EK Pump Issue - Need Help Please - Page 3 - Overclock.net - An Overclocking Community
post #21 of 31 (permalink) Old 09-16-2019, 07:21 PM
professional curmudgeon
looniam's Avatar
Rep: 791 (Unique: 451)
are there any mobos that have the cpu header NOT PWM by default?
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is online now
post #22 of 31 (permalink) Old 09-16-2019, 07:41 PM
skupples's Avatar
Rep: 549 (Unique: 312)
typically that's the one port that is ACTUALLY true PWM. I hear its gotten a lot better in the last few generations though.
My X79 RIVBE is covered in not actually PWM 4 pin headers.
Quote: Originally Posted by ThrashZone View Post
Hi,
Pumps on any channel fan port you'd need to switch it to pwm and then manual
Raise the minimum rpm line to 60% and straight line it to max.
That should get the pump rpm's to 3600rpm and work off temperature to max rmp at about 4800.
Pump ports are weird they just plop the rpm to max just like not having the pwm plug connected to the board at all just like when filling the loop.
Just note which fan port you use to monitor with hwinfo.
CPU port on the board should have fans hooked to it
Do not use a mother board AIO port for a D5 pump.
so the pump header intended for aio use? or are there actual "AIO" ports too?
I rarely use anything on my board, just a CPU header, and USB line to Aquaero
skupples is offline
post #23 of 31 (permalink) Old 09-16-2019, 07:49 PM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
I give the boards cpu port a couple fans just to keep it happy assist or cpu optional.
D5 I'd use a channel fan port and adjust it's manual rpm like I said for a minimum rpm at around 35-3600.
All other radiator.. fans I use a fan controller for.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #24 of 31 (permalink) Old 09-17-2019, 10:12 AM
Robotic Chemist
Asmodian's Avatar
Rep: 189 (Unique: 127)
It doesn't work with the pump completely unplugged from the motherboard... why does everyone keep suggestion messing with BIOS? How would the fan/pump header settings do anything if the pump is not plugged into it?!
When plugged into the motherboard the power supply does not provide power on the molex, this is not totally insane. When shorted none of the power lines are connected but when plugged into the motherboard all the 12V/5V/3V lines are connected. If there is a short or something it could drop the voltage on or even disable the molex connector. Not common and somewhat scary but it is not not insane. Try another power supply. With a voltmeter I would check the pins of the motherboard with the power supply connected to see if there is a voltage drop. I suspect a short somewhere related to the motherboard.
Asmodian is offline
post #25 of 31 (permalink) Old 09-17-2019, 10:22 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
EK D5 pumps have two connectors....the 4 pin molex connector has just 2 wires for 12V power. The 4 pin fan connector has two wires at pins 3 & 4. Pin 3 is RPM and pin 4 is PWM signal....not sure how you diagnose a PWM D5 pump, but plugging it to 12v molex only will power it up. It will default to a set RPM if there is no PWM signal, which is why I stated, it makes no sense that the pump works when the PSU 24 pin is jumped, but doesn’t when connected to the mobo, because once the PSU is on, there’s 12V to the molex connectors and everything on moles connectors is powered up.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #26 of 31 (permalink) Old 09-17-2019, 11:44 AM
Robotic Chemist
Asmodian's Avatar
Right.
1) The pump is only plugged into the 12V molex.
2) With the power supply unpluged from the motherboard (but jumped so it will turn on) the pump turns on.
3) With the power supply plugged into the motherboard the pump does not turn on.
Changing BIOS settings for fan headers is not going to help and we need to investigate the power supply and/or motherboard because the power supply should be providing 12V to the pump in both situations.
Asmodian is offline
post #27 of 31 (permalink) Old 09-17-2019, 11:48 AM
skupples's Avatar
agreed, assuming that the header he's using isn't off by default, then its not the BIOS. RPM/power would at least spin up the pump.
Are you 100% sure you fully clipped the 24 pin in, and all other motherboard power accessories?
as stated above, do you have an additional power supply, or motherboard to test with?
skupples is offline
post #28 of 31 (permalink) Old 09-17-2019, 12:08 PM
ezveedub's Avatar
All he has to do is a voltage drop on the molex connector when the PSU is on with. DVOM. I’ve only seen known good pumps not run when there’s 12v at the molex connector due to a backed out or poor pin connection at the molex connector itself. Unless something shorted out the 12v rail, I don’t see the pump being the only thing not working when on.
i9 9900K
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #29 of 31 (permalink) Old 09-17-2019, 01:46 PM
Robotic Chemist
Asmodian's Avatar
There is no header involved at all, why bring it up? The molex connector is from the power supply. Let's keep it simple.
Asmodian is offline
post #30 of 31 (permalink) Old 09-18-2019, 04:50 AM
ThrashZone's Avatar
Quote: Originally Posted by DFIRINTHEDARK View Post
I tried playing in the BIOS in regards to the fan headers. All show as not connected/undetected, regardless of where I plug it in. I just don't get why the pump will run fine with the PSU shorted, but as soon as I put the 24 pin connector from the PSU to the motherboard, pump will no longer power on with the system.
Hi,
Sounds like a mother board problem
As said trying another power supply would rule that out but about the only two items that can be the problem is psu or mobo.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
