[Build Log] REVIVED - Double Dragon Case Mod-White and Red Cube w/ 720 Rad space and Custom Reservoir - Overclock.net - An Overclocking Community
View Poll Results: What color scheme should I use, Black and Red OR White and Red?? (Renders located under 'Updated Ren
Black and Red with White accents 6 75.00%
White and Red with Black accents 2 25.00%
Voters: 8. You may not vote on this poll
post #1 of 128 (permalink) Old 10-05-2011, 09:30 AM - Thread Starter
Dalchi Frusche's Avatar
Rep: 18 (Unique: 18)
UPDATED 9/3/15
Hey all,
Sorry about the time lapse. Time to revive this build log.
Now that school is done and found a comfortable steady income, time to start collecting materials to begin working on the case. Bear with me as it might take a while to get everything constructed. I'll be fitting in work in between diaper changes of our new baby due Aug 29th 2015.
So.... this will be a build that will take a long time to complete(just warning everyone now) redface.gif Just wanted to get some input while in the beginning stages of the build.
PARTS LIST
P - Pending
O - Ordered
H - Have
MAIN COMPONENTS
  • MSI Z87-GD65 Gaming ATX Extreme OC - P
  • CORSAIR Vengeance Pro 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 - P
  • Corsair RM Series 850 Watt ATX/EPS 80PLUS Gold - P
  • Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive - P
  • Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive - P
COOLING
  • Swiftech Apogee XL PPCS Custom Dragon II - P
  • Corsair AF120s Twin Pack Quiet Edition(x2) - P
!!! A huge thanks goes out to @Osco for donating the below bitspower fittings to the build!
  • Monsoon Chain Gun Compression Fitting - 3/8"ID x 5/8"OD – Red - Quantity: 2 - H
  • Bitspower G1/4 Male to Female Extender - 30mm - Matte Black - Quantity: 4 - H
  • Bitspower G1/4" D-Plug Male / Male Coupler Set - Bold Red - Quantity: 1 - H
  • Bitspower SLI / Crossfire Multi-Link Adapter Pair - Deep Bold Red - Quantity: 2 pairs - H
  • Rigid PrimoChill Ghost Compression 3/8in. ID x 1/2in. OD Fitting – Knurled Grip – Anodized Black - Quantity: 1 - H
  • Bitspower Quick-Disconnect Male w/ Inner G1/4 - Matte Black - Quantity: 1 - H
  • Bitspower SLI / Crossfire Crystal Link Tube Set - H
  • Phobya Fan Shroud 120mm Black x6 - H
  • Phobya Y- Cable 3 pin to 6 3 pin splitter (black) - H
  • Phobya Y- Cable 3 pin to 6 3 pin splitter (red) - H
  • Phobya Y- Cable 3 pin to 4 3 pin splitter (red) - H
  • Phobya Angled clip 90° for 19/13mm tubing (black) - H
  • PrimoChill flex tubing x ~6ft (Clear) - H
  • PrimoChill flex tubing x ~9ft (Black) - H
MISC. MOD SUPPLIES
  • Black Gutless Paracord - H (Night Shark Leftovers)
  • Red Gutless Paracord - P
  • White Gutless Paracord - P
  • Several feet of sleeving (black) - H
  • ~24" of rubber trim (black) - H
  • 20 LED Station/ molex power - H
  • 24" LED (red) x2 - H
  • 24" LED (white) - H
  • 12" 8 pin Extension (black) - H
  • 18" 8 pin Extension (black) - H
  • 24" 24 pin Extension (black) - H
  • 12" 8 pin to 2x 4 pin Extension (black/red) - H
  • 12" SATA cables (red) x3 - H
  • 500mm 180 SATA cables (black) x2 - H
  • 500mm 90 SATA cables (black) x2 - H
TO DO
  • Take cases apart down to the bones - Complete
  • Design custom reservoir and send to 3D printer
  • Trim case #2(white) to match height of case #1(grey) - Complete
  • Rework motherboard plate to provide management holes Next in Line
  • Cut and redesign frame to allow for bottom and rear fans - Complete
  • Flip back panel in reverse ATX style - Complete
  • Price Acrylic vs Aluminum for new back cover, top panel, front cover
  • Order panel material - Complete
  • Craft top panel
  • Craft back cover - Complete
  • Craft front cover - Complete
  • Craft cable routing covers - Complete
  • Paint
  • Order any remaining components
  • Test components for bad pieces
  • Install watercooling components
  • Test fit components
  • Install asthetics(fan covers, fan controller)
  • Install main components
  • Redesign waterloop(if needed)
  • Install loop
  • Leak test loop
  • Finalize build
  • Post final pictures and celebrate!!
UPDATES - Most Recent First
-Attached is the concept sketch I did. Let me know what you think. Sorry about the horrible quality.(Am at school between classes and took the picture with my crackberry)redface.gif Colors will probably be Red/Black/White although the white is not set in stone yet. rolleyes.gif
-- No longer applicable--
-Below is the double loop I plan on doing for the watercooling. Please let me know if there might be a more efficient way.
First Loop: Pump -> CPU -> NB -> RAM-> 240 RAD -> RES
Second Loop: Pump -> SB -> GPU -> GPU -> 240 RAD - > RES
Loop Planned as RES -> Pump -> Rad -> Rad -> CPU -> GPU - RES
Dalchi Frusche is offline
post #2 of 128 (permalink) Old 10-06-2011, 03:31 AM
Liighthead's Avatar
Rep: 69 (Unique: 59)
nice drawing tongue.gif subbin in to see how it goe s
Liighthead is offline
post #3 of 128 (permalink) Old 10-06-2011, 05:50 AM
0gre's Avatar
Rep: 2 (Unique: 2)
Subbing! classroom doodles FTW!
0gre is offline
post #4 of 128 (permalink) Old 10-06-2011, 05:54 AM
Timlander's Avatar
Rep: 214 (Unique: 173)
My only suggestion is make sure both of those dual rads are double thickness ones so you get better cooling performance. Should be fine. Looks interesting. biggrin.gif
meh.. paint damage cause no brain doesn't concentrated hurts my paint I have in the past....
Timlander is offline
post #5 of 128 (permalink) Old 10-06-2011, 05:59 AM
Bit_reaper's Avatar
Rep: 439 (Unique: 336)
280? As in 2x140 rads? I wonder if they make thous in double thickness. Subbed biggrin.gif
The XFX 4890 post 2 year reference cooler fan bearing service
NZXT Tempest Community
[Worklog] NZXT Tempest eats a 360 rad (hopefully)
you under-estimate the power of e-peen, you'll whither and waiver to it's power, and finally succumb.
Bow to e-peen and buy.
Bit_reaper is offline
post #6 of 128 (permalink) Old 10-06-2011, 06:04 AM
Badwrench's Avatar
Rep: 165 (Unique: 143)
If this is double dragon as in the game, I would add some yellow somewhere in the build to complete the look.
images?q=tbn:ANd9GcRTx1vCh-kuxKmZeXWyRYKb97N1KQ6xZJWBS7CYdY_bl0saEzx2FQ
These won't deliver the wub wub wub wubs or the wobble ehehehe wub wub *drop* bump bump wub of dubstep. It's a lie.
[/CENTER]
Badwrench is offline
post #7 of 128 (permalink) Old 10-06-2011, 06:15 AM
lambecrikas's Avatar
Rep: 20 (Unique: 19)
Informatics Engineering PhD researcher
High Performance Computing
Computer Graphics
CPU/GPU Architectures
Clubs and stuff... (Click to show)
lambecrikas is offline
post #8 of 128 (permalink) Old 10-06-2011, 06:43 AM
Timlander's Avatar
Ya I played that game sooo much in the 90's. So much! lol
post #9 of 128 (permalink) Old 10-06-2011, 06:52 AM - Thread Starter
Thanks tongue.gif mind you they are very very rough sketches.
Was thinking about doing the push-pull method.... would you still recommend the double thickness?
Sorry I meant 240 RADS not sure how I got that mixed up.
Originally Posted by lambecrikas;15199494
The perspectives are fine on paper.... not sure why my phone skewed the pics. Will get a proper scan once I have internet again at the house.
post #10 of 128 (permalink) Old 10-06-2011, 08:33 AM
Timlander's Avatar
Well if you are doing push and pull then double thickness would be even better. It will provide much lower load temps. Wont really help idle temps too much. But load temps are what really matter anyways.
