Advice on possible pc - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 09-21-2016, 09:26 PM - Thread Starter
kutraz's Avatar
Rep: 0
ON ONE HAND WE HAVE
FX 6300
16gb ddr3 Ram
1TB + 120 SSD
GTX 1060 6gb
ON THE OTHER HAND
FX 8320
16gb ddr3 Ram
2TB
Radeon RX 480 4gb
LASTLY
Intel i5-6402p
8gb ddr4 Ram
1TB
RX 480 4gb
Which of these builds, allows me to play any game at 1080p and with max setting? Or gets me the closest to that?
kutraz is offline
post #2 of 4 (permalink) Old 09-22-2016, 04:07 AM
Rep: 38 (Unique: 21)
I'd go with the one with i5-6502p, which I believe is a Cyberpower Gamer Xtreme?
You should be able to max out most current games @1080p 60hz, with a few exceptions.
The GPU is not as good as the 6GB 1060, but the i5 is way faster than the FX6300, and better than the 8320 as well.
You shouldn't build a gaming PC around a FX6300 at this point.
But honestly, if you could go for a custom build with the i5 and a 6GB GTX1060, I'd like it even more.
renx is offline
post #3 of 4 (permalink) Old 09-22-2016, 01:04 PM - Thread Starter
kutraz's Avatar
Rep: 0
If i were to buy the Cyberpower Extreme what would be the smartest upgrade to do down the line?
Add a second 4gb 480 (I don't know if the computer allows for 2 cards)
or replace the 4gb with a 8gb
or replace with a GTX 1060 6gb
Or improve the CPU?
kutraz is offline
post #4 of 4 (permalink) Old 12-01-2016, 08:57 AM
Blessed to Serve
Bigceeloc's Avatar
Rep: 15 (Unique: 9)
Well, will you be staying with 1080p for a while? Or going to 4k sometime soon?
You will be more than able to find an affordable GTX 1070 on the used market in about a year or so.
The beginning of wisdom is this: Get wisdom. Though it cost all you have, get understanding. - Proverbs 4:7
Bigceeloc is offline
