[Build Log] Calamity (SM8/G1 Sniper 3 Water Cooled Build) - Overclock.net - An Overclocking Community
post #1 of 513 (permalink) Old 12-04-2012, 02:38 PM - Thread Starter
Addiction's Avatar
Rep: 82 (Unique: 57)
Welcome! This is a build log for my new rig, Calamity. I wanted to get this log started before I started the build process so I can show them both the attention that I am wanting too. This is my first time doing a custom water loop, so I am both excited and nervous. I figured I would put a log up though seeing as this community is very helpful to first timers such as myself. This will be a work in progress, as I only have about half of my parts in at the moment, so stay tuned for updates over the course of the coming weeks. College finals end next week, so I will have a lot of time to tinker starting then. By all means, if you see something that does not look right/doesn't fit/etc, please let me know! My build log is also partially for me to learn as I go in regards to water cooling, so any constructive criticism or input is greatly appreciated. Thanks for checking it out, and wish me luck! thumb.gif
The theme I chose for this build revolves around my motherboard colors, the G1 Sniper 3. So I will be going with a Green/Black/White rig. It will be built in a CaseLabs SM8. Here is a brief list of the component list so far. This list is not 100% complete, so changes could occur at any time. I am a busy man with school, work, my wife, and my child. I will do my best to have updates as frequently as possible once the work has commenced.
I will update all the pertinent information through this first post, including everything that may need updating below, as well as direct links to pictures or updates late in the build, so you can go right to the action if you so choose. If you would like to see anything in particular, please ask, otherwise what you "want" or "need" to see for your particular desires may be excluded due to oversight or what I deem unimportant. I am here to help as much as I can for the community that has so graciously helped me thus far in my endeavors.
Color Legend
Green: Denotes Received Parts
Red: Denotes Ordered Parts
Black: Denotes Undecided/Out Of Stock At Preferred Retailer
Hardware
CPU: Intel i5 3570K- $210
Motherboard: Gigabyte G1 Sniper 3 EATX- $270
Case: CaseLabs SM8 (With Accessories)-Matte White- $750
Pedestal: CaseLabs SM8 Pedestal With Drop In Radiator Mounts-Matte White $199.85 (Waiting Until After Christmas)
GPU: EVGA GTX 680 Superclocked+ (2 Way SLI)- $1080 ($540 Each)
PSU: Corsair AX1200- $270
Ram: Mushkin Blackline Enhanced 16GB-Ridgeback- $100
SSD: Samsung 840 Pro 128GB (2 in Raid 0)- $250
SSD: Samsung 840 Pro 256GB (Games)- $270
HDD: Western Digital Velociraptor 500GB (2 in Raid 0)- $160 ($80 Each)
Fans (Radiator): Gentle Typhoon AP-15 1850 RPM (12)- $195 ($16 Each)
Fan Controller: Lamptron FC5-V2- $65
Monitor: Asus VG278H 27" 3D LED 120hz- $550
Water Cooling
Radiator: Alphacool UT60 480mm- $119.99
Radiator: Alphacool UT60 240mm- $72.00
Pump: Swiftech MCP655 With Speed Control- $76.95
Pump Top: Bitspower D5 Mod Top POM Version- $49.95
Pump Mod Kit: Bitspower Pump Mod Kit-Matte Black- $44.95
Reservoir: Bitspower 250mm Tube Reservoir- $38.95
Reservoir Upgrade Kit: Bitspower D5 Top Upgrade Kit 250-Black POM- $49.95
CPU Block: XSPC Raystorm High Performance Acetal-Black Edition- $67.95
GPU Block: EVGA Hydro Copper GTX 680 Edition (2)- $300 ($150 Each)
Fittings (Compression): Bitspower Deluxe White - 1/2" ID and 3/4" OD Compression (12)- $109.45
Fittings (90 Degree): Bitspower Deluxe WhiteG1/4" 90 Degree Rotary Extender (4)- $47.96 ($11.99 Each)
Fittings (60 Degree): Bitspower Deluxe White G1/4" 60 Degree Rotary Extender- $11.99
Fittings (45 Degree): Bitspower Deluxe White G1/4" 45 Degree Rotary Extender (4)- $71.94 ($11.99 Each)
Fittings (30 Degree): Bitspower Deluxe White G1/4" 30 Degree Rotary Extender- $11.99
Fittings (Stop Plugs): Bitspower Deluxe White G1/4" Low Profile Stop Fittings (6)- $29.94 ($4.99 Each)
Fittings (Stop Plugs): Bitspower Deluxe White G1/4" Stop Fittings (5)- $24.95 ($4.99 Each)
Fittings (Stop Plugs): Bitspower Matte Black G1/4" Stop Fittings- $4.99
Fittings (SLI): Bitspower Crystal Link SLI Tube Set With Matte Black Fittings (2)- $32.98 ($16.49 Each)
Fittings (Straight Extenders) : Bitspower Deluxe White 30mm Extender (2)- $15.98 ($7.99 Each)
Fittings (Dual VID): Bitspower Matte Black Dual VID 41-69mm Extender (2)- $23.90 ($11.95 Each)
Fittings (Rotary T): Bitspower 180 Degree Rotary T-Matte Black- $12.50
Fittings (Male To Male): Bitspower Matte Black Dual G1/4" Male to Male- $5.50
Fittings (Male To Male): Bitspower Matte Black Dual G1/4" Mini Male To Male- $4.99
Fittings (Drain Valve) Bitspower Matte Black Mini Valve- $18.99
Fittings (Water Temp Sensor): Bitspower G ¼” Temp Sensor Stop Fitting-Matte Black (2)- $21.90 ($10.95 Each)
Coolant: Mayhems Pastel Mint Green 250ml (2)- $43.90 ($21.95 Each)
Tubing: Durelene 1/2" ID 3/4" OD-12 Feet- $25.00
Sleeving
Paracord: 550 Lime Green-50ft- $5
Paracord: 550 Black-50ft- $5
Paracord: 550 White-50ft- $5
MDPC: Toxic Green-20 Meters- $25.08
MDPC: White-20Meters- 25.08
MDPC: Black-20 Meters- $23.52
MDPC: White Sata-5 Meters- $9.14
Heatshrink: MDPC White- $11.96
Heatshrink: MDPC Black- $11.96
Heatshrink: MDPC White Sata- $4.94
I am most likely going to order some samples of a few greens from Nils at MDPC, as I would prefer his sleeving. I went with paracord for now because the Lime Green matches the green I am using extremely well. If anyone has used MDCP Ranger Green or Combat Green with a Gigabyte Sniper 3 or M3, please let me know how well the color matches. I also am thinking of just doing my own custom wires for the lengths I want for cable management/aesthetic reasons. I am fairly OCD when it comes to things like that, so we will see how that goes. thumb.gif
Miscellaneous
Fan Distribution: 6 Way Fan Distribution PCB’s (2-1 For Each Radiator)- $11 ($5.50 Each)
Acrylic: Miscellaneous Covers
Total Cost To Date (Excluding Tools) Click To Find Out! (Click to show)
$5647.21 (Still Have Much More To Buy!)
Picture Index
Coming Soon...
I would LOVE some recommendations on the parts I have not ordered as of yet, or even any input reinforcing my original thoughts for said components!
I also have to hit the hardware store once my sleeving arrives (tomorrow) to match the green paint the best I can. I plan on painting the fan blades and possibly the housings (or filter covers if I go that route). Furthermore, I also have some White Carbon Fiber Di-Noc on the way as an option for my Rads/Psu. Not 100% sure if I am going with Di-Noc or paint/powder yet, but I'm sure I will find use of it somewhere in my build, the stuff is amazing for accents/etc. I think the gloss will go nicely with the matte/satin finish of the white CaseLabs SM8! I may also end up getting the CaseLabs Matte White paint matched at a paint shop to get exact colors, without some off the risks of using powder on radiators. I am undecided in this regard, so chime in if you have any thoughts on any of these topics. thumb.gif
A little Teaser of some of the components I have received already. I will update as things come in, and I will be sure to post a bit in advance before I start the actual build! Please understand I am not a professional photographer, but I will try my best to produce the best possible images I can with my DSLR!
Teaser Pictures! (Click to show)
G1 Sniper 3 EATX
i5 3570K
Mushkin Blackline 16GB
Samsung 830 128GB (My Boot Drive)
WD Velociratpor 500GB
Here is a glimpse of how I plan on wiring my 6 fans per radiator into 1 channel each on my Lamptron FC5-V2. This "should" work, as the startup wattage for the 6 GT AP-15's should be ~24 watts is my math is correct. If it seems off to you, please let me know. thumb.gif Also, please pardon my newbie MS Paint skills, or lack thereof. Hopefully it is easy to understand, but I basically am just wanting to maintain the average RPM load on each radiator without my Lamptron going nuts over having 6 RPM wires going into it (Big thanks to EpicAMDGamer of OCN for the guidance with this! thumb.gif)
Stay Tuned For More Updates in the coming days and weeks!
Regards,
Addiction
Addiction is offline
post #2 of 513 (permalink) Old 12-04-2012, 02:52 PM - Thread Starter
Addiction's Avatar
Update: Something sexy showed up as I was typing this build log intro up!
My new waterblocks!
Stay tuned for more soon!
Regards,
Addiction
post #3 of 513 (permalink) Old 12-04-2012, 03:29 PM
TigerStripes's Avatar
Rep: 5 (Unique: 5)
Looks like a great start! Definitely subbed!
My recommendation for fittings would be Monsoon compression fittings. They're very easy to use, look great, and come at a lower price point than most other brands. Plus they come in lots of different colors, so you could easily get green, white, black or even black chrome to go with your build theme.
I've got the Raystorm Black Edition and I love its look. But I could see the vanilla version with the light-up acrylic mounting bracket looking sweet in this build if you got some green LEDs for it. I technically have both - PPCs didn't have the Black Edition, but it was actually cheaper to buy the standard acrylic version from PPCs and the Black Edition aluminum mounting bracket separately from FrozenCPU than to buy simply the Black Edition from FrozenCPU (go figure).
TigerStripes is offline
post #4 of 513 (permalink) Old 12-04-2012, 03:37 PM
Rep: 5 (Unique: 5)
Ooh, another cool thing about the Monsoon fittings a just remembered- you can actually buy fittings that allow you to stick an LED in one end and light your tubing up from the inside
post #5 of 513 (permalink) Old 12-04-2012, 03:38 PM - Thread Starter
Addiction's Avatar
I appreciate the recommendations! I am definitely going the black edition route on the raystorm. I will have to look into the buying the separate back plate like you did though. Paying less for more is always good in my book. This build is adding up already, so I'll take some savings if I can. I am not much for LED's, and the only ones that will be in my case are the indicator lights on the motherboard, and the EVGA Hydro Copper ones (which I am going to change from red to green to keep with my theme biggrin.gif). I may end up putting a simple white cold cathode just to give it better light to see it overall, but nothing over the top.
P.S. Thank you for pointing me to CaseLabs to begin with a few weeks back! I +Rep'd you accordingly then so just letting you know. I think I am going to be very happy with this case over the Fractal Design R4. thumb.gif
Regards,
Addiction
post #6 of 513 (permalink) Old 12-04-2012, 03:43 PM
eskamobob1's Avatar
Rep: 128 (Unique: 95)
Favorite OCN Quotes (Click to show)
Look at it this way, opinions are like buttholes. everyone has one, and they all stink.
very pretty, love the dual frozxorz also.
Exactly! It's down right sexy!
eskamobob1 is offline
post #7 of 513 (permalink) Old 12-04-2012, 03:46 PM - Thread Starter
Addiction's Avatar
post #8 of 513 (permalink) Old 12-04-2012, 03:48 PM
Rep: 5 (Unique: 5)
You're very welcome! I thought that was you, but the rep comments don't come with a username... I'm actually jealous that you're getting your SM8 so quickly - I just spent a ton on just getting my loop together so its sitting in my POS Thor until I save up a bit (and convince the girlfriend).
Just curious - since you're going with 2x 360 rads, are you getting a pedestal or doing a flex bay mount?
Oh and if you haven't already, be sure to post in Stren's thread for Case Labs build logs, he'll add you to the list
post #9 of 513 (permalink) Old 12-04-2012, 03:54 PM - Thread Starter
Addiction's Avatar
It took some convincing of the wife to get it, but since it's Christmas time it wasn't too bad! As far as radiator placement, I am going 360 up top and 360 in the front with the flex bay rad mount. I was considering either top/bottom or the pedestal, but ended up deciding I did not want to add the height, and I think it will "fill it out" better with the one up top and the one up front. This also still leaves me space for my Lamptron, which is the only bay device I will have. I almost went 480 up top and was going to figure out a way to mod the inside to hold my Lamptron, but decided 2 360's is more than enough for what I am doing anyways. Hopefully the PSU/Sleeving get here tomorrow, so I can start some trial and errors runs on that while I am in between finals. biggrin.gif And I will get myself added to Stren's thread here shortly, thanks for the tip. cheers.gif
Regards,
Addiction
post #10 of 513 (permalink) Old 12-05-2012, 09:28 AM
nezff's Avatar
Rep: 36 (Unique: 29)
The mdpc greens don't match. Too dark/ green/brown
nezff is offline
