[Project] 1N5P1R3 - FT02 Inspired by the modding community (Final Touches 99% Complete) - Page 16 - Overclock.net - An Overclocking Community
post #151 of 156 (permalink) Old 12-31-2013, 08:33 PM - Thread Starter
S1L3N7D3A7H's Avatar
Rep: 36 (Unique: 25)
PSU Mod complete. Everything is now practically dead silent. Just a small noise coming from my Corsair SP 120 QE which is being replaced soon and some very subtle noise from the HDDs. My pumps are almost dead silent running at 1200RPM; they only speed up to around 1800RPM under heavy loads, even then they are very quiet.
After I replace the top 120mm with the NF-F12 I will be finishing my 5.25 cover mods. I need to get some sound isolating foam to keep the noise from my HDD cage down (the thin aluminium of the covers wont dampen this noise).
S1L3N7D3A7H is offline
post #152 of 156 (permalink) Old 12-31-2013, 10:15 PM
JockThatCamel's Avatar
Rep: 2 (Unique: 2)
Looking good!
JockThatCamel is offline
post #153 of 156 (permalink) Old 01-02-2014, 08:29 PM - Thread Starter
Got my NF-F12 in today. Almost forgot how amazing the top cover is on the FT-02 :DDDDD
post #154 of 156 (permalink) Old 01-02-2014, 08:41 PM - Thread Starter
So I decided I would finish up my 5.25 bay covers today.
I found some medium density foam that came as a protective casing to one of my tools. Its about a half inch thick, cut it to fit nice and snug in the empty bay area and cut out a small area for the pump to fit through. The foam is to help dampen hard disk noise and also serve as a form of pressure mount for the bay covers. All I did for the bay covers was cut the brackets to half an inch on both sides, filed them nice and smooth, and pressed them in between the 5.25 bay and the foam. For the very bottom bay cover; I filled the cavity with some quarter inch 3M felt stripping that I packed nice and tight in there. This is so to help dampen any noise from my pumps coming through the cutout I made.
Whelp, I would say I'm now 99% done with this project. All I have left to do is expand the window to show off all my hard work, and to make a cover plate to smooth out the hot swap bay I made.
On a side note: I really need a camera and tripod to take some real pictures. Phone cameras only go so far......
I will probably also be upgrading graphics cards this year after Maxwell comes out. I will probably go SLI and upgrade my monitors to G-Sync capable ones.
post #155 of 156 (permalink) Old 02-13-2014, 03:47 AM
Anabaric's Avatar
Rep: 0
Anabaric is offline
post #156 of 156 (permalink) Old 03-11-2017, 11:09 AM - Thread Starter
Whelp, It is time to start upgrading this baby. Its been a few years, and RYZEN is looking really sweet right now.
I'll be keeping the GTX680 in there until I see performance of the flagship Vega chip vs the 1080ti.
I'll be wanting to do some benchmarks to compare the performance of my 4.5GHz 3930k to the RYZEN after I have achieved a stable OC.
Any benchmark requests?
I haven't found any VULKAN tests I can run without spending money. I'll probably just post Cinebench, Cobra HEVC Decode, HWBOT x265, and Time Spy.
Here is a link to my post for this over on the AMD section:
https://www.overclock.net/t/1625289/1n5p1r3-project-ryzen
