[SCRATCH BUILD] Metro Last Light - Page 2 - Overclock.net - An Overclocking Community
post #11 of 73 (permalink) Old 08-17-2013, 07:35 PM - Thread Starter
Bad Fenny's Avatar
Rep: 14 (Unique: 9)
Originally Posted by szeged View Post
looking better and better.
Thanks much. I am having a really great time with the build and I am glad someone is enjoying it. smile.gif
Cheers
Fen
Bad Fenny is offline
post #12 of 73 (permalink) Old 08-18-2013, 06:48 AM - Thread Starter
Bad Fenny's Avatar
Rep: 14 (Unique: 9)
Window Dressing
Hi all,
Not much of an update, but alas, I have to attend to the yard work today so I thought I would keep it small. For those of you who have played the game, you will know that a few things are very important: (1) never go on the surface without your gas mask and; (2) always scrounge for ammunition.
Right, so I have the gas mask which I will incorporate at some juncture wink.gif . So I figured I should pay homage to another important element . . . ammo.
Look what I got.
Before all you ammo purists say . . . "Hey those are .303 rounds" . . . I would have loved to get my hands on 7.62 x39mm soviet rounds but unfortunately, it was not in the cards . . . So .303 will have to suffice as a stand-in tongue.gif
I wanted to have a clip of ammo but was unable to locate one so I decided to fabricate a clip out of sheet metal . . . this was not the easiest thing to do as the bend required was an 1/8th of an inch so it took some patience to get it right. mad.gif
Okay, the end result may not be pretty but for the most part you won't see the crimped ends. smile.gif
I wanted to age the clip so it looked as though it has been hanging around and reused over time. Started with the base rust colour then a light dusting of black.
The final product.
Cheers
Fen
post #13 of 73 (permalink) Old 08-18-2013, 06:59 AM
AlderonnX's Avatar
Rep: 53 (Unique: 45)
Nice work man! i love the non-case cases. I would totally send you some of my 1970's russian Ammo (7.62 X54R) but not sure it can be shipped over into canada legally?
AlderonnX is offline
post #14 of 73 (permalink) Old 08-18-2013, 07:02 AM
szeged's Avatar
Rep: 737 (Unique: 415)
and yeah i would donate some of my military ammo cases etc but doubt i can get them to you without actually driving them to you lol.
szeged is offline
post #15 of 73 (permalink) Old 08-18-2013, 07:58 AM - Thread Starter
Bad Fenny's Avatar
Rep: 14 (Unique: 9)
I have to admit creating a case out of non-case is a bit of a challenge but I have been thoroughly enjoying it thumb.gif
Thanks for the offer guys on the ammo but I am sure it would get stopped at the border . . . biggrin.gif I tried earlier to get some from a friend down your way but when he checked, it was a no go (inert or not). My normal contact up here in Canada doesn't have any on hand.
Oh well, guess .303 will have to suffice.
Cheers
Fen
post #16 of 73 (permalink) Old 08-24-2013, 04:40 AM - Thread Starter
Bad Fenny's Avatar
Rep: 14 (Unique: 9)
UPDATED: Front Ammo Can Access Panel
Hi all,
Been away from things for awhile . . . funny how life and work gets in the way of having fun smile.gif.
In between that pesky think call my "day job", I worked a bit on the front ammo can. If you recall, there are three ammo cans to this build, two are stack one on top of the other to form the main portion of the case and third is stacked to the front. This ammo can will hold the PSU and one HDD.
Since this was a tribute build, I wanted to place some artwork on the very front of the PSU ammo can and I figured that it should be the signature "M" from the game. I had two art concepts but one looked much better than the other (below is my attempt at a render).
My intent was to produce a decal of the artwork on my computer and affix it to the front of the ammo can. Unfortunately this did not work out for a couple of reasons. The first was that I only have an "inkjet" printer and it could not do the work justice. The second was that I planned to adhere this to an access panel which would be located on the front of the ammo can. Once the build is complete, I will not be able to access the PSU ammo can by opening the lid (build design reasons). So I had to incorporate an access panel. When thinking about the panel, I realized that with a 750 PSU and one HDD enclosed in the tight constraints of an ammo can, it is going to get very hot in there even with an PSU fan exhaust cut in the back of the can. So I decided to make the panel out of meshed metal to allow for maximum air flow. Since it would be meshed, then I would have to punch holes through the decal as well so as to allow that airflow . . . short story, I scrapped the decal idea. This left no other option but hand painting for which I don't have a lot of talent.
Making the Panel
As I said above, I decided on a mesh panel. So in keeping with the "Metro" theme, I salvaged part of the old case in order to make the panel. Once cut, it was primed and a flat black base coat was applied.
Artwork
As you can see my poor attempt at a decal did not do the artwork justice (the one on the panel lying flat . . . the other one is printing on white paper). The whole image was flat with no vibrancy as the colour and texture did not come through . . . Particularly the signature "M".
So, my only option was to hand paint the artwork. Now bear in mind I do not have an airbrush (wouldn't know what to do with it even if I had one confusedsmiley.png). So it was brushes, cotton and sponges for me in order to paint and create texture on a flat surface. Also, what you see below is a culmination of various attempts with plenty of mistakes, repaints and a lot of madsmiley.png
The first thing I needed to do was create a backdrop of a grey industrial wall which has been weathered. I used grey spray primer then sponge dabbed flat black latex paint in various watered consistencies to get the aging effect on the wall.
The last step was to apply the rusted effect. This was done by using various tones of brown and orange latex paint in various watered consistencies to create texture and depth. Paint was dabbed on using sponging and blended together. A light dabbing of watered black latex was used to raise shadowing.
I turned my attention to the signature "M". I decided not to paint this on as I really wanted it to stand out and I thought the mesh look would make it disappear into the background (yellow filled with holes). So I decided to make the "M" out of sheet aluminum and affix it to the front. This would make it stand out from the rest of the art work.
Once the "M" was cut I primed it and applied a first thick coat of flat latex yellow. Now you are probably wondering why I didn't use spray paint. Firstly, finding this shade of yellow in a flat spray was impossible (lots of gloss out there). Second, I need thick paint to create the textured look. Once applied, I dabbed the thick coat with cotton pads to give it texture. Once the yellow dried, I used various shades of yellow to create highlights and lowlights and browns to darken and age.
The final product
After completing the artwork, the panel was fitted to the ammo can (bent at the rear) and final lettering was applied to the "M". It turned out okay (better than I though it would) but not as good as if I had real talent at painting. Nonetheless I am happy with it smile.gif
Cheers
Fen
post #17 of 73 (permalink) Old 08-24-2013, 06:43 AM
szeged's Avatar
Great job. Can't wait for more.
szeged is offline
post #18 of 73 (permalink) Old 08-24-2013, 01:26 PM
Linux Lobbyist
Apocalypse Maow's Avatar
Rep: 15 (Unique: 13)
What! How did I miss this!!! Sub'd for sure!!!
Apocalypse Maow is offline
post #19 of 73 (permalink) Old 08-24-2013, 06:48 PM - Thread Starter
Bad Fenny's Avatar
Rep: 14 (Unique: 9)
Thanks guys . . . I get the distinct impression that these are not the type of builds people like on this forum. Oh well, I do it for the fun and if some like minded people enjoy it along the way, then that makes it even more enjoyable. thumb.gif
Cheers
Fen
post #20 of 73 (permalink) Old 08-25-2013, 07:06 PM - Thread Starter
Bad Fenny's Avatar
Rep: 14 (Unique: 9)
Hi all,
Not much done today as I had to deal with that pesky "to do" list. So I did some work on the PSU ammo can. I also thought I would take the opportunity to let you in on what I plan to do with that gas mask . . . well not everything that is . . . I have to keep some things back wink.gif .
So, as I indicated earlier, I was going to use one ammo can to hold the PSU and one of the HDDs. However, I would need to alter the can to accommodate the PSU venting fan and switch. As well, I figured it was going to get very hot in there so I was going to cut an access port through the front side. Finally, I needed an opening to run cable through the PSU ammo can to the main PC ammo cans.
PSU fitted for measurement
Taped for cutting
Final cut
Normally I don't have much luck on these custom cuts but it was spot on this time and the PSU fit perfect. I had to account for a small hump in the bottom of the can which the PSU is going to sit on.
The concept dry fitted
Bear in mind this is not the final paint job and there is still lots of weathering and aging to come . . . you know me . . . if it doesn't look like it was kicked down a hill and buried for 100 years in a nuclear waste dump . . . it isn't finished biggrin.gif
(Front side of the case - PSU access panel open)
(Front side of the case - PSU access panel installed)
This will be mounted to the case and while I have some plans for it which will unfold over the life of the build . . . suffice it to say it will not be just window dressing ph34r-smiley.gif
(Rear of the case)
(Back side of the case)
Both openings will allow access to the interior of the case. The bottom opening will have the intake fan mounted. The exhaust fan is in the top lid of the top case. I am thinking about incorporating a small plexi window in the top access panel so you can see into the interior of the build (lots of aging will be going on in there as well. Still have to mount the mobo tray.
(Front of the case)
Well that's it for now . . . stay tuned for more.
Cheers
Fen
