Repository Of Power Supply Pin Outs. - Page 57 - Overclock.net - An Overclocking Community
post #561 of 1044 (permalink) Old 06-04-2015, 12:45 PM
tistou77's Avatar
Rep: 18 (Unique: 15)
By default, the 12v was at 12.18v, when I removed the "double wire", I had the 12v at 12.39v and with the modification, it's returned to 12.18v
The next time that I "disassembles" the PC, I think I'll put of the "crimp" modified
Sorry for my english
tistou's config
(19 items)
i9 7980x
Asus Rampage VI Extreme
EVGA RTX 2080ti XC Ultra
G.Skill Trident Z @4000 C17
Intel Optane 900P
Samsung 970 EVO
Seasonic Prime Ultra Titanium 1000W
Alphacool VPP755 x2
Mod Pump Bitspower
Mod Pump Ek Waterblock
Ek Velocity
Waterblock EVGA Hydro Copper XC
MORA 3 9x120
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Logitech Illuminated K740
Mouse
Logitech MX Revolution
Audio
Asus Xonar Phoebus
tistou77 is offline
post #562 of 1044 (permalink) Old 06-04-2015, 04:18 PM
ANTEC CS155's Avatar
Rep: 12 (Unique: 5)
Just a heads up, HCP 750 Platinum Power supplies have a different power connector configuration
ANTEC CS155 is offline
post #563 of 1044 (permalink) Old 07-30-2015, 01:55 AM
Adict's Avatar
Rep: 4 (Unique: 3)
Hello guys I need help , I buy a new GPU and now I have 1x6 pin power and 1x8 pin power from PSU to GPU . My old GPU have 2x6 pin power connector and I sleeve them .
Now I want sleeve for new gpu that 2 more wire what gpu need . Can somebody give me or tell me where i must put this 2wire in my psu 8 connector . PLS help wink.gif
I want sleeve that today wink.gif I must sleeve 8pin psu to 8 pin . PSU TO GPU ..
Adict is offline
post #564 of 1044 (permalink) Old 07-30-2015, 03:07 PM
8.2 liters
WiSK's Avatar
Rep: 553 (Unique: 361)
The two extra wires on the 8-pin connectors are both ground, so if you let us know exactly which PSU you have, probably there is an easy solution for finding two more ground wires.
WiSK is offline
post #565 of 1044 (permalink) Old 07-31-2015, 01:22 PM
Adict's Avatar
Rep: 4 (Unique: 3)
I have XFX XTR 550W modulas PSU . I sleeve one wire and plug at the both connector at the same place , and GPU works fine . So i hit first one smile.gif
Adict is offline
post #566 of 1044 (permalink) Old 08-01-2015, 04:08 AM
Adict's Avatar
Rep: 4 (Unique: 3)
Pls help . 8 pin psu to 8 pin gpu . XFX XTR 550w .
Adict is offline
post #567 of 1044 (permalink) Old 08-03-2015, 06:06 AM
8.2 liters
WiSK's Avatar
You have two PCIe plugs on the PSU side. Those are big 12-pin connectors with the top row is 12V and the bottom row is grounds. So instead 12-pins to 2x6, you could make 12-pins to 8 and 12-pins to 6.
At PSU side, see left most diagram, view from rear of connector
At GPU side 8-pin connector is bottom drawing, view from front of connector (the blue and green pins are ground)
WiSK is offline
post #568 of 1044 (permalink) Old 08-18-2015, 02:12 PM
u25a0's Avatar
Rep: 0
Greetings one and all!
My name is Ender, long long time lurker, first time poster.
I was introduced to the modding community many years ago by a previously very active member, colleague and very close friend who went by Langer. Unfortunately he passed away a few years ago and left a big hole in everyone's lives. Some of you may remember his PrometheusCU and Helios case mods, among others.
I still work and operate the company once founded by Langer -Society Inc- and we're still working on a bunch of very cool tech projects. One of our projects requires TWO very serious PCs for the development of a next generation type VR/AR headset akin to what you may have seen from Hololens/MagicLeap/GoogleGlass.
I'm going to be doing a project log in the coming months reviving Langer's Helios case mod... a little homage to my old buddy. I've worked with his family to get some very similar 8mm thick carbon panels, like those used in his project log years ago. I've updated and improved his drawings and designs. As well, I've ordered all the hardware already... and I'm at over $60,000cad into this project now already.
The hardware list of the two machines is as follows, The First is going to be pretty standard in terms of it's construction and will live in a rackmount case, very little modding here:
x1 - Asus - Z10PE-D8 WS Motherboard
x2 - Intel Xeon - E5-2687 V3 Processors
x8 - Kingston - 16GB ECC DDR4 RAM Stick
x3 - Evga - Titan Z 12GB Graphics
x1 - Samsung - SM951 256GB M2 Drive
x8 - HGST - HE8 8TB HardDrives
x1 - Asus - PCE-AC68 Wificard
x1 - Asus - Xonar Essence Soundcard
x1 - Evga - 1600w Titanium PSU
x1 - Case - Rugged Rackmount
The second is going to be something pretty special, and will be the topic of discussion with my questions further below:
x01 - Asus - Z10PE-D8 WS Motherboard [130w]
x02 - Intel Xeon - E5-2690 V3 Processors [300w]
x08 - Kingston - 16GB ECC DDR4 RAM Stick [36w]
x03 - Radeon - R9 Dual Fury X 8GB [unreleased] Graphics [1600w]
x01 - Samsung - SM951 256GB M2 Drive [5w]
x08 - Corsair - Neutron XT 960GB SSDs [50w]
x01 - Asus - PCE-AC68 Wificard [15w?]
x01 - RME - HDSPE AIO Soundcard [20w?]
x02 - Supermicro - PWS-2K04A-1R 2KW Power Supplies [2000w out]
x01 - Turemetal - TL240 240W PICO ATX Power Supply [240w out]
x12 - Noctua NF-A14 Industrial PPC-3000 Fans [100w incl pumps]
total - ~2256w under absolute max load (likely more ~1750watt under heavy operating load)
I've opted to use two rackmount 1U server style hot-swap power supplies, in this case they deliver 2000w at 230v, (1000w at 120v), of 12v power, rated 80+ titanium.
They look a little like this: http://i.imgur.com/xl3AgwC.jpg
(note that there are no wires, these PSUs use 'gold finger connections')
SO this brings me to my specific system, I've drawn a rough map below:
http://i.imgur.com/1govIYC.jpg
Here's a little Langer inspired teaser, a totally updated and revised Helios mod plan in keeping with his aesthetic style:
This is just a little taste, but communicates the parts layout well enough, the long pink rectangles in the bottom are the Supermicro PSUs. Note that in total we have only 10 wires going to the motherboard and GPUs for power. Also all the connections for power (and data) are built right into the chassis for total modularity.
As you can see I want to run the two 2kw 12v PSUs in parallel, which will drive the various 12v components of the build.
They also power a very small 240w DC-DC ATX power supply that will provide the various voltages for the motherboard, as well as the necessary 5V for the SSD Sata drives.
The order of business here is wire reduction, I plan on eliminating the normally standard ~167 wires needed to power all my gear and cooling down to just 30wires.
1) I haven't had anyone say anything to the contrary as yet in regards to bridging like wires. For example, the 24pin ATX connector only consists of 8 different connections... if the necessary current is provided for is there any reason I cant just jump all the connections throughout the built and minimize the wire count (as shown in my diagram)?
2) Same goes with the 6x and 8x pin 12V connections on the motherboard, I would like to jump all these together and run just 2x wires from the PSU. In the case of the 12v GPU power lines, I've seen the 2-wire mod done before: http://imgur.com/a/LEG2L
Full build log here: http://community.thermaltake.com/index.php?/topic/1426-australia-stuart-tonks/
3) I know almost nothing about these server style power supply units, there's a great about them that's still a mystery to me. I've reached out to Supermicro, who asked me to sign an NDA in exchange for some documentation... but I found very few answers to the deeper question. I see a lot of reference to current sharing in one document, and there is a loadshare pin (ishare) as well as a wake-up bus pin that seem to be related to this but can be ignored, can anyone help me better organize the necessary circuit and connections to make this work?
I got some feedback from reddit that tells me ishare simply needs to be joined on each psu, and I've seen a vague wire diagram that eludes that wake-up-bus works the same (although I suspect wake-upbus requires some additional circuitry between each psu).
4) In the case of the +5v standby out from the Supermicro units, it's my thinking that i should bridge these lines and run the current to the motherboard; ignoring the 5Vsb from the Pico PSU. Same goes with the DCGOOD wire, I'm thinking that I should bridge and run it to the motherboard as well, in place of the pico.
Please take a look at my diagram above, let me know if I've done anything glaringly wrong... I'm sure I have, as I mentioned I have no idea how to force a current sharing situation with these units so it's all guesswork. Any little bit of input would no doubt be of huge help!
Thanks in advance.
*e
u25a0 is offline
post #569 of 1044 (permalink) Old 08-26-2015, 09:31 PM
WaterCooler & Case Modder
crafty615's Avatar
Rep: 12 (Unique: 7)
for the EVGA 850 pinouts, since the 8 pin doesnt have numbers in ( ) like the 24 pin, does that mean that the 8th pin slot on the psu side goes into the 8th pin slot on the other side?
Open Air
(31 items)
Intel Core i7-8700K Coffee Lake 6-Core 3.7 GHz (4.7 GHz Turbo) LGA 1151 (300 Series) 95W BX80684I78700K Desktop Processor Intel UHD Graphics 630
ASRock Z370 Killer SLI/ac LGA 1151 (300 Series) Intel Z370 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
ASUS GeForce GTX 1080 TI 11GB GDDR5X Founders Edition VR Ready 5K HD Gaming HDMI DisplayPort PCIe Graphics Card (GTX1080TI-FE)
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C16D-16GVGB
Seagate BarraCuda Pro ST4000DM006 4TB 7200 RPM 128MB Cache SATA 6.0Gb/s 3.5" Hard Drive Bare Drive
SAMSUNG 850 EVO 2.5" 500GB SATA III 32 layer 3D V-NAND Internal Solid State Drive (SSD) MZ-75E500B/AM
EVGA SuperNOVA 850 G2 220-G2-0850-XR 80+ GOLD 850W Fully Modular EVGA ECO Mode Includes FREE Power On Self Tester Power Supply
Bitspower Water Tank Z-Multi 250 - POM
EK-Supremacy EVO CPU Water Block - Nickel/Plexi
XSPC RX480 Quad-Fan Radiator V3 - Black
Mayhems X1 UV Green Concentrate - 250ml
Swiftech MCP655 G1/4 Threaded Special Edition 12 VDC D5 Pump With Speed Controller
Bitspower Premium D5 Mod Top with Acrylic Pump Top and Black Mod Enclosure
EK-Vardar F4-120 (2200rpm) High Performance Liquid Cooling Fan
XSPC LCD Temperature Sensor V2 - Green + G1/4 Plug Sensor
Bitspower Non-champher Crystal Link 16mm OD Tube Length 1000mm
Bitspower G1/4" Matte Black Enhance Multi-Link For OD 16MM
EK-FC1080 GTX Ti Backplate - Black for EK-FC1080 GTX TI series water block
EK-FC1080 GTX Ti - Nickel Plated Copper Water Block with Plexi Top for NVIDIA GeForce GTX 1080 Ti graphics card
Thermaltake Core P5 ATX Open Frame Panoramic Viewing Tt LCS Certified Gaming Computer Case CA-1E7-00M1WN-00
Operating System
Windows 10 Pro
Samsung U28E570D, 28-inch Free Sync Ultra HD, 16:9, 3840x2160, 1ms, Tilt, HDMI 2.0, Display Port, Split Screen
Acer H6 Series H236HLbid Black 23" 5ms (GTG) HDMI Widescreen LED Backlight LED Backlit LCD Monitor, IPS Panel 250 cd/m2 ACM 100,000,000:1 (1000:1)
Keyboard
RAZER Blackwidow Chroma RGB Gaming Mechanical Keyboard - Razer Green Switch
Mouse
Razer DeathAdder Ergonomic PC Gaming Mouse
Mousepad
Bimor Extended Gaming Mouse Matt/Pad - Rick and Morty
Audio
Audioengine A2+ Premium Powered Desktop Speakers - Pair (Black)
Audio
Polk Audio PSW10 10-Inch Powered Subwoofer (single, Black)
Audio
Razer Kraken 7.1 Chroma V2 USB Gaming Headset - Oval Ear Cusions - 7.1 Surround Sound with Retractable Digital Microphone and Chroma Lighting
crafty615 is offline
post #570 of 1044 (permalink) Old 08-27-2015, 01:16 AM
Rep: 12 (Unique: 12)
Guys,
I had not found a pinout schematic for my Power Supply: the (relatively) new Corsair RM1000i. So I did the work myself. I've saved the work and am happy to share it with you all / the Overclock.net community. Many of you have helped me, so it is good karma to give something back! Maybe some of you will find this useful.
(As a health warning. I have triple checked this data, but I will not take responsibility for any errors or omission. You use this data at your own risk. One thing I was not sure about was the definitions of the writing on top of the SMD capacitors. If anyone else reading this has a correction, please let me know and I will update the source document.).
See attached. - Simon.
Corsair RM1000i pinout schematics
SimonOcean is offline
