800D how hard is it to drop the lower tray? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 09-08-2011, 03:46 PM - Thread Starter
saer's Avatar
Rep: 66 (Unique: 58)
I really want to pick one up for water cooling my setup. Problem is that the stock config won't accommodate my EVGA 4-Way mobo, I have seen some people fit it in by dropping the lower tray a bit.
How exactly is the lower tray connected ? What would I need to do this ?
saer is offline
post #2 of 4 (permalink) Old 09-08-2011, 04:17 PM
andrewmchugh's Avatar
Rep: 626 (Unique: 493)
screws and rivets to get it out, not sure on remount, you might have to use L brackets.
Graduate of Computer Science (Game Engineering) - Newcastle University
andrewmchugh is offline
post #3 of 4 (permalink) Old 09-08-2011, 04:20 PM
WeAreMad! (yup, I'm back)
wermad's Avatar
Rep: 905 (Unique: 620)
A bit tricky to remove the front part where the hot-swap bay attaches but the rest are rivets you can just drill out.
Btw, I would consider the Xigmatek Elysium, it supports a 360 or a 420mm rad on top and XL-ATX mb like your 4-way.
That's the sr2^^^ *not my build
"Rock Bottom Became The Solid Foundation On Which I Rebuilt My Life" J.K Rowling
Mont Blanc 2.0
(9 items)
Intel i7 6700K @ 4.5
Gigabyte GA-Z170X-Gaming G1
G.skill Ripjaws 4 16GB (4x4GB) 2400
EVGA 1300G2
Corsair H105
Thermaltake View 71 (diy Snow Edition)
Operating System
Windows 10 Home
Keyboard
Razor Deathstalker Chroma
Mouse
Razor Deathadder Chroma Elite
wermad is offline
post #4 of 4 (permalink) Old 09-08-2011, 08:41 PM - Thread Starter
saer's Avatar
saer is offline
