[Complete] Red Alert SR1 - Chopped CM Storm Scout with 360 top radiator - Page 3 - Overclock.net - An Overclocking Community
post #21 of 73 (permalink) Old 07-19-2011, 07:29 PM - Thread Starter
Retired Staff
Shadow_Foxx's Avatar
Rep: 76 (Unique: 58)
Large last ditch update before I go to Cali for the weekend! Did some major work, cut the top off, mounted the shroud, put the fans in, lookin pretty sexy if I do say so myself biggrin.gif
Beginning the cut with the jigsaw:
Most of the cutting done, but the mesh does not work well with the jigsaw, so we were forced to dremel those parts out. It takes a little longer but ends up being just as good!
Here is the hole in all its glory! The white paper is to catch a lot of the dust so I dont have to worry as much about cleaning out the case when Im done.
The shroud slides right under the handle like a champ!
Ooo FANS:
Yes I realize the fans are upside down. It was a brainless mistake thumb.gif
You can see the hole extends farther than the shroud, this is to accomodate the USB/power/reset etc cables from the front panel of the scout. Since we covered up the old hole with the shroud, we had to make sure there was some place for the cables to go:
Anyway, that is all for now, another major step id say. Soon I will put everything back together and mount the fans right to finally see how she looks! Thanks for looking! Comments/Suggestions/ subscriptions welcomed wink.gif
Shadow_Foxx is offline
post #22 of 73 (permalink) Old 07-19-2011, 08:09 PM - Thread Starter
Retired Staff
Originally Posted by smoket4279`;14218636
Just found this....member B_Negative put a 360 up top https://www.overclock.net/computer-cases/525009-official-coolermaster-storm-scout-club-2258.html
Bigfatwilly put a 240 in bottom https://www.overclock.net/case-mod-work-logs/823121-cm-storm-spectre-complete.html
mr charles's build https://www.overclock.net/case-mod-work-logs/758141-cm-scout-seal-edition.html
I found all to be very good reading and alot of good info I thought I would share
Thanks for giving me the links mate, I will definitely check those out. Its too bad B NEGATIVE beat me to the punch tongue.gif. Storm Scout Club seems like a pretty cool place with lots of helpful tips! I posted a pic of this mod there to maybe get some suggestions, keep checkin in! biggrin.gif
post #23 of 73 (permalink) Old 07-20-2011, 01:31 AM
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
You wont regret it....
careful what rad thickness you go for,you only have about 30mm clearance to your ram slots if you go internal.
B NEGATIVE is offline
post #24 of 73 (permalink) Old 07-20-2011, 11:40 AM
smoket4279`'s Avatar
Rep: 7 (Unique: 5)
Have you desided what radiator your gonna be using yet? and the results are looking awsome
smoket4279` is offline
post #25 of 73 (permalink) Old 07-27-2011, 05:04 PM - Thread Starter
Retired Staff
Yea, the one bad thing about an build like this, cant use a very thick rad...
My choices have really narrowed down, seeing as how the thickness has to be very low. There is a magicool and also a swiftech I believe that fit the bill, we shall see soon! Thanks for the interest!
post #26 of 73 (permalink) Old 07-27-2011, 05:32 PM - Thread Starter
Retired Staff
Back from Cali-forn-i-a!! I now present you PICTURES!!
Some Pics with the radiator shroud and fans installed:
Ooh sexy rezzz: (RP450X2) (Now discontinued) Fan controller is Lamptron FC6, highly recommended. Able to change the screen color, I chose red of course
Time for another teardown, I need to cut some more of the cable management clips on the top of the case in order to get the rad to sit flat on top, I will need every mm I can get
Cutting update to come in a day or two, also putting in some noise canceling foam, more for the looks though. If it actually dampens any noise, its a plus
post #27 of 73 (permalink) Old 08-01-2011, 06:12 PM - Thread Starter
Retired Staff
Well, we are one step closer to the watercooling, all the parts for that part should be here within the week!!
First, some more dremel work! I will cut some more holes in various parts of the case to accomodate the large amount of cables from the fan controller, pump, switches, etc. I want to route them all out of sight, as you can imagine. For this reason, all the front panel cables will all be routed this way as well, not through the hole on the back panel, where they are routed when you first get the case:
I also had to cut the cables management clips at the top of the case, as it will allow the radiator to mount flatly to the top of the case, creating more clearance between the rad and the mobo, and also preventing damage and scratching to the rad:
Mmmm, Storm Scout powder....
Mounting the foam liner to make things look cleaner and mayber help with noise a little?
Another unfortunate turn of events, is that I need to cut off the top of the back panel, so the radiator can fit. The further back I push the radiator, the more of the fans are exposed, as hopefully the better the cooling. This is the reason I didnt just move the shroud up further toward the front of the case.:
Once I put everything back together, this is the monster of wires I had to deal with. That is what you get when you put all these LEDs, switches and fan controls in a mid tower I guess... I literally had to use my weight to get the back panel on again.
Here is the pic of the front of the case, sorry for the bad lighting... Once again, the res is a Koolance RP 450X2, the fan controller is a Lamptron FC6, and the switchplate is the performance pcs, along with some Red LED switches. The switches will be wired to the red LED strip, the UV LED strip, the LEDs in the res, and two other things I have yet to decide on Looks like I used all the drive bays
Terrible view of the front, but I wanted you all to understand that the front doesnt look the same as the back
Night Shotsss, they will be much better once the tubing and everything comes in. Cant wait! I promise I will get a decent camera for the final pics
mmmmm RED
Hopefully you like . The real part I am looking forward to is getting all this hardware under water so she can really glow. Thanks for following
post #28 of 73 (permalink) Old 08-02-2011, 05:03 PM - Thread Starter
Retired Staff
List of Watercooling parts coming in the mail:
1 xKoolance PMP-450 High-flow Pump$76.99
2 xKoolance QDC (High Flow) No-Spill Shutoff, Male $23.98
1 xEK-Supreme HF High Flow - "Easy Mount" - Copper/Acetal $72.95
2 xBitspower G 1/4" Matte Black Rotary 90 Degree IG 1/4" Adapter$25.90
2 xKoolance QDC (High Flow) No-Spill Shutoff, Female Threaded$21.98
6 xBitspower G1/4 Matte Black Dual Rotary 45-Degree Compression Fitting-ID 3/8" OD 5/8"$95.70
1 xBitspower BP-MBWP-C60 G1/4" Matte Black IG1/4" Extender - 15mm$5.49
1 x*** NEW *** EK-FC6970 for AMD/ATI Radeon HD 6970 Series - Acetal $99.95
1 xDanger Den Red UV DreamFlex All-in-One "Retail Pack" - 3/8" ID Tubing$29.95
Sub-Total:$Too Much
United Parcel Service (Ground):$Way too much
Total:$A lot more than planned
post #29 of 73 (permalink) Old 08-02-2011, 07:22 PM
FS19 Addict
Rick Arter's Avatar
Rep: 350 (Unique: 310)
Nice work think this is first time I have seen a rad mounted like that in this case.
Rick Arter is offline
post #30 of 73 (permalink) Old 08-04-2011, 10:31 AM - Thread Starter
Retired Staff
Thanks mate! Im glad it all worked out, it was the first time I had done a mod without a specific step by step tutorial. I think it turned out alright, thanks for checking in!
EDIT: Parts should be on my doorstep when I get home!!!
