline
post #2 of 9 (permalink) Old 11-20-2018, 04:31 AM
Rep: 0
The same thing happens to me every time I put in or change the fluid. I have the memo block. ALWAYS this "bubble" disappears in less than 24 hours. I've never had bigger problems.
RANDRADE is offline
post #3 of 9 (permalink) Old 11-20-2018, 08:47 AM
Abaidor's Avatar
Rep: 2 (Unique: 2)
The same for me...the bubble disappears sooner or later. Increase the pump speed for 1-2 days if you want since it can help. Also open/close the reservoir to release any pressure that might have build up.
X299 - i9 7940X
(24 items)
i9-7940X
Asus Rampage VI Extreme
Asus Strix GTX 1080Ti OC
64GB Trident Z RGB
Samsung M.2 960Pro 512GB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Phanteks Asus Strix 1080Ti GPU Block
EK-XTOP Revo Dual D5 PWM
Bitspower Fittings
Heatkiller 200mm Reservoir
9X Corsair ML140 Pro Fans
Coolermaster Cosmos 2
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Logitech MX Master 2S
Mouse
Abaidor is offline
post #4 of 9 (permalink) Old 11-20-2018, 09:02 AM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Been there mono blocks have horrible flow
Could be blockage in the ek jet part of the block what fluid are you using not ek I hope it tends to clog blocks pretty quickly.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 9 (permalink) Old 11-20-2018, 09:13 AM
ThrashZone's Avatar
Hi,
I'll add show us the rest of the loop please
After i installed a mono block I had this
Worst was like yours and it was indeed a clogging mono block jet
But I have non adjustable D5 pumps which were full blast mostly no need to slow it down D5 are mostly silent
Name:	X299 current loop mono block-3 air bubbles.jpg
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 9 (permalink) Old 11-20-2018, 06:07 PM
Abaidor's Avatar
Rep: 2 (Unique: 2)
Hey Thrashzone, I had this too but it disappeared and never came back. In the beginning I run my two D5s at full speed kept releasing pressure from the reservoir. It helps that I was using soft tubes that you can squeeze and cause abrupt increases/decreases to the flow. Now that I am switching to hard tubing I won't have this luxury anymore.
Anyway, I remember reading about a lot of users having this issue with the monoblock but never troubled me for long. It took some time to disappear completely though (not 1-2 days). Another issue I had was oil coming off the o-rings inside the monoblock but I caught most of it while testing it with an inline filter before I connected it to the loop. Not harmful stuff anyway.
X299 - i9 7940X
(24 items)
i9-7940X
64GB Trident Z RGB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Bitspower Fittings
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Mouse
Abaidor is offline
post #7 of 9 (permalink) Old 11-20-2018, 06:20 PM
ThrashZone's Avatar
Hi,
All ek blocks or at least the evo and mono block have escape routes on the bottom I assume if clogged jets occure and flow will flow the least restrictive route yes along the bottom path thus leaving voids on the top part where the vrm route is.
Jack the pump to 5 and see if the bubble disappears.
On a good day and clear flow the top part should not have any bubbles except small micro bubbles and most.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #8 of 9 (permalink) Old 11-20-2018, 10:47 PM - Thread Starter
KIENAST's Avatar
Rep: 0
Hello , thanks all for yours answers. I got in touch with ekwb and they asked to put two drops of kitchen soap in the loop. It has not changed anything. I al indeed using ekwb fluid. The buble is not expandind , if I reduced it but schaking the tower a bit , the bubble comes back immediately. Annoying but I can live with it.thanks!
KIENAST is offline
post #9 of 9 (permalink) Old 11-21-2018, 01:52 PM
ThrashZone's Avatar
Hi,
Fibers in the ek fluid has clogged it in record time looks to me
Some thing to browse through
https://www.overclock.net/forum/1806...s-deal-ek.html
Original thread that not too far after ek quit ocn support lol review last page for the crickets from ek
https://www.overclock.net/forum/1806...-coolants.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
Tags
loop air bubble problem issue
