Please suggest PC parts for my Lighting and Rendering build - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 10-06-2019, 09:10 AM - Thread Starter
Rep: 0
Hi all,
Hi, I'm going to built a PC from scratch for my work of Lighting & Rendering. Basically my budget is kind of tight. so can you please suggest me if there are any changes needed in the configuration i am planning to build . is there anything where i can reduce or change or save on.
Budget Range: Around/Below 100K to 130K Indian Rupees.
# System Usage from Most to Least Important: Animation(Lighting and Rendering), GPU rendering, Gaming, Browsing, Sometimes overnight rendering( yes only sometime).
# Software usage: I will be using Software like Maya (Most), Unreal engine, Substance Painter, Adobe Photoshop & Aftereffects, Foundry Nuke & Katana and Renderers like Arnold, Vray, Renderman, Redshift etc.
# Preferred Website(s) for Parts: I am buying from Local brick and mortar shops , but yes was checking the pricing and comparison on these sites. https://www.amazon.in , https://in.pcpartpicker.com , https://www.primeabgb.com , https://mdcomputers.in
# Location: Mumbai, Maharashtra, India
# Parts Preferences: Not really, but i am opting for Intel over AMD for long term goal.
# Overclocking: Maybe, But not for CPU
Your Monitor Resolution: 1920x1080, atleast 100% sRGB,HDMI, DVI ports, 24inches.
Additional Comments: This is my final configuration unless you guys recommend something else . will upgrade the following maybe after 6-8 months
RAM - may be upgrade to 32 GB
Secondary storage - will add another couple of TBs
# Operating system: Windows 10 64 bit, Linux - CentOS (might install after few months usage of PC)
# List of Parts i have selected :
** CPU - Intel Core i7 9700K 3.6 Ghz
https://mdcomputers.in/intel-core-i7...84i79700k.html
Motherboard -These 3 i select budget wise but that Gigabyte Aorus is pushing my budget still included review
MSI Z390-A PRO or any other suggestions.
https://mdcomputers.in/msi-z390-a-pro.html
Gigabyte Z390 AORUS ELITE
https://www.primeabgb.com/online-pri...t-motherboard/
** GPU - Galax GeForce RTX 2070 Super EX (1-Click OC) 8GB GDDR6
https://www.primeabgb.com/online-pri...-27isl6mdu9ex/
** PSU - Antec EARTHWATTS GOLD PRO 650
https://in.pcpartpicker.com/product/...ply-ea650g-pro
** RAM - Corsair (8 x2 )16 GB Vengeance LPX DDR4 3600 Mhz
https://mdcomputers.in/corsair-venge...2b3600c18.html
** CPU Cooler - COOLER MASTER MASTERLIQUID ML240L RGB or any other suggestion
https://mdcomputers.in/cooler-master...-a20pc-r1.html
** Primary storage - 250-512 GB M.2 / SSD, Please suggest any other. ( brand and price also)
* Intel 512GB 660P NVMe M.2
https://www.primeabgb.com/online-pri...dpeknw512g8x1/
** Secondary storage - WD or Seagate 1TB HDD
https://mdcomputers.in/seagate-1tb-b...1000dm010.html
Case - Antec Dark Avenger DA601 RGB (E-ATX) Mid Tower
https://www.primeabgb.com/online-pri...d-glass-panel/
Thermaltake V200 RGB Tempered Glass Black Mid Tower Cabinet or any other suggestion
https://www.primeabgb.com/online-pri...1k8-00m1wn-01/
**Monitor - These are the few i have selected; You can suggest good and budget monitor.
* Dell U2415
https://www.primeabgb.com/online-pri...n-lcd-monitor/
* Dell S2418H
https://www.primeabgb.com/online-pri...c-ips-monitor/
* LG 24MP59G
https://mdcomputers.in/lg-24-inch-rg...g-24mp59g.html
* Benq GW2480
https://mdcomputers.in/benq-23-8-inc...or-gw2480.html
* HP24F
https://mdcomputers.in/hp-24f-3al28aa.html
Thanks for Your comments, Eagerly waiting for your reply.
koncord9 is offline
post #2 of 2 (permalink) Old 12-02-2019, 10:37 PM
ᕕ( ᐛ )ᕗ
neurotix's Avatar
Rep: 306 (Unique: 181)
Hey,
If you are doing rendering work, why are you going Intel? Are you working or gaming?
No one is recommending or building Intel right now, for the same price as that 9700k you could get a Ryzen 3700X assuming there is stock in your country and the prices aren't inflated etc. This chip is 7nm, nearly as fast in gaming and single thread performance, and will smoke the i7 in Blender, Maya, and everything else you do for work due to it being 8 core/16 thread (that i7 is only 8 core/8 thread).
If you can live with a 2060 Super instead of 2070 Super, or possibly go for an AMD Radeon 5700, you could take the money saved on GPU and possibly afford a 3900x which is 12 core/24 thread and will destroy render workloads and seriously outperform anything Intel offers that is not HEDT.
Everything else looks great, you made some good choices. I'd suggest not getting the Intel 660 SSD simply because it's basically a terrible cacheless drive from everything I've seen- a better bet would be one of the new PCI-E 4.0 SSDs if you go AMD, or simply a cheap Samsung 970 Evo.
Out of all those 1080p monitors I'd pick the LG or the BenQ but the LG is better, response time is lower, and it's an IPS. It depends on what games you play. If online gaming/competitive definitely go for the LG, given that that 1ms response time (take this with a grain of salt- things like the scaler in it, USB polling rates, interrupt latency, DPC latency, ping time etc. pretty much guarantee some small amount (10ms or so) input delay no matter what but modern games compensate for this anyway- the only way to have literally no lag, at least in single player, is a CRT ) should be better for competitive FPS play, and so on.
You might consider going with a cheaper Ultrawide display, you can get non-curved ones at lower resolution here for sub $200 now (15k rupee or so) that are 2560x1080 and even have HDR. If you play lots of single player offline games, this would be great, but the reason I recommend it is it is MUCH MUCH better for video editing and should be better for rendering too. If video editing, you will see much more of your timeline.
Hope this helps. Regards from America.
Big Red build log
[Official] OCN Retro - The Overclock.net Retrogaming Club
Current console collection: NES, SNES, PC Engine Core Grafx (recapped), Master System, Genesis, Sega CD(model 1 recapped and model 2), 32X (x2), Saturn (x2), Dreamcast (x2), Game Gear, (x2) Game Boy Color, Game Boy Advance SP, PS2 (FMCB), Xbox (softmodded), PSP-1000 (6.60 PRO-C3), PSP Go (6.60 PRO-C3), PS Vita 1000 (HENKaku 3.60), 3DS, PS3 Slim, Xbox 360 Slim, Wii (letterbomb'd), Wii U, original 2017 Switch.
Big Red 2020
(35 items)
Big Blue?
(14 items)
Green
(12 items)
Ryzen 9 3900X @ 4.4GHz CCD0 1.36v VID, 4.2GHz CCD1- 1900Mhz fclk/uclk
ASUS ROG Crosshair VIII Hero BIOS 1105
EVGA GTX 1080ti FTW3 2025/5940MHz
EVGA RGB SLI HB Bridge
G.SKILL Flare X B-Die 3200 C14 @ 3800MHz C16-16-10-16-30-48 1T 1.42v GDM off
Samsung 970 Evo 500GB m.2 2280 PCI-E NVMe SSD
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Samsung 840 Evo SATA 256GB
Optical Drive
Lite-On DVD-RW
COOLERMASTER V1000 (Seasonic 1000w 80+ Gold)
Corsair H100i V2 (plastidipped red tubing)
Arctic Bionix F120 red (radiator), Bionix F140 red (rear), Bionix P140 3k RPM (front)
Prolimatech PK-3 Nano 30g tube
G.skill OG DDR3 Memory Cooler, white LED
Corsair red LED 140mm fan, blowing on board socket + VRMs from behind
Corsair 780T w/ custom red paint
Operating System
Debian Linux 10
Operating System
Win10 X64 Pro 1903 (gaming only), stripped down, updates blocked, Firewalled.
LG 34WN80C 34" 3440x1440 21:9 IPS, 300 nit, HDR
Keyboard
Ducky One 2 RGB PKT MX Reds
Keyboard
OCN Ducky DK1008 MX Blues
Keyboard
Corsair K70 Lux red led/MX Reds
Mouse
Redragon Chroma M710 RGB (Omron Switches)
Mousepad
Corsair Polaris RGB
Audio
Logitech G230 red
Audio
Logitech Z2300 2.1 120w 8" sub, w/ 40w satellites
Other
Phanteks RGB 5050/Digital RGB strips
Other
Custom acrylic PSU shroud "Big Red" (black w/ red led logo, v1tech)
Other
Custom acrylic drive cage shroud "[email protected]" (black w/ red logo. Clockwerkindustries)
Other
Thermaltake TTmod combed red/black cable extensions
Other
"Republic of Gamers", "EVGA" case badges.
Other
Merax Red/Black Racing Chair
i5-7600k 5GHz 1.32v
ASUS ROG Z270H Strix
Sapphire R9 380X Nitro 1200/1500mhz
G.skill Ripjaws4 DDR4-3000 CAS15
Western Digital Caviar Blue 320gb
Samsung 850 Evo 256gb
OCZ ModXStream Pro 500w
Corsair H60/PK-3
Thermaltake Core V71
Operating System
Win10 Home
2x ASUS V236H 1080p
Keyboard
Corsair K70 Lux Blue LED Cherry MX Blue
Mouse
Cooler Master
Mouse
Thermaltake GAMMA
FX-8350 stock
ASUS ROG Crosshair V Formula
Sapphire R5 230
G.skill TridentX DDR3 2400mhz
WD Caviar Blue
Optical Drive
Lite On DVD-RW
OCZ ModXStream Pro 500W
Cooler Master TX3
Corsair SP120 Exhaust
Corsair C70
Operating System
Win7 Ultimate X64
ASUS V236H 1080p 23"
neurotix is offline
