[Build Log] i7-4770k - GTX 780 Ti SLI - Corsair 750D - Custom Liquid Cooling - Page 13 - Overclock.net - An Overclocking Community
post #121 of 268 (permalink) Old 12-01-2013, 08:13 PM
SpecialEffect's Avatar
Rep: 0
First post in the forum to your interesting build! biggrin.gif Haha.
I just bought my 750D and similar to your set up. I wont be water cooling my setup, but what your doing is damn interesting.
Nicely done and props!
Hopefully ill get into water cooling, but untill then My only issue is my motherboard and the 750D. Will see when all my parts arrive
SpecialEffect is offline
post #122 of 268 (permalink) Old 12-01-2013, 10:59 PM - Thread Starter
brandon6199's Avatar
Rep: 75 (Unique: 69)
All that's left now is to sand the aluminum bracket and paint it matte black... that thing really took a beating today. tongue.gif
Mounting that res/pump was a lot harder than it looks...
brandon6199 is offline
post #123 of 268 (permalink) Old 12-02-2013, 02:09 PM - Thread Starter
post #124 of 268 (permalink) Old 12-02-2013, 04:01 PM
hiarc's Avatar
Rep: 54 (Unique: 47)
For the Photon mounting, you used the already in place motherboard standoffs correct?
hiarc is offline
post #125 of 268 (permalink) Old 12-02-2013, 04:19 PM - Thread Starter
Correct. It worked out pretty well, but I had to drill holes in the Photon backplate in order for it to mount properly.
post #126 of 268 (permalink) Old 12-02-2013, 04:41 PM
hiarc's Avatar
The drilling is absolutely no problem on my end and I will probably be using the same method to mount it, thanks. I have been meaning to purchase a Photon but had zero idea how I would mount it given its irregular mounting method. +1 thumb.gif
hiarc is offline
post #127 of 268 (permalink) Old 12-02-2013, 05:40 PM
dade_kash_xD's Avatar
Rep: 24 (Unique: 23)
What color liquid are you going to use in the end?
in life, it's not about getting what you deserve, but getting what you negotiate.
dade_kash_xD is offline
post #128 of 268 (permalink) Old 12-02-2013, 08:04 PM - Thread Starter
Distilled water + mayhems biocide extreme + mayhems deep red dye
post #129 of 268 (permalink) Old 12-04-2013, 05:56 AM
DeusBellum's Avatar
Rep: 0
Did you have to remove the ROG armor back plate from your Maximus VI Formula to mount it in the 750D?
DeusBellum is offline
post #130 of 268 (permalink) Old 12-04-2013, 02:40 PM
IBIubbleTea's Avatar
Rep: 0
Yes he did remove the back armor.
IBIubbleTea is offline
