[Project] 1N5P1R3 - FT02 Inspired by the modding community (Final Touches 99% Complete) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 156 (permalink) Old 08-04-2012, 01:20 PM - Thread Starter
S1L3N7D3A7H's Avatar
Rep: 36 (Unique: 25)
Yeah, I'm going to use a single pull. Just have to do something about the color of the shroud.
S1L3N7D3A7H is offline
post #22 of 156 (permalink) Old 08-04-2012, 04:01 PM - Thread Starter
Doing some painting.
post #23 of 156 (permalink) Old 08-04-2012, 04:14 PM - Thread Starter
post #24 of 156 (permalink) Old 08-04-2012, 04:52 PM - Thread Starter
post #25 of 156 (permalink) Old 08-04-2012, 09:49 PM - Thread Starter
I have to make a custom bracket for the HDD bay and make it level.
post #26 of 156 (permalink) Old 08-05-2012, 01:09 AM
Gomi's Avatar
Rep: 78 (Unique: 62)
wheee.gifwheee.gifstun.gif Phase Change Owners Club stun.gifwheee.gifwheee.gif
Gomi is offline
post #27 of 156 (permalink) Old 08-05-2012, 06:42 AM - Thread Starter
Had problems with sliding in the bottom radiator with the brackets on. So, I'm going to cut the guide slots teeth off the middle brackets but leave the outers alone to secure the radiator to the case.
I also discovered I need to cut some slots to have access to the SATA connectors on the back 5.25" panel. I will probably drill some holes in the bottom and top of the HDD cage for airflow, if that doesn’t look too great, I'll cut slots out.
I got to figure out a good way to mount this thing securely without causing vibration. I also need to find a way to mount the 5.25" bay covers since the previous mounting solution is out of the question with all the cutting. I can probably add some aluminum bracing and tap some 6-32 threaded holes.
Any suggestions are greatly appreciated.
post #28 of 156 (permalink) Old 08-06-2012, 02:24 PM - Thread Starter
Found a good method to mount my hot swap. Using some mountain mods hdd holders. 4cae8ebd-35dc-bc7c.jpg4cae8ebd-35e5-fc51.jpg4cae8ebd-35f4-854c.jpg
post #29 of 156 (permalink) Old 08-06-2012, 10:24 PM - Thread Starter
Got the rad installed with brackets for test fitting.
post #30 of 156 (permalink) Old 08-06-2012, 11:15 PM
Gomi's Avatar
Looking good mate!
Gomi is offline
