Upgrading a pre-built HP Z220, need options! - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 12-30-2017, 12:08 PM - Thread Starter
1Kaz's Avatar
Rep: 9 (Unique: 9)
I'm looking to upgrade a pre-built HP Z220. It has 8 gigs of ram and an i7 3770 processor, but the graphics are very lacking. In addition to that, the power supply is also very small. I'm accustomed to building systems with a large tower, and this has a very small case, not the typical width of a larger tower. What power supplies and graphics cards are available for such small cases? Target budget is ~$200, any recommendations would be greatly appreciated!
1Kaz is offline
post #2 of 8 (permalink) Old 12-30-2017, 11:40 PM
Ahnt's Avatar
Rep: 62 (Unique: 48)
I'm not sure if it's the SFF or CMT, but either way I would recommend this. Leave the PSU alone. It should be enough for what you need, and not only that, the motherboard has an 8 pin connector instead of the 24 pin. It's a dell proprietary thing.
For the GPU. I would go with a 1050Ti SFF. Link HERE. There are a couple different ones on newegg, ranging from $159.99 to $210.07.
That card will fit, and doesn't require a power connector. Other than that, get you an additional 2x4 kit of ram and your set.
Ahnt is offline
post #3 of 8 (permalink) Old 12-31-2017, 08:01 AM - Thread Starter
1Kaz's Avatar
Rep: 9 (Unique: 9)
Thanks for the input on a low profile graphics card. I'm afraid the power supply still won't hold up. The specs sheet recommends 300w power supply for that graphics card, and I believe the pre-built one has the bare minimum of 90w.
Edit: Looking at this guy as a possible PSU:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151113&ignorebbr=1
1Kaz is offline
post #4 of 8 (permalink) Old 12-31-2017, 08:16 AM
GroinShooter's Avatar
Rep: 4 (Unique: 4)
Well which model is it, the SFF or CMT? Both have different PSUs.
SFF has a 240W PSU and the CMF has a 400W PSU.
Anyway, that suggested 1050 Ti will work fine on either of those. The recommendations are just guidelines to follow, not hard facts.
GroinShooter is offline
post #5 of 8 (permalink) Old 12-31-2017, 08:22 AM - Thread Starter
1Kaz's Avatar
Rep: 9 (Unique: 9)
I will check again on the PSU, have to go over to my neighbors to view it.
1Kaz is offline
post #6 of 8 (permalink) Old 12-31-2017, 09:34 AM - Thread Starter
1Kaz's Avatar
Rep: 9 (Unique: 9)
It's an SFF, 240 W power supply. I'd be inclined to try the 1050ti on a 240 w, but I'd like to have a backup option just in case. I'd hate to order the guy a new graphics card, then say your SOL it doesn't work.
The power supply I linked seems to a bit too large. The dimensions of the old one are 2 1/4" height, 5 1/4" length, 5" width. Is there any particular term I can search for when looking at power supplies to know that they fit a small footprint?
1Kaz is offline
post #7 of 8 (permalink) Old 12-31-2017, 02:11 PM
Ahnt's Avatar
From the HP spec sheet, it looks like a 240W 90% efficiency. Me personally, I would run it. If your super concerned, you can grab one of these HERE and get a compatible PSU. I'm not sure on the physical size of the PSU however.
Ahnt is offline
post #8 of 8 (permalink) Old 01-01-2018, 03:21 AM
Rep: 4 (Unique: 4)
Yeah I wouldn't be worried about the PSU, it should be just fine.
I looked around a bit but I can't find any quality PSUs to fit in those size dimensions. That SFF model has a small form factor PSU but most if not all aftermarket SFF PSUs have a height of 2.5 inches.
