[Build Log] "Magnum" Watercooled 350D Haswell Build - Page 14 - Overclock.net - An Overclocking Community
post #131 of 299 (permalink) Old 06-26-2013, 05:56 PM - Thread Starter
Oliver1234's Avatar
Rep: 9 (Unique: 7)
Originally Posted by Ninjawithagun View Post
That is correct. If you do decide to mount an optic drive, there won't be any room for maneuvering the Corsair H110 into place if you want the tubes in the front. That's because there is only about 1 inch of clearance between where the tubes connect to the radiator and the top of the optic drive. If you look closely at the second pic, you can see clearly that there is no room to orient the tubes. You could try, but the tubes would either kink or pop off the radiator altogether which is a very bad thing. If you decide that you MUST have the tubes toward the front of the case, you will not be able to have an integrated optic drive. For some folks, this is okay.
Also, FYI - I forgot to mention that this is my secondary LAN gaming rig. My primary rig is listed below in my profile signature coolsmiley02.gif
With a little bit of modding, you may be able to fit a slim profile optical drive in the 2nd bay, and that would give you enough clearance to run the tubes from the front, and have a proper fan in the back!
"Set your mind, soul, and heart upon doing everything necessary to become your best".-Coach Duane Lee Bemis M.Ed.
My Clubs (Click to show)
post-flame-small.gif Teen Overclockers Club post-flame-small.gif The OCN Brass Club post-flame-small.gif Overclock.net Mechanical Keyboard Club post-flame-small.gif Corsair Obsidian Club post-flame-small.gif Club for those with beastly mATX/ITX rigs post-flame-small.gif Corsair 350D Owners Club post-flame-small.gif Overclock.net Watercooling Club post-flame-small.gif Mayhems Users Club post-flame-small.gif 4GHz Club post-flame-small.gif
Build Logs (Click to show)
Oliver1234 is offline
post #132 of 299 (permalink) Old 06-26-2013, 09:17 PM
I miss Case Labs
Panther Al's Avatar
Rep: 62 (Unique: 58)
Originally Posted by Oliver1234 View Post
I was actually thinking about Magnum also because Magnus sounds a bit too Latin ( I take the language in school).
The 2 280's would fit fine, but the front one may require drilling a few holes for the fans. I didn't go with the 280's for 3 reasons:
1. I already had the 120mm corsair fans
2. In some cases, 120mm fans give more static pressure than most 140mm fans, and will cool the rad much more effectively.
3. They are slightly cheaper (In my situation, every dollar counts).
The honest reason I didn't follow through on the unique layout I had planned was money ( lack of), and my obsession with having a tube res in the case. When I have a steady job in college in a couple years, I definitely plan to mess around with "alternate" layouts with my case in real life, instead of in my head.
Actually, I don't think you can put a 280 up front out of the box: While two 140mm fans will fit, you still need room for the connections to come into play. The only way I can see that happening is if you mod the case - probably and most easily, by stripping out the ODD bays. At that point, you'll have to figure out how to fit a res in there somehow - since a bay res will be out of the question.
Kevdog's Law: 2 // GTX Titan: 0 CaseLabs - BH2, SMA8-A, S8
"Mad Science" means never stopping to ask "what's the worst thing that could happen?"
"If the modding you do is covered by the manufactures warranty, you didn't do enough modding."
Panther Al is offline
post #133 of 299 (permalink) Old 06-27-2013, 05:55 AM
Rep: 7 (Unique: 6)
Actually, you can. I just rechecked the mounting holes in the front of my 350D case last night and saw that it is possible without any modifications to the case. What you would need to do is mount the radiator inside the case with the tubes on either end facing inward. Then mount the two 140mm fans on the exterior of the case in a push configuration. The screws included with the H110 are long enough to secure the fans to the backside of the radiator. No mods are necessary because the tubes are already facing inward inside the case biggrin.gif
Not sure how many people here would prefer doing this upgrade though as it prevents from being able to have fresh cool air being blown into the PC from the front... I guess it would be okay if you decided to mount a custom 280mm radiator for watercooling the graphics cards, but the reservoir would need to be mounted in place of the optic drive or in the bottom of the case between the radiator and power supply.
*UPDATE* I forgot to check the width between the two sides of the metal beams in the front of the case. It may not be wide enough to mount a 280mm radiator. I will measure it when I get home from work tonight and post another update...
Ninjawithagun
Ninjawithagun is offline
post #134 of 299 (permalink) Old 06-27-2013, 06:45 AM - Thread Starter
Oliver1234's Avatar
Rep: 9 (Unique: 7)
Ninjawithagun is right, and also even if the tubes were at the same end, it's definitely possible to just cut the 2nd OD bay, and leave the first open for a single bay res.
post #135 of 299 (permalink) Old 06-27-2013, 07:13 AM
I miss Case Labs
Panther Al's Avatar
post #136 of 299 (permalink) Old 06-27-2013, 07:30 AM
superglu's Avatar
Rep: 0
I am 95% sure that a non-AIO 280mm radiator cannot fit in the front unless you saw through the ODD cage (it is not removable by rivets, it is actually the same piece of steel as the front frame). The reason is that the input and output ports extend the height of the radiator by almost another inch.
superglu is offline
post #137 of 299 (permalink) Old 06-27-2013, 07:50 AM - Thread Starter
Oliver1234's Avatar
Rep: 9 (Unique: 7)
Here's a shot of CPU - Z, Memory info, Super pi Calculation Times, and Core temps (shows min. and Max during super pi):
Rad and res should be here later today!
post #138 of 299 (permalink) Old 06-27-2013, 07:51 AM
Linux Lobbyist
dsmwookie's Avatar
Rep: 17 (Unique: 16)
I intended on removing the optical completely. This is good news.
dsmwookie is offline
post #139 of 299 (permalink) Old 06-27-2013, 08:10 AM - Thread Starter
Oliver1234's Avatar
Rep: 9 (Unique: 7)
Glad you'll end up fitting a 280, just plan out carefully ahead of time where and how you will cut.
I sketched up a quick design of the GPU backplate, the black color will be brushed aluminum, and the red will be light showing through holes. Any thoughts?
post #140 of 299 (permalink) Old 06-27-2013, 01:13 PM - Thread Starter
Oliver1234's Avatar
Rep: 9 (Unique: 7)
UPDATE!!!!!
Got my package!
EDIT: Sorry, pics went in backwards order!
Picked up some distilled water and vinegar for rad flushing:
Do you guys know what this is? Is it a drain port? It's not on the 30mm rad, could I use it in the loop?
With rad flushing, should I only flush it right before I fill it with fluid, or can I do it now? Also, if I decide not to do it now, could I still install the rads, and flush the entire loop (would vinegar hurt anything like the pump or blocks?)
Thanks!
