Future Upgrade-ability for Custom Loop - Overclock.net - An Overclocking Community
post #1 of 29 (permalink) Old 01-07-2019, 10:41 PM - Thread Starter
Atrus619
Hi!
I'm looking to build a new deep learning rig, and am interested in using an EK custom loop for this project. My rig is initially only going to have 1 gpu, but I plan on adding 1-2 additional gpus later on as needed (up to 3 total).
My question is, will the loop I have put together be "future-proof" to accommodate the additional 1-2 gpus I might add? Below is the link to the loop I was considering:'
https://www.ekwb.com/custom-loop-con...W5c31bb6b09746
Thanks, and let me know if you have any additional questions!
Atrus619 is offline
post #2 of 29 (permalink) Old 01-24-2019, 02:12 AM
jackmiller669
Please let me know the answer to the query if you found anything! I am also looking for something resemble with your query.
jackmiller669 is offline
post #3 of 29 (permalink) Old 02-02-2019, 03:29 PM
Ceadderman will become famous soon enough Ceadderman will become famous soon enough Ceadderman will become famous soon enough Ceadderman will become famous soon enough Ceadderman will become famous soon enough Ceadderman will become famous soon enough Ceadderman will become famous soon enough
Ceadderman's Avatar
Quote: Originally Posted by Atrus619 View Post
Hi!
If you intend to add up to two more GPU, make sure they are the same length pcb. Otherwise you may run into fitment issues. The connectors may not line up properly otherwise.
In the event you do get them you will need something to tie them together. So more fittings will be required.
A 560 Radiator will be more than enough to run your CPU and GPU blocks. Standard rule applies. One 120 per component + one 120 for overclocking. Two components + two overclocks.
~Ceadder
AMD Phenom II X6 1100T
Crosshair IV Formula
Sapphire Radeon HD 6870
Corsair Dominator
G. Skill Ripjaws X
G. Skill
x2 HITACHI 1TB Deskstars 1TB RAID0
Optical Drive
ASUS DRW-24B1ST
Corsair CMPSU HX 850w Modular
Swiftech Pump DDC-1T (2)
Liquid Fusion V Double helix Reservoir
Yate Loon 120x20 (D12SM-12C) Medium Speed Silent Fans
EK Supreme HF Classified
Swiftech 6950/6870 GPU Heatsink
Monsoon 1/2"x5/8" PETG White Hardline tubing.
Monsoon Economy Hardline fittings
EK Dual DDC V2 top
EK Thermosphere GPU Block
HAF 932
Operating System
Win7 64 bit Ultimate OEM
Asus VH222H Black HDMI Widescreen
Keyboard
Logitech the OCZ went buhbye adios. Don't know what I'm going to replace it with.
Mouse
Logitech g9x
Mouse
COOLER MASTER Weapon of Choice: M4 Duramesh Pad
Audio
Logitech X-240 2.1 speakers
Other
Creative X-Fi
Other
Sunbeam Rheosmart 3
Intel
Dell
XFX 5770 HD Radeon
GSkill Ripjaws
Seagate
Optical Drive
Dell
Dell 430w
Stock
Operating System
Windows 7 Home Professional?
HP
Keyboard
Dell
Ceadderman is offline
post #4 of 29 (permalink) Old 02-03-2019, 09:53 AM
JustinThyme Level 1
JustinThyme's Avatar
Generally speaking I never follow the 120 per component. If I did my rig would cook itself as there is no way ANY 120MM rad with the highest speed 120 push pull configuration can pull off the 500 watts an overclocked HEDT CPU or overclocked high end GPU (especially one doing computational work loads) dishes out. You really need to look at wattage as there is a huge diffference in cooling a 960 and a 2080Ti or Titan RTX.
There really is a reason the large cases with multiple radiators have a market. Im running a 9940X and 2 2080ti with 2x 480 rads and 1x 360 with 20 fans and considering adding another rad. In the summer I have to supplement ambient cooling.
Das Beast
(29 items)
I9 7900X
Asus Rampage VI Extreme
Asus Strix 1080 Ti OC
Corsair Dominator Platinum CMD64GX4M8X3800C19
Samsung 960 Pro
Samsung 850 EVO
Intel 900P
Corsair AX1500i
Aquaero 6 pro controller
Corsair SP120 PWM x 18
EKWB RVIE Monoblock
EKWB Xres 250
2x EKWB 1080 Ti Stix blocks and backs
EKWB FC SLI parallel triple
EKWB 480 XE
EKWB 480 PE
EKWB 280 CE
Corsair ML140 PWM 3
D5 pumps x2 in serial bitspower head with mod kit
Corsair Obsidian 900D
Operating System
WIN 10 Pro
ASUS PG34Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
Audio engine 192kBPS DAC
JustinThyme is offline
post #5 of 29 (permalink) Old 02-03-2019, 02:47 PM
Ceadderman's Avatar
Ummmmm... yeah. First of all even in a computational system he is still @ 1:1. A 560 is twice the cooling surface of a 420. Cooling nothing but CPU and GPU. At this time the rule applies to the task.
It's common sense that the loop should be expanded once cooling surface is maxed out by the additional hardware. Also since one cannot cool below ambient without a cooling source(AC or water chiller) it doesn't matter what you're cooling if you're pegged due to the "type" of hardware.
Unless of course you're mining with more than just the odd bit of cards. I run HEDT for the most part and will be running three 360s in a heavily modded HAF932. Trust me it really doesn't matter. Because heat is heat and the more heat you output in a closed environment heat builds up. HEDT or computational system, doesn't matter. For what he's tasking, 120+120 per component correctly applies. Only in this case scenario I guess we could change that to 140+140 per component. lol
Oh and these days with how Radiators have improved you no longer need to run Push/Pull as the mounting surface of most newer Rads have a 5mm gap of clearance off the cooling surface. Effectively creating a shroud. Atop that Fins per Inch have gone from the mid twenties to mid to upper teens, allowing better airflow. The latter being the main reason for P/P. With the higher fin counts of the older Radiators one needed to force the air through the dense cores of the Rads.
If you looked at the link, you saw his list of components compiled by the EK Configurator. That automatically applies the wattage necessary to the hardware compiled in the list. I used it for my soon to be built R7 1800x build and put a 360 XE in my current case. Of course I modded the case to allow for 2 more 360s which EK couldn't possibly know about. At this time I plan to use a PE unit in place of their rec'd XE and add two Vertical SE units up front. Giving me more cooling surface than the recommended amount the Configurator correctly listed based on my cased prior to mod. It's good but isn't perfect for every scenario.
~Ceadder
Corsair Dominator
G. Skill Ripjaws X
G. Skill
Optical Drive
ASUS DRW-24B1ST
EK Dual DDC V2 top
HAF 932
Operating System
Keyboard
Mouse
Logitech g9x
Mouse
Audio
Other
Creative X-Fi
Other
Sunbeam Rheosmart 3
Intel
Dell
XFX 5770 HD Radeon
GSkill Ripjaws
Seagate
Optical Drive
Dell
Dell 430w
Stock
Operating System
HP
Keyboard
Dell
post #6 of 29 (permalink) Old 02-04-2019, 06:14 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Not sure you got the right tubing for the 10-13mm fittings
I would also go 3/8-5/8 or 10-15mm fittings and tubing instead they are a lot better.
Also would switch to constraint instead of premixed cryofuel fewer issues, less weight for shipping too buy distilled water locally.
As far as color fluids go they stain everything get clear constraint you'll like it better
Not sure anything is future proof seeing at some point maybe the exact gpu or water block could go out of stock.
Single pump would be okay but adding more gpu's later could end up with a flow issue with 3 gpu's and cpu too
EK does have a nice dual pwm d5 pump well worth upgrading too with the single loop you have in mind to end up at.
Last be aware of ek rad design and possible flaws
https://www.overclock.net/forum/61-w...-rad-barb.html
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #7 of 29 (permalink) Old 02-04-2019, 10:24 PM
JustinThyme Level 1
~Ceadder
If you are looking at just cooling with liquid instead of air and don't want any subsequent temp drops to allow for OC or just longevity, its all good. If you want the temps down and the clocks up its not nearly enough. I just played a short round of the new shadow of the tomb raider using ray tracing at highest levels. 20 fans screaming full tilt to keep the loop in check. Has me considering chilled water. I was like what did I get myself into here. Cards stayed in the desired temp range not passing 45C loaded but loop temp crept up really fast. If I opened up to allow for a higher loop temp to keep the fan speeds down the component temp will go up losing the edge and putting me right back into the same boat as cooling with air. With the CPU loaded and GPUs not loaded fans will run at low speed no matter how hard I loaded up the CPU. A pair of 2080Tis loaded and CCPU not loaded takes no time at all get the liquid temp up and fans cranking. Im absolutely certain a 360MM rad following the 120 per component rule wouldn't keep one GPU under 45C let alone two and a CPU.
For the OP its not mentioned what GPU/S you intend on cooling, this can change things dramatically.
In the end I guess its what you want from it. Me I want the lower temps to allow me to squeeze out everything I can. If you just want to substitute water for air without high expectations the 120 or even 140 will be fine.
Das Beast
(29 items)
I9 7900X
Samsung 960 Pro
Samsung 850 EVO
Intel 900P
Corsair AX1500i
EKWB RVIE Monoblock
EKWB Xres 250
EKWB 480 XE
EKWB 480 PE
EKWB 280 CE
Corsair ML140 PWM 3
Operating System
WIN 10 Pro
ASUS PG34Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
post #8 of 29 (permalink) Old 02-05-2019, 02:07 PM
Ceadderman's Avatar
Bruh, dude is looking at a 560 not a 360. A 560 is a 4x140 Radiator. Plenty of cooling surface for the CPU and GPU setup, and should he add one more GPU should still perform well. If he gets 2 more? Well he could add another 140 and it wouldn't be a bad thing. I don't know what case otherwise I would be more specific with a recommendation for size.
That said the 120 per component rule is pretty much applied and surpassed in his list right now.
~Ceadder
Corsair Dominator
G. Skill Ripjaws X
G. Skill
Optical Drive
ASUS DRW-24B1ST
EK Dual DDC V2 top
HAF 932
Operating System
Keyboard
Mouse
Logitech g9x
Mouse
Audio
Other
Creative X-Fi
Other
Sunbeam Rheosmart 3
Intel
Dell
XFX 5770 HD Radeon
GSkill Ripjaws
Seagate
Optical Drive
Dell
Dell 430w
Stock
Operating System
HP
Keyboard
Dell
post #9 of 29 (permalink) Old 02-05-2019, 10:20 PM
JustinThyme Level 1
~Ceadder
Bruh, He said expandable so Id recommend more. Better to have it and not need it and have it and it run cool and quiet then need it and not have it then have to tear it down and do a rebuild. He said he is adding 1-2 cards later and will be doing heavy computational workloads. These cards are HOT!!! Like twice as hot as a 1080Ti. 3 cards with a slight OC will dump every bit of 1200 watts of heat and pull 450 watts of power each loaded.
One card, OK, Two cards and if you dont mind fans running full bore waking the neighbors and liquid temps over 40C and card temps into the realms of leaving it on air, OK, 3......forget it. I thought I had it covered with what I already listed in my build going well above the 120 per component rule. Boy was I wrong with 11x 120!
Case is listed in the link he provided which will hold a butt load more. Thermaltake The Tower 900. If I was doing the build Id put in x 560s and call it a day. Adds a little over $200 to the build where just another 140 will add just under $100.
Another recommendation to OP is make sure you get as much PSU as you can. My 1500 Watt Corsair AXI is moaning with a 9940X at 4.8 GHz and two 2080tis at 2.1GHz. For 3 cards you are going to need 2 PSUs
Im adding at least another 280 and maybe another 360 after that depending on what I see from the 280....on top of what I already have.
My recommendation stands based on experience with these cards and a huge case. Take what you like from it or disregard completely.
Das Beast
(29 items)
I9 7900X
Samsung 960 Pro
Samsung 850 EVO
Intel 900P
Corsair AX1500i
EKWB RVIE Monoblock
EKWB Xres 250
EKWB 480 XE
EKWB 480 PE
EKWB 280 CE
Corsair ML140 PWM 3
Operating System
WIN 10 Pro
ASUS PG34Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
post #10 of 29 (permalink) Old 02-05-2019, 10:46 PM
Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about Abaidor has a spectacular aura about
Abaidor's Avatar
Or get an external rad like a MO-RA3 420 Pro and enjoy efficiency at its max.....I am done with internal rads after trying the MO-RA. The fact that in most set-ups besides the first rad that gets fresh air (intake) secondary rads are cooled by "hot" air led me to dump this solution (internal rads) as "inefficient". My 9X140 Fans work at 400-450 rpms MAX cooling an overclocked 7940X and overclocked 1080Ti (2085 / 6100) without breaking a sweat with the MO-RA and 2X D5s running at 40% and up to 55%....
I know that external rads are not for everyone but there are ways to set them up nicely (the Stainless Steel Pro version of MO-RA looks great too) and get the best possible performance out of watercooling...
I am actually planning to add a second MO-RA3 420 in my loop and a 3rd D5 and I am sure that I will be running passive this way most of the time...
Just a thought.
X299 - i9 7940X
(24 items)
i9-7940X
Asus Strix GTX 1080Ti OC
64GB Trident Z RGB
Samsung M.2 960Pro 512GB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Phanteks Asus Strix 1080Ti GPU Block
EK-XTOP Revo Dual D5 PWM
Bitspower Fittings
Heatkiller 200mm Reservoir
9X Corsair ML140 Pro Fans
Coolermaster Cosmos 2
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Logitech MX Master 2S
Mouse
Abaidor is offline
