Custom Loop - Overclock.net - An Overclocking Community
Custom Loop
post #1 of 12 (permalink) Old 03-25-2019, 11:59 AM - Thread Starter
Rep: 0
Custom Loop
Hello. Will this configuration be compatible and is it a good choice?
Phanteks Enthoo Evolv X
Gigabyte Z390 Aorus Xtreme Waterforce
EK-CoolStream PE 360 (Triple)
EK-XRES 140 Revo D5 RGB PWM
3x EK-Vardar EVO 120ER Black BB
EK-ACF Fitting 12/16mm
EK-DuraClear 11,1/15,9mm 3M RETAIL
Zacharys is offline
post #2 of 12 (permalink) Old 03-25-2019, 12:17 PM
I can count to potato
Fluxmaven's Avatar
Rep: 27 (Unique: 11)
Just doing a CPU loop? If so, everything listed would be good to go. If you want to add a GPU to your loop and intend to overclock, you might want another radiator.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
Basic Geil 2133 4x2GB
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig C7
Maingear Shift
Fluxmaven is offline
post #3 of 12 (permalink) Old 03-25-2019, 12:45 PM
Alex132's Avatar
Rep: 342 (Unique: 274)
You wont be able to fit the res in-between the GPU and front radiator. The case is very tiny.
If you're okay with going horizontal res on the false floor, or just having a ceiling-only radiator then it should work just fine.
| This Cannot Continue | We Are Become As Gods | This Cannot Continue |
Vehicles:
Current: None.
Ex: '07 Fiat Palio, '07 Honda Accord Type-S
Illya
(26 items)
Yuki
(23 items)
Intel i9 9900K @ 5.2Ghz
Gigabyte Aorus Master
EVGA 1080 Ti FTW3
G.Skill Trident Z 32GB 4000Mhz
Samsung 970 Pro 512GB
Samsung 850 Evo 1TB
WD Red 8TB
Seasonic Prime Titanium 850W
EK Velocity CPU Block
EK 1080 Ti FTW3 GPU Block
HardwareLabs GTX420
HardwareLabs GTS280
HardwareLabs GTS140
EK D5 140 Glass Pump/res
Phanteks Evolv X
Operating System
Windows 10 Pro
Asus ROG Swift PG279Q 165Hz 1440p
I-INC 1920x1200 TN 27"
Keyboard
Ducky One 2 Midnight
Mouse
Logitech G502
Mousepad
CoolerMaster Swift-RX XL
Audio
Sennhesier HD650
Audio
Schiit Jotunheim Amp/DAC
Audio
Samson C01U Microphone
Audio
Edifier R1700BT
Other
Oculus Rift
Intel 2500K 5Ghz
ASUS P8P67 Pro
EVGA 1080 Ti FTW3
G.Skill RipJaws X 2133Mhz 16GB
120GB Corsair Neutron GTX
Samsung 850 Evo 1TB
WD Red 8TB
EVGA G3 850W
Hyper 212
EK Vardar fans
Corsair 270R w/TG mod
Operating System
Windows 10
I-Inc 1200p
Keyboard
Razer BlackWidow 2013
Mouse
Logitech G502 Proteus Spectrum
Mousepad
Audio
Sennheiser HD650
Audio
Schiit Jotunheim Balanced DAC + Amp
Audio
Edifier R1700BT Speakers
Audio
Other
Oculus Rift
Other
PS4 Controller
Alex132 is offline
post #4 of 12 (permalink) Old 03-26-2019, 06:55 AM - Thread Starter
Rep: 0
I intend to add a GPU loop and overclock the processor and place only one radiator on the top in the case.
Zacharys is offline
post #5 of 12 (permalink) Old 03-26-2019, 07:10 AM
skupples's Avatar
Rep: 579 (Unique: 324)
cases like that remind me why I wanna build my external radiator, pump, res combo box. Then you'd just QDC your tower of choice to your radiator tower
skupples is online now
post #6 of 12 (permalink) Old 03-26-2019, 08:21 AM
Fluxmaven's Avatar
Unless you want to run your fans on jet engine takeoff mode, doing all that on a single 360mm isn't going to work well depending on what CPU and GPU you are trying to cool.
I would go up to a larger case and run a 420mm up top if you really want to go single radiator.
One possible option:
http://www.phanteks.com/Enthoo-Pro-TemperedGlass.html
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
GTX 1080 FE
WD Black SN750
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Mouse
Glorious Model O
Mousepad
Audio
Audio
Focusrite 2i4 Gen2
Audio
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
WD Blue 3D m.2
Corsair AX760
InWin D-Frame Mini
i7 6700
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig C7
Maingear Shift
post #7 of 12 (permalink) Old 03-26-2019, 08:22 AM - Thread Starter
Rep: 0
So I have another question. Whether the EK-MLC Phoenix 360 fit on the top of the case with the hoses on the left and right?
Zacharys is offline
post #8 of 12 (permalink) Old 03-26-2019, 08:39 AM - Thread Starter
Rep: 0
I am not going to get the lowest possible temperatures...
Zacharys is offline
post #9 of 12 (permalink) Old 03-28-2019, 12:07 PM - Thread Starter
Rep: 0
Will someone help?
Zacharys is offline
post #10 of 12 (permalink) Old 03-28-2019, 12:27 PM
munternet's Avatar
Rep: 7 (Unique: 4)
I'm running 2x 360 radiators with Vardar fans with an overclocked 8700k 5.2GHz and a 1080Ti and I think that is a bout the minimum I can run when playing BFV on the extra hot summer days unless I want to crank the fans up a little in which case I could run a 360 and a 240. I have the EK-XRES 140 Revo D5 PWM running at 40-45%. Any faster and I can hear it. Not loud but it is right next to me and I don't think faster cools much better.
When water cooling a bigger case can be better especially when you want to reach into the case and change stuff without the pipes and pump getting in the way.
I am changing one of my radiators to a 420mm and fitting 140 furious varders to give even better cooling.
You could start with a single 420rad and 140mm fans and see how you go but either way my preference would be for a larger case.
When you hold a 140mm fan you realise how much more substantial it is than a 120mm fan
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Mouse
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
