HELP! My EK-FC Terminal X2 S 3-slot needs longer screws! - Page 3 - Overclock.net - An Overclocking Community
post #21 of 25 (permalink) Old 02-21-2019, 07:41 AM
Shawnb99's Avatar
Rep: 14 (Unique: 10)
Was it not possible to buy replacement screws from Home Depot or something?
If you need a 23mm screw and all you can find are 25mm one truck is buying 2mm washers and using that with the screw.
That’s what I had to do to install their rads in push/pull.
Do they really use metric screws for these blocks and not the non metric kind? That makes no sense since the rads use the non metric kind. Be really stupid to us 2 different formats for screws.
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #22 of 25 (permalink) Old 02-21-2019, 08:17 AM - Thread Starter
Rep: 0
Shawnb, not possible in my case because I modified the decorative terminal covers for a flush reinstallation atop the plexiglass bridge. If the socket heads protruded proud of the face of the bridge due to washers, I won't be able to use a thin 3M double stick tissue thickness material to adhere my RGB terminal covers to the bridge.
My concern has always been that I have the correct length of screws. I'm an architect (and teacher) and not an engineer. But, I know that developed thread lengths are important for achieving the proper strength on connections. Not enough threads in contact with each other can have bad results resulting in broken threads because too much force on too small of a surface area can do damage.. Too long of a thread and you can damage the item it's being screwed into. I did not want to use a critical connection element without the proper specs coming from the equipment manufacturer's engineering team. I'm fine with hacking things that are not structural to an issue. But, if I damage the cooler block threads, or can't get sufficient contact pressure to provide an adequate watertight bond, then I'll have to live with the consequences of that. I have enough trouble and complexities in my life to deal with and don't need to stack "Gee, is my waterblock going to leak?" issue atop everything else!
The original spec in the bridge installation manual called for a M4x28 DIN 7984 screw. Checking with some precision calipers, I can see that the average internal length of the hole through the plexiglass bridge is 22.23mm. The low socket head thickness on the screw is 2.87mm. SO, if a 28mm screw includes the head (which is an odd way to list it, but that appears to be the way EKWB does it, not by the actual thread length) then a M4x28 screw SHOULD give me 25.13mm of thread. The internal length for the threaded portion of the screw on the bridge is 22.23mm on my bridge. That would give an internal thread connection distance inside the waterblock of 25.13 - 22.23 = 2.9mm (assuming full contact between surfaces). So, let's just call it 3mm of thread contact. When I measure the depth of usable threads inside the waterblock, I get a minimum value of 5.76mm and a maximum of 6.41mm. So, that leaves 2.75mm of extra space to ensure that the screws don't damage the waterblock.
Here's the odd part for me though. I received notice from EKWB that the screws they are now sending me are M4x27....that means I'll only get 2mm of threaded contact between the screws and the tapped holes in the waterblock. I hope 2mm of contact inside the Vector holes will be enough!
BuildOne
(8 items)
Core i9-7900X
Thermaltake Core P5 - Tempered Glass - Black
Asus Prime X299-Deluxe
EVGA GTX 1080 FTW
G. Skill Trident Z RGB 3200
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Bighouse is offline
post #23 of 25 (permalink) Old 02-21-2019, 09:53 PM
Rep: 0
I'm in the same boat. They said they will send me M4x27 screws too.... Hopefully, that will be sufficient.
UMUX is offline
post #24 of 25 (permalink) Old 02-23-2019, 05:41 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
We can send out any of our stock screws. Just shoot us a support ticket.
EKWB Forum Rep
EKJake is offline
post #25 of 25 (permalink) Old 04-16-2019, 02:22 AM
Ashcroft's Avatar
Rep: 80 (Unique: 63)
For anyone looking for metric machine screws / Hex bolts like the EKs use in the US try a hobby or radio control shop. Radio control cars use the same screws and should be stocked.
Outside the US of course we can get them just about anywhere.
For us it's the 6/32 screws that can be a pain to find.
Ashcroft is offline
