[Build Log] i7-4770k - GTX 780 Ti SLI - Corsair 750D - Custom Liquid Cooling - Page 24 - Overclock.net - An Overclocking Community
post #231 of 268 (permalink) Old 01-03-2014, 12:43 AM
MxPhenom 216's Avatar
Rep: 40 (Unique: 35)
Hi Brandon,
Did you find that the two radiators you have is enough for the CPU and those 2 780Ti?
MxPhenom 216 is offline
post #232 of 268 (permalink) Old 01-04-2014, 04:28 PM
back at it
barkinos98's Avatar
Rep: 71 (Unique: 62)
I'm surprised i missed out such a build.
on other hand,
Originally Posted by brandon6199 View Post
All that's left now is to sand the aluminum bracket and paint it matte black... that thing really took a beating today. tongue.gif
Mounting that res/pump was a lot harder than it looks...
Plum Explosion
(20 items)
Macbook Pro 16"
(11 items)
Intel i3-9100F
Asrock Z370M-ITX/ac
XFX RX580 XXX 8GB
Corsair Vengeance LPX 2x8GB 3000MHz
Samsung 840 Pro 256GB
WD Red 8TB
EVGA SuperNova 750G3
Corsair H60 (2018)
Noctua NF-F12 PWM
Noctua NF-P14s redux-900
NZXT H200
Operating System
Windows 10 Pro
Asus PA248Q
Asus PA248Q
Keyboard
Velocifire TKL78 (Granite Keyset)
Mouse
Logitech MX Master
Audio
Bose Companion II
Audio
Blue Snowball iCE
Other
3M 1080 Plum Explosion Wrap
Intel i7-9750H
Apple Logic Board
Intel UHD Graphics 630
AMD Radeon Pro 5300M
16GB 2667MHz DDR4
PCIe 512GB
96W USB-C Charger
Operating System
macOS 10.15
Retina Display 16"
Keyboard
Magic Keyboard
Other
Slickwraps Honeycomb Wrap
barkinos98 is offline
post #233 of 268 (permalink) Old 01-04-2014, 07:53 PM - Thread Starter
brandon6199's Avatar
Rep: 75 (Unique: 69)
Originally Posted by MxPhenom 216 View Post
Hi Brandon,
I haven't actually had the chance to see how it handles both 780 Ti's... since I cracked the acrylic top on one of my blocks. But it (obviously) handles a single Ti and i7-4770k like a champ. But that's expected. I'll let you know once I get the second one in.
on other hand,
Also, quick update. FrozenCPU just informed me that they've received my replacement EK-FC780 Ti Acrylic top and have shipped it out! thumb.gif
Expected delivery date is 1/10/14. I'll probably drain my loop on the 8th to prepare smile.gifthumb.gif
brandon6199 is offline
post #234 of 268 (permalink) Old 01-05-2014, 12:45 AM
Pat77's Avatar
Rep: 3 (Unique: 3)
Cool Brandon ! : Pouce:
Pat77 is offline
post #235 of 268 (permalink) Old 01-12-2014, 06:56 PM
Rep: 75 (Unique: 66)
hfcobra is offline
post #236 of 268 (permalink) Old 01-12-2014, 07:44 PM - Thread Starter
The recent polar vortex in the northeast delayed my acrylic block from being delivered on Friday, so it'll be here tomorrow on Monday.
I have it drained though. Also cleaned out some gunk that was caught up in my block. Can't wait to actually finish this build!
post #237 of 268 (permalink) Old 01-12-2014, 08:28 PM
That looks very nice for sure! May I ask where you found 45 degree fittings from bitspower? Performance-PCs does not seem to have any and I would really like to avoid ordering from another site if I don't have to. Have you tried any other fittings other than the Bitspower ones?
EDIT: Never mind I just did not realize that they were a dual rotary instead of a single rotary. I found them. smile.gif
hfcobra is offline
post #238 of 268 (permalink) Old 01-13-2014, 05:13 AM
masscrazy's Avatar
Rep: 8 (Unique: 5)
Would you advise against using the coolant with dye?
masscrazy is offline
post #239 of 268 (permalink) Old 01-13-2014, 06:18 AM
nathanblandford's Avatar
Rep: 17 (Unique: 16)
Your concerns have been addressed thumb.gif I appreciate the constructive criticism. You're right.
Hey guys, quick update. I've completely done away with the zip ties! I've found an alternative solution. You're all right, using zip ties, although effective, would not be right to use in a build like this where you'll be able to see it. I drilled two new larger holes in the photon bracket, used larger and longer screws, and used a nut to completely fasten it down through the other side. My Photon res is as solid as a rock with this new method. It's completely rigid as opposed to the old method where the zip ties were only used to prevent it from wobbling. I'll also be using black rubber washers to prevent any vibration from the pump resonating with the case.
Let me know your thoughts.
Warning: Spoiler! (Click to show)
My workspace... very messy. lol.
Can't believe I didn't think of using a longer bolt with a nut to fasten it on the other side. I wish you guys could see how solid the mount is now. It won't even budge. thumb.gif
Also, there's not much I can do about those extra holes on the bracket now... luckily the res will be covering most of it. I'm probably going to be painting the bracket with my matte black paint within the next couple days to get rid of all of the marks, etc.
I would post pics of the res mounted, however I painted the nuts and bolts black and am waiting for them to dry. I'll have the final mounted pics uploaded tonight.
Hi Brandon i know this is an old part of your build but I'm basically up to the stage of figuring out a mount for my photon 170/d5 in my 750d. i just wanted to know your thoughts about using the threaded mobo mounts versus drilling and using a bolt/washer like you did. did you consider using the mobo mounts? Also what size/thread are those bolts?
nathanblandford is offline
post #240 of 268 (permalink) Old 01-13-2014, 07:33 AM
Watercooling fan
Garrett1974NL's Avatar
Rep: 15 (Unique: 15)
I would... tried a couple of dyes in the past, always had clogged blocks. Never again, I don't care what anyone says, no matter "how small the particles" are...
Garrett1974NL is offline
