EK ZMT TUBING EOL QUESTION? (time critical) - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 12-11-2018, 12:27 AM - Thread Starter
sdmf74's Avatar
Rep: 44 (Unique: 40)
Hello this question is for EK or anyone that may know for sure. It is time critical cause I intend on having my pc completely rebuilt and functioning by this evening, hopefully.
What is the difference between the EK ZMT end of life tubing here.
https://www.ekwb.com/shop/ek-tube-zm...16-10mm-retail
And the new EK ZMT tubing?
And more importantly is the old EOL tubing compatible with the new EK-AFC compression fittings???
I noticed that the new tubing size is stated as 15,9/9,5mm and the old is 10mm / 16mm. Are they really slightly different sizes and will that matter?
I also noticed that the old tubing says its compatible with the CSQ fittings but makes no mention of the AFC fittings.
I have the old tubing and will recieve all new AFC fittings today and want to make sure there will be no issues/leaks or anything before I get my pc all cleaned, refitted, pasted and filled.
Is anyone using the old tubing with the new fittings and if so has everything worked ok?
THANKS!
sdmf74 is offline
post #2 of 5 (permalink) Old 12-11-2018, 09:16 PM - Thread Starter
sdmf74's Avatar
Does EK still participate at overclock.net?
sdmf74 is offline
post #3 of 5 (permalink) Old 12-11-2018, 10:46 PM
Robotic Chemist
Asmodian's Avatar
Rep: 191 (Unique: 128)
Asmodian is offline
post #4 of 5 (permalink) Old 12-11-2018, 10:58 PM - Thread Starter
sdmf74's Avatar
Good to know thanks, I emailed EK but havent heard anything yet. Im actually in the middle of disassembling/cleaning my kingpin block right now the tubing is next.
sdmf74 is offline
post #5 of 5 (permalink) Old 12-18-2018, 08:50 AM
The Supremacy Block Cracked and killed a Mobo....
Jspinks020 is offline
