Multiple Card Question: Series or Parallel Flow? - Overclock.net - An Overclocking Community
Old 01-01-2019, 04:25 PM - Thread Starter
Bighouse
Well, I'm starting to narrow my decision on an upgrade for my graphics card down to two NVidia RTX2080ti FE cards. They're the most affordable from NVidia, from what I've seen. (I'm hoping they aren't somehow limited in function compared to third party cards made by others? Comments?) And I'll connect them to my EKWB CE 3x 140mm fan radiator system. According to the EKWB configuration tool, it's a good match for my system as was originally planned and built. (Couldn't have anticipated the RTX cards back then!) But, I don't know if it's better to use Parallel or Series waterflow for the cards. I know that if the header is large enough, water will flow equally into both cards. BUT, part of my brain thinks about the discharge ports on the cards and can't help but wonder how EVENLY the water will flow through each card, given the small header size at the entrance and exit to the ports on the waterblocks.
I'm running the D5 pump/reservoir.
So, which would be better? Parallel or Series?
EK-FC Terminal X2 3-slot - Plexi?
EK-FC Terminal X2 S 3-slot - Plexi?
BuildOne
(8 items)
Core i9-7900X
Thermaltake Core P5 - Tempered Glass - Black
Asus Prime X299-Deluxe
EVGA GTX 1080 FTW
G. Skill Trident Z RGB 3200
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Bighouse is online now
Old 01-01-2019, 04:47 PM
High Clocker
bmgjet is an unknown quantity at this point bmgjet is an unknown quantity at this point
bmgjet's Avatar
High flow rates and series is best since you know both cards got complete flow though them. But you run series with low flow rates then the 2nd card is going to get hotter water going into it then the first so will run hotter.
In that case parallel is better.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
Old 01-01-2019, 04:58 PM
woot
sli_shroom is on a distinguished road sli_shroom is on a distinguished road sli_shroom is on a distinguished road
here is some good info on the subject by toolmaker
https://www.overclock.net/forum/61-w...el-9-6lpm.html
i tried both the fk serial and parallel and saw about a 2 degree difference (better with the parallel) on average for the gpus. keep in mind this is with dual pumps, dual rads, and dual 1070 gtxs...so i am not really putting out alot of heat from the gpus
There are some things that smoke can come out of and still be good, for instance, a bong. Bad things for smoke to come out of, computer parts.
sli_shroom is offline
Old 01-02-2019, 04:54 PM - Thread Starter
Bighouse
Based on feedback from others, I've decided on running them in serial mode...should work out fine. Cards and EKWB parts all ordered! Now the waiting begins...
BuildOne
(8 items)
Core i9-7900X
EVGA GTX 1080 FTW
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Old 01-06-2019, 08:01 AM - Thread Starter
Bighouse
Looks like I may have even longer to wait.
Though I made my order with plenty of time for me to work this weekend on my rebuild, a thoughtful EKWB representative monitoring my order and responding to my question about the serial or parallel terminal, extended to me an offer to cancel my order and reorder to get the EKDelights discount. I checked and it would save me $40...not bad, but as I have limited weekends available to work on my rebuild, I REALLY needed to get it done this next weekend. So, I replied and told them I didn't want the discount IF it meant my order would be delayed...and alas, it seems the message won't be received until they return to work on Monday and the last message I received seemed to indicate they had canceled my order so that I could reorder with the discount. The $40 means little to me compared to the scarcity of my available time to work on this project. So, there's like zero chance I'll be able to work on my rebuild for weeks now, though the rest of my order from NVidia, will be here on three days. A month from now it won't matter a bit, but I sure was hoping to get things up and running before the new semester started.
Update: Received an email today from EKWB. Their representative who I've been working with managed to manually refund the EKDELIGHTS seasonal discount to my credit card- which is really nice- AND it also seems my shipping was upgraded! Though it's not in DHL's tracking system yet, their shipping estimates indicate that I should be receiving the package in two days and will be able to teardown and rebuild within my critical timeframe!
YEAH EKWB!
BuildOne
(8 items)
Core i9-7900X
EVGA GTX 1080 FTW
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Old 01-06-2019, 08:10 AM
Hardware Princess
Hydroplane Level 1
Hydroplane's Avatar
I do agree that series is the best... easier to run the plumbing and pretty much no performance difference from parallel. Even with a single pump the water moves through the system fast enough (and is cooled by the rads) that it barely has a chance to warm up much from the components. I can run my 7980XE up to 90C stress testing and my GPUs are still like 26C
CHILLER DESTRUCTION
Build Log - White Voodoo
White Voodoo
(14 items)
ThinkPad W520
(8 items)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
G.Skill Trident Z 32GB (4x8GB) DDR4-3200 CL14
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Core i7 2720QM @ 2.2 GHz
Quadro 1000M
8GB DDR3-1333
500GB 7200RPM
Optical Drive
DVD-RW
170W Brick
Operating System
Windows 7 Professional 64 bit
1920x1080 Matte 15.6"
Hydroplane is offline
Old 01-06-2019, 08:48 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Only thing I would do is prioritize the cpu first in the loop from the rad or pump.
7900x will be the hottest item I assure you and you'd want it cooled first before the gpu's
Examples of both
https://www.overclock.net/forum/61-w...l#post27776042
https://www.overclock.net/forum/61-w...l#post27774976
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is online now
Old 01-06-2019, 09:01 AM - Thread Starter
Bighouse
Yes. From my reservoir, it goes directly to the center of my CPU. From the out on my CPU, it'll go into the first card, then the second. I'm thinking of putting an inline temp sensor at the intake on the radiator to measure the temp of the water after it's been through the three devices, and one inside my reservoir to measure the cooler radiator water. The one at the top of my reservoir will serve as my air release gap when draining.
Something like this, but I wish the probe was longer to make sure it will hit the water in my reservoir (I like to keep a bit of air in my tube so I can see the water movement.) http://www.performance-pcs.com/bitsp...p-fitting.html
BuildOne
(8 items)
Core i9-7900X
EVGA GTX 1080 FTW
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Old 01-06-2019, 09:09 AM
ThrashZone's Avatar
Hi,
I'd just use a Y connection and put the sensor on it
http://www.performance-pcs.com/fitti...gle--y-angle/?
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
Old 01-06-2019, 10:03 AM
woot
another option...nothing additional required and it is guaranteed to be in the flow. been using one for years
http://www.performance-pcs.com/phoby...ck-nickel.html
