MSI RTX 2080Ti Sea Hawk EK High temps. - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 11-17-2018, 08:55 AM - Thread Starter
brunob10's Avatar
Rep: 0
I have a problem with high temps on my MSI RTX 2080Ti Sea Hawk EK (MSI card with pre-instaled EKWB watreblock on GPU). I have install all in new loop, with SE 280mm radiator and D5 pomp. Whole build with Polish comment you can find on yt:
Whole loop was connect outside of case, all parts was move around and "shaked", additional pipe for air to go out on top of res.
After 30 secend on Furemark I have 78 C on GPU. Radiator is going a little hot after 5 min, but with this temps on GPU it should be fire on Radiator.
Pump is going on max, is not connected to PWM conenctor.
It going to RMA, couse I cant remve block form card. Warranty sticker on one of four skrews near GPU, but ather 3 of them I could move almost with my fingers
Is it possible that MSI card form factor with block, and maybe they forget to remove sticker from block in factory
Thanks for any advice, it's my first open loop. Tomorrow will get GTX 1080 with proper working blok.
brunob10 is offline
post #2 of 11 (permalink) Old 11-17-2018, 09:20 AM
Overclocker in training
ThrashZone's Avatar
Rep: 31
Hi,
SE series isn't much of a radiator
PE series would be a little better but I'd look into a GTX 280 if you have the room for it in the case
Add another if you plan on add the cpu to the loop or larger if the case can handle a gtx 360.
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #3 of 11 (permalink) Old 11-17-2018, 09:29 AM - Thread Starter
brunob10's Avatar
Rep: 0
Sure, I'a going to add 9900k and then 420mm / 45mm and that allready used SE 280 will go on top of the case.
But now i Have only a card and still issue. This themp sould be lower, even without any fans on radiator.
On AiO 120mm with 2 fan, had 52-55 max(GTX 1080TI).
Config with 240 60mm -> 52:
brunob10 is offline
post #4 of 11 (permalink) Old 11-17-2018, 09:43 AM
GAN77's Avatar
Rep: 0
You have correctly assembled the contour.
78 degrees a lot. Apparently the problem is in the EK block.
GAN77 is offline
post #5 of 11 (permalink) Old 11-17-2018, 10:30 AM
nycgtr's Avatar
Rep: 91
https://www.youtube.com/watch?v=FWIzl3mc-6U
meh i have the bp founders and the bp strix. I don't go past 47c with 31c water temp when it was on a 240 v3 bench rad.
nycgtr is offline
post #6 of 11 (permalink) Old 11-19-2018, 06:52 AM
Nineball_Seraph's Avatar
Rep: 0
You said the block was pre-installed? i would remove the block and do a reinstall. It might have been installed improperly (improper thermal pad install, poor contact, etc).
Heatware: Nineball | TT Core X9 | [email protected] (1.26v) | MSI GTX 1080Ti FE 2101Mhz on stock BIOS | 16 G.Skill Trident RGB | Asus Hero Max X | 2 x EK MLC 360 Core with CPU and GPU block | Corsair AX1200i PSU
Nineball_Seraph is offline
post #7 of 11 (permalink) Old 11-19-2018, 07:33 AM
1689 Federalist
lightsout's Avatar
Rep: 239
Warranty sticker.
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
EVGA GTX 1080ti FTW3
GSkill 16gb 3200c14 Flare
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
LG 32GK650F-B 1440p 144hz
Mouse
Sensei Raw
Audio
Sony Core Bookshelves
lightsout is offline
post #8 of 11 (permalink) Old 11-19-2018, 11:23 AM - Thread Starter
brunob10's Avatar
Rep: 0
And funny part:
In box with card you can find EKWB thermal paste with screws to waterblock. But I Cant open this card because of card warranty sticker.
In normal waterblock you can clean water block after remove couple of screws from front of card to maintanance you waterblock maybe, after 1 years of usage. In MSI most of screws are under cover with dragon, so you have to send card for maintenance and they will install new block(?), its hard to remove whole sticker... maybe is other way to do this.
brunob10 is offline
post #9 of 11 (permalink) Old 11-20-2018, 07:36 AM
Rep: 0
Quote: Originally Posted by lightsout View Post
Warranty sticker.
My understanding (depending on the country you're in) a broken warrenty sticker doesn't mean a thing and you can't be denied a refund/RMA because of it. The company would have to prove that anything you did after breaking the sticker caused the issue. Most GPU companies would rather not have to deal with a bad PR situation either, especially if you properly documented your problems before removing the block.
If you dont want to go through all that, then an RMA is your best bet.
EDIT: sorry i, thought you were the OP.
post #10 of 11 (permalink) Old 01-23-2019, 10:34 AM
XTAC's Avatar
Rep: 11
Oh wow. I wish saw this a week ago. I am on MSI 2080 Ti EK X #2. Both are exactly the same way with GPU temp running way over coolant temp. A full water block GPU that hits 50C on the title screen in 20 seconds? I also found less than funny to see that little baggie of 1080 Ti screws and TIM and the same sticker on the back plate springs.
What did you end up doing? Did you ever get a card with decent block contact?
XTAC is offline
