Project KAPROS - IKEA Galant PC Desk Mod!!! - Overclock.net - An Overclocking Community
post #1 of 637 (permalink) Old 01-16-2012, 02:42 AM - Thread Starter
Kaxtos's Avatar
Rep: 76 (Unique: 57)
LATEST UPDATE
Haven't Added the Leds on the Plexi Glass so you cant really see the SandBlasting in the Dark.. should be done by the weekend.....
PS..All lights can be turned on/off by the Pilot switches
Quick pic from my phone, with the wall mounts :
Forgot to mention.......
The Lighting you see above in the red circles was custom made with Electricians pipes ..... made holes with drill and painted black.
Older PIcs
Hi all,
I got inspired by many talented users that inserted their PC in their Desk so i came up with the easiest and most fisible one that i could do, trust me its much harder than it looks. I have posted another post about a month ago with another idea i had but it was much much harder, impossible to do so i came up with the below idea that i have already started.
IKEA GALANT BEFORE:
IKEA GALANT AFTER:
A few parts that have arrived yesterday:
3x Spectre Pro Led 230mm
Buttons for Power on/off ect and red cable sleeving
Touch Monitor
LOG PICTURES:
DAY1
Old case i had, using it to mount the Motherboard on.
Case after cutting it to pieces , Motherboard Mounting , DVD-ROM Cases, Touch screen Case
Cut the first circle for the Fans
Cutting a mold to get the curve of the desk, so not to make a mistake while cutting the actual MDF wood.
Bottom desk part plus part of the top
FEW CHANGES 23/1/2012
Change 1: Add the bellow Hot Swap Trays were i added the red circle on the picture
2x 3.5 HDD
2x 2.5 SSD HDD
Change 2: the Left side corner was going to be done by wood, but changed it to plexi glass
DAY 2
Making the holes for Motherboard, PSU, DVD-ROM, Touch Screen and Hotswap HDDs
It may seem that not much work was done on day 2 but there was lots of measurements that took lots of time and precise cutting.
Will work on it in the afternoon again, should be able to upload a complete picture of the desk by tonight (not painted of course and no plexi glass) but you will be able to get an idea of what the desk will look like when complete
DAY 3
Assembling parts of the desk, still lots of pieced not completed.
Checking if fans fit in desk (Lol i would like to hope so after all that work )
Cutting the Wood were the buttons , DVD-ROMs, Touch Screen and HDD Hot swaps are going to be inserted.
Going to rest for a few days, maybe ill work on it in the weekend but don't know yet
DAY 4
Fitting all the stuff on front panel. (Misplaced two buttons so it missing two buttons )
Setting up the desk for a millionth time, trying to get everything straight
Carving the MDF wood so we can fit the Plexi Glass
Placing the plexi glass in the MDF Wood, the protective sticker is still on the Plexi Glass that's why it looks fuzzy
Last picture taken before finishing
I still got to sand all the desk down, Primer it and start painting. Should be done in a couple of days..
SANDING
Managed to complete the sanding of the desk , but had no time to start primer
One of my main concerns was access to the inside of the desk if i needed to fix something..so as you can see in the picture below i screwed some pieces of wood in certain areas, holding the top part of desk so it cant move out of place.
Bought the primer, but had no time to start ..maybe tomorrow if am lucky
DAY 5 (PRIMER)
So i managed to finish the primer today...
Next to come ....
Sand down the Primer so its ready for paint
and hopefully finish the paint this week.... and start putting everything in the desk...
DAY 6...SANDING PRIMER
Finished the Sanding today, hope i can start painting tomorrow if the weather is good because my paint is polyurethane paint and shouldn't paint if there is humidity,, and guess what ? for the last week the weather is crazy no day of sun .
If the weather is good tomorrow and i have the chance to paint i will upload pics
DAY 7 PAINTING PART 1
So the Weather was GOOD and managed to paint the one side of the desk ...going to paint the other side tomorrow morning..
If all goes well i should have the desk in my room by Sunday....will take pics with DSLR for good quality image because all the pics till now were taken from my phone.
SETTING UP THE DESK IN MY ROOM
Will update more pics ,, its just that i promised would update last night some pictures but was too tired ....
Will update pics where i sleeved all that mess of cables
Some quick pics from my phone
Some other pics....
Haven't finished yet still need to do many things yet,,but here are 2 pics i just took..hope you like
Sand Blasting on Plexi_Glass
Modding is a way of life...why buy something when you can just do it
Kaxtos is offline
post #3 of 637 (permalink) Old 01-16-2012, 04:01 AM
Rep: 160 (Unique: 131)
I love the idea thumb.gif and the wife loves IKEA.
Subbed as well.
ginger_nuts is offline
post #4 of 637 (permalink) Old 01-16-2012, 04:10 AM
amigo092's Avatar
Rep: 17 (Unique: 14)
amigo092 is offline
post #5 of 637 (permalink) Old 01-16-2012, 04:19 AM
Jimbags's Avatar
Rep: 83 (Unique: 73)
looks bloody awesome suBBBBBBBBB D, cant wait for some nice pics biggrin.gif
Jimbags is offline
post #6 of 637 (permalink) Old 01-16-2012, 04:21 AM
Retired Staff
derickwm's Avatar
Rep: 379 (Unique: 291)
derickwm is offline
post #7 of 637 (permalink) Old 01-16-2012, 04:23 AM
Retired Staff
pioneerisloud's Avatar
Rep: 1388 (Unique: 956)
You know, while you're in there, you could mod a car stereo head unit in there. Pair that up with an 8ohm amp for power, and some nice bookshelf speakers sitting beside those monitors. smile.gif Maybe a powered sub too, and let the car stereo handle all of it (using your PC as input mind you).
Retro Rig
(17 items)
Core 2 Quad Q9550 @ 3.4GHz, 1.15v BSEL Modded
HP DC 7900 Series
MSI GTX750Ti Low Profile
4x2GB Samsung DDR2-800
Intel 330 120GB
2x 500GB WD Black 2.5" RAID0
Optical Drive
Samsung DVDRW
Lite On 240w Bridged Rails
Stock HP DC7900 Intel
HP DC7900 Slim Tower
Operating System
Windows XP Professional SP3 x86
Operating System
Kubuntu 18.04 x64
Dell 2007FP
Keyboard
Razer Chroma
Mouse
Logitech G602
Audio
Dayton DTA-120
Audio
Micca MB42x
pioneerisloud is offline
post #8 of 637 (permalink) Old 01-16-2012, 04:32 AM
Jimbags's Avatar
this is an awesome idea smile.gif gonna do a full desk build one day when i can afford it smile.gif
Jimbags is offline
post #9 of 637 (permalink) Old 01-16-2012, 04:39 AM
superj1977's Avatar
Rep: 213 (Unique: 185)
superj1977 is offline
post #10 of 637 (permalink) Old 01-16-2012, 04:40 AM
chrisguitar's Avatar
Rep: 40 (Unique: 37)
Subbed, so want to see this.
Project Azure
OCN rule number 1: Every thread eventually devolves into an AMD vs Nvidia or Intel vs. AMD one.
chrisguitar is offline
