Cheapest PC for what I need? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 09-24-2016, 02:26 AM - Thread Starter
Rep: 0
To cut a long story short I really need to get a desktop computer for study and music production. I've been stuck on a Atom netbook for the last several years and it makes EVERYTHING a living hell, trust me when I say I need to get a new PC ASAP.
But I'm not sure what my best options are. Basically what I need is a cheap desktop that
Has Windows 10
The ability to handle multiple programs and web pages with ease.
A video card that can output 1080P @60HZ though HDMI instead of DVI
And a sound card that can handle FL Studio with no problems.
I just need the bare minimum for that and I was wondering if there's a desktop on the market that fits all those requirements for the best price,
Mantis128 is offline
post #2 of 7 (permalink) Old 09-24-2016, 03:41 AM
Rep: 0
I have a couple of PCs I don't need so I was thinking about selling them. They are not the fastest, but they are tweaked for performance. I don't remember the particulars of the video situation and I don't know much about your sound card need (they both have sounds but I don't know if they are good enough). If you fill me in for more info on the sound card, I am sure I can make it happen for you. If you are interested, let me know. I will try to meet your budget. smile.gif
jyou is offline
post #3 of 7 (permalink) Old 09-24-2016, 04:38 AM
Fylzka's Avatar
Rep: 8 (Unique: 6)
Large FL Studio projects benefit from a decent CPU (i5/i7) and unless you want to use a multi-screen setup, the iGPU should be sufficient.
A SSD drive is always advisable for overall system performance and 16GB RAM would be good.
For music production you should get a ASIO/ASIO2 audio-interface. I don't know your exact needs and am also not well versed with them.
In the end It really depends on your budget and how complex your projects are.
I don't know if there are good price-performance All-in-One dekstops, because I never bothered with them.
That would be a good build you could consider if your budget allows it:
Intel Core i7-6700K CPU ~$340
Cooler Master Hyper 212 EVO CPU Cooler ~$30
Asus Z170-A Motherboard ~$150
2x8GB G.Skill TridentZ DDR4-3200 RAM ~$90
250GB Samsung 850 EVO SSD ~ $100
2TB WD Green Hard Drive ~$95
550W EVGA SuperNOVA G2 PSU ~$85
Corsair Carbide Series 200R Case ~$60
Microsoft Windows 10 Home 64-bit ~$100
ESI [email protected] XTe PCIe Audio Interface ~$240
Total: ~$1290
I know, that's far away from cheap, but it's future-proof for several years.
As I said, for the audio interface you should know what your needs are.
You could also read this buyers guide:
https://support.image-line.com/knowledgebase/base.php?ans=214
I hope the input helps!
Fylzka is offline
post #4 of 7 (permalink) Old 09-24-2016, 05:13 AM - Thread Starter
Rep: 0
Ah yes, I do want to build my own custom super PC that will last 10 years at some point but I do need to get a PC that can keep up with what I'm doing that will last at least a year ASAP since the the next year will be nothing but intense study and $1000+ is just too much.
For music, I probably won't be trying anything too advance at first anyway, the ability to have a basic melody, bass, drums and one or two things extra without the sound crackling or CPU slowing down would be enough.
Also thanks for the info.
post #5 of 7 (permalink) Old 09-24-2016, 11:22 AM
new to OCN?
PontiacGTX's Avatar
Rep: 1536 (Unique: 924)
you could tyr to get an used 4770k/4790k on a z87/z97 mobo or a i7 3930k/e5 1650 (v2) and x79 but if it is too expensive than eithe ran i7 2600k/3770k on z77/z68 or a FX 83xx on 970/990 chipset
PontiacGTX is offline
post #6 of 7 (permalink) Old 09-24-2016, 11:25 AM
Rep: 0
If you want, I can get you some thing of under $150 or under $250. The downside, the $150 one is a bit slower because it is 1st gen i5, and the $250 one is HP 3rd gen i5 so it is low profile (no room for a video card).
jyou is offline
post #7 of 7 (permalink) Old 10-07-2016, 07:38 AM - Thread Starter
Rep: 0
Ok thanks everyone, but it turns out my study isn't quite what I was expecting, so I guess I could hold of on getting a PC until I can get one that really goes the mile.
