EK-RES X3 - Multiport TOP with EK-XRES Revo D5 RGB PWM
Hello!
My system is made up exclusively of EK components, from blocks and radiators including the "EK-XRES 140 Revo D5 RGB PWM pump" in which I use the 400 "EK-RES X3 - TUBE 400 354mm ". In this pump I normally use the outlet and inlet located on the bottom of the pump / reservoir assembly. The question I need help with is the following. If I get "EK-RES X3 - Multiport TOP" and more "EK-RES X3 - Internal Tube 12/16 200mm" can I have the liquid inlet from my loop at the top of the reservoir? Will not I need to have anything connected in the lower entry labeled "INLET"? Thank you for your help.
AtilaEKWB
akira749
can you help me?
I thank the collaboration of all!
