PC Crimping Part Numbers - Page 19 - Overclock.net - An Overclocking Community
post #181 of 467 (permalink) Old 04-30-2015, 07:08 AM
mandrix's Avatar
Rep: 170 (Unique: 116)
Originally Posted by critters View Post
FYI there are white molex connectors for Seasonic PSUs ooops sorry, they're natural (ivory I think)
Big difference between them, color wise. I have ordered Molex connectors that were listed as ivory, that were sort of an off-white. Others were what I would call white.
There are now more places stocking white connectors for SeaSonic. But when I assembled all mine, my main source was modDIY in Hong Kong, where I got the 24, 18, 12 & 10 pin connectors. wink.gif This after getting the "off white" connectors that were listed as being made by Molex.
Maximus VIII Hero/6700K delidded w/CLP @ 4.8/Corsair LPX 4x4GB 2666 OC'd @ 3200/PCS 390X w/EK blockMain Rig specs (Click to show)
White Case Labs SM8 w/dual pedestals-Custom top extension
Rigid acrylic tubing/Dual D5's-MCP35x2
3x480mm-1x240mm Radiators
All psu wiring & sleeving by myself
2xAquaero 5 Pro's w/c - 1xFC8 for light panel & various led's
PowerColor PCS 390X w/EK block
6700K/Maximus VIII Hero/Corsair 4x4GB RAM
Build Logs (Click to show)Validations (Click to show)
mandrix is offline
post #182 of 467 (permalink) Old 04-30-2015, 09:48 PM
Rep: 20 (Unique: 17)
350 Malibu is offline
post #183 of 467 (permalink) Old 05-01-2015, 06:43 AM
8.2 liters
WiSK's Avatar
Rep: 553 (Unique: 361)
Originally Posted by 350 Malibu View Post
Connectors are made of smooth nylon, you need a specialised primer. Sanding roughly helps.
White Plastidip is an easy alternative because it sticks well to nylon.
WiSK is offline
post #184 of 467 (permalink) Old 05-02-2015, 05:14 AM
mandrix's Avatar
I actually tried painting some connectors and I wasn't totally satisfied. But in the end, I found all white connectors for my SeaSonic...but I'm pretty sure they weren't all made by Molex.
The problem with Molex "Ivory" is that they aren't always a nice white color. Or at least specifically one I still have in my toolbox, which is a 12 pin connector that is almost a very light tan color.
I did paint some mini Tamiya connectors that I use for 12v/ground to my pumps with Krylon for plastics that turned out OK.
mandrix is offline
post #185 of 467 (permalink) Old 02-09-2016, 07:04 AM
goofyhsk's Avatar
Rep: 2 (Unique: 1)
In regards to the cables.hillsidekonnection.com stuff in the original post - I can re-upload those pages if needed; probably not with the sub-domain any more though
goofyhsk is offline
post #186 of 467 (permalink) Old 02-18-2016, 08:17 AM
Daggi's Avatar
Rep: 9 (Unique: 9)
Don't know if it's of any help, but i found this page to a company that makes the same Receptacle Housing that is on my Corsair AXi 760, 860 1200 and HX 1050, the only thing I couldn't find is the 8 pin PCI-e receptable
WST - WELI SHENG TERMINAL INDUSTRIAL CO.,LTD
Daggi is offline
post #188 of 467 (permalink) Old 04-23-2017, 09:23 AM
Taking a break
iamjanco's Avatar
Rep: 145 (Unique: 66)
Realize this thread hasn't been updated in a while, and figured I'd share some of what I've found regarding the use of gold-plated vs tin-plated terminals, since I've seen a lot of inconsistent info regarding that, including in this forum (and needed the info for my own build)
Summing up what I've found, it seems the viability of using one or the other in your cabling connections could depend on how many times those connections are made over the course of their use (e.g., life cycle), and whether or not those connections are subject to excessive vibration (e.g., fan, pump, lack of strain relief, etc.). Toss in the propensity of some enthusiasts to change out things regularly, and durability might become questionable (there are cabling related posts by people in the forum which may be related to that).
Of special interest are fretting and fretting corrosion, which the referenced docs I linked to explain fairly clearly, albeit briefly.
All in all, I think the issue boils down to one of a matter of YMMV more than anything else; which could be dependent on your particular use case example, and just how much of a concern something like matched material is in your electrical conductors. Sort of like the question of to cap (or not) any cables you build yourself.
Remember the 901. Edited 05/16/17: it's possible this link may now be dead. Essentially, it linked to an older USAF document that broke out all the codes associated with how man hour time was tracked on work orders. "901" referred to a generally used descriptive catch-all where intermittent issues were experienced, often leading to fixes like "remove and replaced unit, ops check good," or simply ops or bench checked good," no problems noted. "901s" could be and were problematic, especially if they were repeat issues, forcing technicians to change something (e.g., anything) just to say that they did as a process of elimination, usually at the request of higher ups.
Summed up, IOW: If you can't find an issue when you're troubleshooting a complaint, you won't know what to fix.
References:
The rule of thumb used to be mating pins should be plated using the same materials if you want avoid problems. See Golden Rule No.12 : Gold Contacts Should Not Be Mated To Tin Contacts in this linked AMP Technical Report. While the doc is somewhat older, its principles should be more or less still applicable.
Also see: TE brief on reliability in general and for electrical connectors in particular
Muffler Bearings
(24 items)
i9-7900X, i9-10940x
Asus Rampage VI Extreme
EVGA X299 DARK
EVGA GeForce RTX 2080 Ti XC
(2 ea) EVGA GTX 1080 Ti FTW3
G.SKILL F4-3200C14Q2-64GTZ
(2ea) Intel Optane 900P (480GB)
(2ea) Samsung 850 Pro 1TB
(2ea) Samsung 850 Pro 256GB
(2ea) Samsung 970 Pro 512GB
(1ea) Samsung 950 Pro 256GB
EVGA SuperNOVA 1600 T2
Custom water
Custom, 8020x3060 and x2020
Operating System
Win 10 Pro/Ubuntu
NEC PA272W-BK-SV
Eizo ColorEdge CE240W
Alienware AW3418DW
Keyboard
Ergodox EZ with Kailh Thick Gold (Bronze) and Copper switches
Audio
Bottlehead Mainline Amp
Audio
RME ADI-2 Pro FS 2-in/4-out AD/DA Converter
Audio
FOCAL Clear Professional Headphones
Audio
Mr. Schpeakers ETHER C Flow 1.1 Headphones
Other
Protectli Firewall Micro Appliance With 6x Intel Gigabit Ports, Intel i5 7200U, AES-NI
Other
Misc. see build description for details
iamjanco is offline
post #189 of 467 (permalink) Old 04-23-2017, 01:48 PM
Jubijub's Avatar
Rep: 11 (Unique: 8)
Hello,
Can you confirm my reading that the connectors required to connect to an EVGA 1200P2 PSU (Super Flower Leadex basis) are all findable at Molex ? Sorry if the questions sound obvious, but it's hard to check on the Molex website since the visual doesn't always match the connector.
CPU = Molex mini-fit Jr 39-01-3085 ?
VGA = it looks like Molex http://www.molex.com/molex/products/datasheet.jsp?part=active/0455590002_CRIMP_HOUSINGS.xml, but would be an 8pin version
I am trying to make custom cables from A to Z, which would involve getting the right connectors to plug on the PSU.
Jubijub is offline
post #190 of 467 (permalink) Old 04-23-2017, 02:58 PM
Missing friends
Mega Man's Avatar
Rep: 700 (Unique: 431)
They are mini fit jr.
Rigbuilder and how to put it in your sig post-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gif budget components = budget resultsPearls before swine! (Click to show)
Also rma wise, regardless of what vendor used it's always like getting a tooth pulled imo.
I facepalmed when trying to explain cpu and gpu overclocking to him after he got his 4930k. It was like teaching trigonometry to a rock.
That's like wrapping your car around a pole then asking for warranty service.
Dont be hard on yourself, we all break stuff sooner or later.
I don't appreciate your judgment here. I am just stating facts. That's all I'm doing. If you are taking offense to it or something, then that's not my problem, so don't put it on me. Ok?...Good god man. You would know that if you would actually carefully read...
Mega Man is offline
