HELP, need to decide fast! Alienware Area 51 TR vs Custom Built? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 45 (permalink) Old 12-21-2017, 12:18 PM - Thread Starter
pser's Avatar
Rep: 0
You are right, here are the specs:
Area 51 R3
Processor
AMD Ryzen™ Threadripper 1950X (16-Core, 40MB Cache, Overclocked up to 3.6GHz on all cores)
Operating System
Windows 10 Pro 64-bit English
Chassis Options
Alienware™ 850 Watt Multi-GPU Approved Power Supply with modular cabling [80 Plus Bronze Efficiency]
Video Card
NVIDIA® GeForce® GTX 1080 Ti with 11GB GDDR5X
Memory
32GB Dual Channel DDR4 at 2666MHz; up to 64GB (additional memory sold separately)
512GB M.2 PCIe SSD (Boot) + 2TB 7200RPM SATA 6Gb/s (Storage)
Optical Drive
Slot-Loading Dual-Layer DVD Burner (DVD±RW)
Wireless
Killer 1535 802.11ac 2x2 WiFi and Bluetooth 4.2
pser is offline
post #12 of 45 (permalink) Old 12-21-2017, 12:21 PM
Linux Lobbyist
SavantStrike's Avatar
Rep: 97 (Unique: 66)
Originally Posted by pser View Post
Thanks for the insights, all valid points.
Two things to consider though: you still need to take care of the issue by yourself and waste time on the shipping side, which in case of a business is a deal breaker. Also, the warranty on the parts is usually 1 year (maybe 2 at most?). With Dell I'm getting 4 years warranty, on the support
and
the parts.
Now a rather important question. The PSU on the Alienware is 850w and the computer can mount up to 3 video cards, which made me think I should go with a higher PSU. The strange thing is that adding one more card to the configuration doesn't give me any warning about the PSU, so it goes with the 850w. I called Dell and they confirmed the PSU is enough. Isn't that strange? I knew with two video cards I would need at least 1000w.
Two 1080 TIs with a 1950x would fit inside 850W at stock clocks, but I wouldn't recommend it for a workstation.
SavantStrike is offline
post #13 of 45 (permalink) Old 12-21-2017, 12:25 PM - Thread Starter
pser's Avatar
Rep: 0
Mh... That's the thing, I thought I would need a higher PSU.
pser is offline
post #14 of 45 (permalink) Old 12-21-2017, 01:21 PM
Linux Lobbyist
I just wouldn't trust them to put a quality unit in, so add 20 percent to what you need so it's not being thrashed during long work sessions.
post #15 of 45 (permalink) Old 12-21-2017, 01:52 PM - Thread Starter
pser's Avatar
Rep: 0
Totally, but that's the annoying part: I can't upgrade the PSU which is dumb, especially because I remember the video from hot hardware with a bigger PSU unit.
pser is offline
post #16 of 45 (permalink) Old 12-21-2017, 03:17 PM
Zer0CoolX's Avatar
Rep: 52 (Unique: 43)
"Cinema 4D + X-Particles + Arnold, Blender 3D, Adobe CC, Affinity Photo & Designer, Blackmagic DaVinci Resolve & Fusion, 3Ds Max"
Wouldnt these apps benefit from a workstation class GPU vs a gaming GPU?
Have you looked at any workstation PC's with similar specs? I did a quick search and it does appear most use Intel CPU's though you may be able to find AMD TR based ones if you search for them. You may consider a custom built one from any of the many vendors who make custom builds (I know you could do it yourself for less, but again the extra money is for warranty/support).
I mention this as workstation GPU's like quadro offer the added benefit of drivers tailored to give the best results using software like you are using. Thats why they are usually more expensive for what seems like (and is) often less hardware.
Zer0CoolX is offline
post #17 of 45 (permalink) Old 12-21-2017, 04:59 PM
mumford's Avatar
Rep: 7 (Unique: 6)
850w is enough with no overclocking. I imagine the Dell bios may not even allow you to overclock. However, TR runs best with Ram overclocks and runs at 3200 mhz.
mumford is offline
post #18 of 45 (permalink) Old 12-21-2017, 05:12 PM - Thread Starter
pser's Avatar
Rep: 0
Thanks for the info, mumford.
Compared to the specs I posted above, how much would you say is the difference with the overclock you mentioned? 10, 20% faster?
pser is offline
post #19 of 45 (permalink) Old 12-21-2017, 05:25 PM
mumford's Avatar
Rep: 7 (Unique: 6)
mumford is offline
post #20 of 45 (permalink) Old 12-21-2017, 05:38 PM - Thread Starter
pser's Avatar
Rep: 0
Doing some research, it seems alienware tr comes already overclocked.
pser is offline
