Shipping a desktop with a bulky air cooler - good idea? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 12-01-2016, 11:41 AM
Blessed to Serve
Bigceeloc's Avatar
Rep: 15 (Unique: 9)
Originally Posted by Blameless View Post
Insurance, service departments, and enough volume to justify custom packaging...they can afford it.
You certainly are right about that. It seems like the OP is constrained to sending the pc fully assembled and is assuming there will be some risk. wink.gif
The beginning of wisdom is this: Get wisdom. Though it cost all you have, get understanding. - Proverbs 4:7
Bigceeloc is offline
post #12 of 17 (permalink) Old 12-01-2016, 10:54 PM
Iconoclast
Blameless's Avatar
Rep: 3135 (Unique: 1869)
Well, you do what you've got to do.
I'd personally try to put an AIO cooler on the CPU and have the recipient install the GPU if at all possible, but if that's not possible, there has been plenty of solid advice about how to pack the system.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #13 of 17 (permalink) Old 12-02-2016, 01:32 PM - Thread Starter
Justiceinacan's Avatar
Rep: 1 (Unique: 1)
Thanks for the tips, old thread and it was already shipped before many replies came in but I'm happy to report it arrived safe.
Justiceinacan is offline
post #14 of 17 (permalink) Old 12-02-2016, 01:40 PM
Mr.4way SLI
Moparman's Avatar
Rep: 193 (Unique: 173)
Last time I shipped a desktop I had to pack the inside with Foam that they had to remove. If you don't pack it well where the cooler is supported and the GPU for that matter I will bet it ends up DOA from how the boxes are treated during shipping. I always label my boxes Glass when they are computers that are together.
Moparman is offline
post #15 of 17 (permalink) Old 12-02-2016, 01:58 PM
Blessed to Serve
Bigceeloc's Avatar
Rep: 15 (Unique: 9)
Nice, so how did you do it? Let's have some closure on this thread. smile.gif
post #16 of 17 (permalink) Old 12-02-2016, 06:53 PM
Vario's Avatar
Rep: 45 (Unique: 38)
Glad it worked out. One thing that can be done in the future for this type of thing is to use foam or stacked cardboard and carve it out to fit around your components inside the case.
CPU: Intel Core i5 8600K // Motherboard: ASRock Z370 Taichi // Ram: G.Skill TridentZ 3200 CL14 // GPU: Zotac GTX 1060 6GB Mini // SSD: Seagate 600 240GB // HDD: WD 1TB Blue WD10EZEX // Case: Lian Li PC A05 NB // Heatsinks: PH-TC14PE // Fans: 2xCorsair SP120L, 2xThermalright TY143, 1xYate Loon D14BH-12 PWM https://valid.x86.fr/29fsdx
Vario is offline
post #17 of 17 (permalink) Old 12-04-2016, 08:38 AM - Thread Starter
Rep: 1 (Unique: 1)
I kept the case in it's own box, and kept the styrofoam bits it came with
Surrounded that box with fillers, ya know
Put a big box around that
I basically took your advice (but from someone else) and filled the inner bits with packing materials too. A RAM stick came loose but it was straightforward enough for him to re-install it.
