[Build Log] Evga Hadron "Golden Nugget" (Water Cooled Mini-ITX) FINALLY DONE! - Overclock.net - An Overclocking Community
post #1 of 201 (permalink) Old 11-01-2013, 01:02 PM - Thread Starter
note's Avatar
Rep: 12 (Unique: 11)
Golden Nugget
Introduction:
Hi, welcome to my build log. I have been wanting to build a small form factor system for a while and when I saw the new EVGA Hadron my heart skipped a beat. My original plan was to build a red and black themed RoG inspired case and then I saw the MDPC #044. The MDPC #044 was the cleanest and classiest build I've ever seen in my life. The release of ASUS gold themed mother board, and EK gold cpu blocks definitely helped my decision. I took the plunge to build a mini MDPC #044 and bought all the parts needed.
Build Goal:
My main goal is to get as close as possible(looks wise) to the MDPC #044 on a SFF case.
Things I'm aware of:
I am aware that a slim 240mm is not enough to cool a GPU and CPU.
I am aware that the slim Slipstreams is not an ideal fan to cool the radiators.
Parts List:
  • i7- 4770k (might delid if the temps would be too high)
  • Asus z87i-deluxe
  • 16GB Corsair Vengeance LP
  • Mushking 250gb SSD
  • Zotac GTX 670 2gb
Pictures:
Warning: Spoiler! (Click to show)
Water Cooling Parts List:
  • EK Supremacy Gold CPU Block
  • EK GTX 670 Nickel Plexi (Please make a gold one for me EK!)
  • EK X3 150mm Tube Reservoir
  • Black Ice Pro II 240mm radiator
  • Scythe Slipstream 120mm x 12mm 2000rpm case fan
  • Swiftech MCP35x pump
  • Gold Monsoon Fittings
  • Primochill Black Tubing
Update Log:
  • 10/18/2013
    Ordered parts
  • 10/29/2013
    Test the system
  • 10/31/2013
    Remove the case drive cage
    Remove the front panel sticker
    Found out that black ice pro ii x-flow wouldn't fit
  • 11/01/2013
    Ordered a regular black ice pro II 240mm.
  • 11/02/2013
  • 11/07/2013
    Fan trim mod. WOHOO! IT FITS!!
  • 11/08/2013
  • 11/16/2013
    Finished plexi glass mount to hide the cables!
  • 11/30/2013
    Sleeving components arrived!!
To do list:
note is offline
post #2 of 201 (permalink) Old 11-01-2013, 01:03 PM - Thread Starter
note's Avatar
Update Log with pics:
  • 10/31/2013 - I removed the drive cage by drilling through the rivets that holds the drive cage, and remove the sticker from the front panel.
    Pictures: Warning: Spoiler! (Click to show)
    Drive cage.
    Drive cage removed! That hard drive cage took a lot of space.
    Stickers removed!
  • 11/01/2013 - Went to home depot to buy some plexi glass and found out that they have a smoked one. What a pain in the butt to cut plexi glass with the plastic cutter! I failed a couple of times but eventually got one piece that I could use.
    Some of the failed ones.
    Here's the piece I might use.
    This is just showing how the plexi glass would be mounted on the case. I would be mounting the reservoir, and hide the sleeved cables underneath the plexi glass. (see how the cables kinda pops out)
  • 11/07/2013 - Basically cutting the fan trim to make room for the radiator and mobo.
    Picture of a fan that I trimmed.
    Picture of the fan + radiator.
    SUCCESS!!!
  • 11/16/2013 - Plexi glass mount to hide the cables and cable routing.
    24pin and 8 pin routing..
    Just trying out the possible routing of the cables.
note is offline
post #3 of 201 (permalink) Old 11-01-2013, 01:03 PM - Thread Starter
note's Avatar
Final Pictures:
Some outdoor shots
note is offline
post #4 of 201 (permalink) Old 11-01-2013, 01:17 PM
subtec's Avatar
Rep: 58 (Unique: 53)
That's really a misconception, and for your planned build it's adequate.
subtec is offline
post #5 of 201 (permalink) Old 11-01-2013, 01:23 PM - Thread Starter
note's Avatar
Thank you! To be honest, I put it right there to avoid a page of flaming. thumb.gif
note is offline
post #6 of 201 (permalink) Old 11-01-2013, 01:50 PM
subtec's Avatar
Have you test fit the rad+fans in the case yet? I've seen someone get a rad in, but I'm skeptical the fans will fit inside -- even those half thickness Scythes.
subtec is offline
post #7 of 201 (permalink) Old 11-01-2013, 02:08 PM - Thread Starter
note's Avatar
It does fit. I tried it yesterday with a case fan(25mm like the pro ii rad) and my scythes(12mm) and it has a bit of clearance but not much.
note is offline
post #8 of 201 (permalink) Old 11-01-2013, 11:25 PM
GZJR's Avatar
Rep: 3 (Unique: 3)
excited to see this. love the mother board. have the same one on the way
GZJR is offline
post #9 of 201 (permalink) Old 11-02-2013, 09:44 AM - Thread Starter
note's Avatar
I'm thinking of ways to mount the plexi glass and I'm really considering using velcro to mount it.
Do you guys think that a velcro could hold a 9 x 4 plate with a reservoir(about 1-2lbs) mounted on it?
note is offline
post #10 of 201 (permalink) Old 11-02-2013, 12:37 PM
jd2195's Avatar
Rep: 25 (Unique: 21)
Looks like a pretty sweet build. Looking forward to seeing it.
Check out my current build log here: https://www.overclock.net/t/1495943/project-viridis-water-cooled-haf-912#post_22495895
I am modding my Coolermaster HAF 912+ to fit in a water cooling loop for my gpu and cpu while making the aesthetics better, in my opinion.
jd2195 is offline
