[Build Log] i7-4770k - GTX 780 Ti SLI - Corsair 750D - Custom Liquid Cooling - Page 15 - Overclock.net - An Overclocking Community
post #141 of 268 (permalink) Old 12-10-2013, 12:29 AM - Thread Starter
brandon6199's Avatar
Rep: 75 (Unique: 69)
brandon6199 is offline
post #142 of 268 (permalink) Old 12-10-2013, 07:31 AM
yurvalentine's Avatar
Rep: 2 (Unique: 2)
SO hawt
yurvalentine is offline
post #143 of 268 (permalink) Old 12-10-2013, 07:53 AM
vallonen's Avatar
Rep: 42 (Unique: 36)
Climax, in case you haven't figured it out yet = finished build.
vallonen is offline
post #144 of 268 (permalink) Old 12-10-2013, 08:05 AM - Thread Starter
Originally Posted by yurvalentine View Post
SO hawt
post #145 of 268 (permalink) Old 12-10-2013, 11:15 AM
MxPhenom 216's Avatar
Rep: 40 (Unique: 35)
Originally Posted by brandon6199 View Post
So what screws did you decide on for the backplate on the GPUs? I like the way the look. Pretty clean.
MxPhenom 216 is offline
post #146 of 268 (permalink) Old 12-10-2013, 11:25 AM - Thread Starter
For the backplate screws > PCB > EK block , I used M3x0.5x8mm socket-head screws
For the EK block screws > PCB, I used M3x0.5x6mm button-head screws
post #147 of 268 (permalink) Old 12-10-2013, 11:41 AM
So to screw in the backplate where there is not block, use used some screws, and then locking nuts?
I was thinking 8mm screws are probably perfect for Backplate > PCB > block.
post #148 of 268 (permalink) Old 12-10-2013, 11:54 AM - Thread Starter
Correct. I used (3) M3 nuts per card where there was nothing that the screw threads would be able to fasten into.
And yes, the M3x0.5x8mm screws are exactly what I used for Backplate > PCB > block
post #149 of 268 (permalink) Old 12-10-2013, 01:37 PM
Awesome man. Thanks for the info. +rep. Excited to see the finished product. I just have a week of finals left till I can go home and rebuild my rig into my new 750D sitting there. Should be good.
Also are you mixing up that vinegar in water and heating it up to clean out the radiators?
post #150 of 268 (permalink) Old 12-10-2013, 02:19 PM - Thread Starter
Correct. I used a 80/20 ratio (distilled water/distilled vinegar). I heated it up to the point where it was quite warm, but not so warm that it was actually boiling. I let the solution sit in the radiators for about an hour, and then filled it up a couple more times with the distilled vinegar/water solution, gave it a nice shake, and poured it out. Then 3 more times after with straight distilled water. For the blocks and tubing, I simply rinsed them for a bit with distilled water and let them dry.
I think it worked quite well, as the last couple times I flushed them out, the water that came out was crystal clear. I do want to note that quite a bit of gunk came out the first couple times with the warm distilled water/vinegar mixture thumb.gif
