[Build Log] Project Nothing to Hide (2010-2019) Antec 300 Custom Loop 9 years in the making! - Overclock.net - An Overclocking Community
post #1 of 49 (permalink) Old 02-04-2014, 01:14 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
Finally back after MIA for the last 5 years on the forum!
Really excited to announce that this project has finally been completed after almost a decade.
Updated: 8/13/2019: It's literary taking me forever to get the entire build log updated, finally able to clean up the backlogs after all these years.
Final pictures are up in Page 4
Feel free follow my [email protected], new build coming up soon!
Any questions, feel free to let me know
Intro and History
Project “Nothing to Hide” aka. Project “N.T.H” started way back during the summer of 2010, two years after I acquired the original Antec Three Hundred. In 9 years I've through 4 generations of hardware, from air cooling to soft tubing and eventually to hard tubing loop. The only thing still remaining the same is the Antec Three Hundred case, that's right, it's the vanilla version
Initially picked the case due to it's minimalist look, decent air flow and only cost $50 I think. It wasn’t until after watching the Three Hundred Mod by Bill Owen / Mnpctech that had really inspired me to start my own project. Thank you Bill for the inspiration and all the great work you do!
Like many others back in the old days, I started the initial mods with cutting side panel window, drilling cables management holes and painting the interior, honesty just want to improve cable management to hide these ugly rainbow cables and all that mess.
As time progressed, my has vision became more and more clear, I knew the time would come to create something special inside the same old chassis. During the 3rd year as continued to experiment and explore different things, I came to the sense of embrace as much as I can instead of hiding that's inside, at that moment in time, Project Nothing to Hide was truly born!
My end goal was to create something out of the ordinary from inside with nothing to hide, yet remain the elegance from the original exterior design. Been going on and off, so hasn't been easy past few years, but at the end of day, I'm really happy with the final results, what a journey it has been for the past 9 years!
Before the buildlogs, below you will find all the water cooling parts used in the latest edition of the project. Most of them were provided by EKWB (thanks for the love guys!)
Watercooling parts
  • CPU Block: EK-Supremacy EVO - Acetal+Nickel (Original CSQ)
  • GPU Block: EK-FC980 GTX Classy - Acetal+Nickel with EK-FC980 GTX Classy Backplate
  • RAM Heatsink: 4 x Iceman LP Heatspreaders
  • RAM Block: EK-RAM Monarch X4 - Acetal+Nickel
  • Radiators: EK-CoolStream SE 120 & EK-CoolStream SE 240
  • Pump & Reservoir: EK-XRES Revo D5 PWM with EK-RES X3 – TUBE 150 & Multiport TOP
  • Fittings: 10 x EK-HDC Fitting 16mm G1/4 - Black Nickel & some angle adapters from EKWB
  • Tubes: Darkside16mm PETG Hard Tube
  • Fans: 3 x GELID WING 12 UV Blue & 2 x SLIM 12 PL BLUE
  • Fan Controller: Zalman ZM-MFC1 Combo
Now, let’s get down to the build log with lots and lots of pictures,I got so much to show you!
Spoiler alert, for the final pictures
Spoiler!
Last edited by MegaMod; 08-15-2019 at 07:00 PM. Reason: Updated Project timeline with new links/pictures
GSCustomz is offline
post #2 of 49 (permalink) Old 02-04-2014, 01:26 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
v1 (Sept 2008- June 2010)
  • Vanilla Antec Three Hundred with just changing a few led fans updates and cut off some fan grills, nothing much going on.
v1.1 - Year 2010
  • Cut a window for side panel
  • Cut cable management holes
  • Painted the case to glossy black
  • Installed the U-Channel from Mnpctech
Dremel was all I had to use to cut the window.
Should have used matte black, would have saved all the hassle later on, but oh well...
Apparently, I didn't like the way the window look, so I decided to make a bigger cut
Just cut off some cable management holes...
This thing stinks, U channel is 100 times better!
RIP my old Gigabyte UD3, board was shorted since I placed one stand off to the wrong spot...
My old UD3 in the case.
If you are new to spray paint, don't make the same mistake like me, be sure to take everything apart before spraying, or else you'll regret it just like me...
Yeahhhh, U channel has finally arrived! Thanks Bill!
v1.2 - Year 2011
  • Sleeved PSU extension cables
  • Reverse case mod with some major system components upgrade.
For those who plan to reverse mod this case, it's totally possible.
IMO, Zalman makes some of the sexiest air coolers on the planet.
v1.3 - Year 2012
  • Re-painted case without top and bottom panels with matt back and lots of dry/wet sanding
  • Sleeved front I/O cables
  • Sleeved PSU cables for Seasonic X760
  • Removed entire HDD cages, only 5.25 bays left at this point
So this was what I had to do with the entire case again!
Two thing I should have done long time ago...
  1. Paint it matte black instead of glossy black
  2. Taking every thing apart before the paint job...
Sanding, sanding and sanding...
Ready for the prime
Lots lots of wet sanding, that's 5 hours of work right there
It was actually snowing outside, crazy huh?
More wet sanding for the final finish...Hoping to get it right this time
Time for some sleeving pictures
No more extension cables, direct cable sleevings are ready for the X760.
v1.4 - Year 2013
  • Re-spray painted the bottom panel as well as the rest of the case again!!! lol
  • Added custom HDD cages
Finally time to spray the bottom panel.
Basically I was using the system without top and bottom panel for over a year.
Just finished wet sanding after a few coat of prime
Wow, just sanded over my entire case again !!!
Final Result
What a lovely day today, so decided to take some more pictures! This time with the bottom panel painted and installed.
So that pretty much wraps up my past work from 2010-2013.
post #3 of 49 (permalink) Old 02-04-2014, 05:04 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
v1.5 - Year 2014
  • Removed stock honeycomb 140mm grill and modded it to fit dual 120mm fans for the top panel
  • Carbon fiber mod with and dual 120mm acrylic grill on top panel
  • Removed 5.25'' bays completely (rest is history!)
RIP honeycombs
There were four mounting holes for the 140mm, so had to make sure they were not in the way.
Last shot before the cut
Done!
Took me forever to sand off the existing paint.
Completely removed all 5.25'' bays, which means wet sanding and spray painting all over again.
Top panel after priming, looking good
Time for more spray paint!
A pair of these Gelid Wings would look great inside the case!
Love how they match with my sleeving.
Let's hope I won't have to spray paint this part all over.
Time to apply some carbon fiber.
Pre-cut the sheet first, notice how I left some gap between left and right.
Can't wait to put it on already.
post #4 of 49 (permalink) Old 02-06-2014, 11:21 PM
KillThePancake's Avatar
Rep: 18 (Unique: 15)
I like the simplicity of it, nothing like a matte black finish thumb.gif Subbed!
Yesterday's Pancakes, today.
-Egami
My Scratch build log: Durandal
My current build log (WIP): Larry
KillThePancake is offline
post #5 of 49 (permalink) Old 02-07-2014, 05:46 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
Yeah, the idea was too keep it simple and clean. I probably wouldn't have to remove all the 3.5'' and 5.25'' bays if the case had more room.
-George
post #6 of 49 (permalink) Old 02-09-2014, 11:18 AM
rRansom's Avatar
Rep: 9 (Unique: 9)
rRansom is offline
post #7 of 49 (permalink) Old 07-19-2019, 04:43 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
I'm Back!
Guys, I'm finally back with more pics. Really sorry about the MIA past few years on OCN, but the great good news is the project has finally been complete (Yes! wait until you see it's final form)
I've got so much to show you to make up for it. Let's start with a few more pics didn't get to post back in 2014, much more to come! Feel free to follow me on IG @gscustomz if you can't wait to see some final pics.
post #8 of 49 (permalink) Old 07-19-2019, 04:55 PM
Intel Pariah
King4x4's Avatar
Rep: 98 (Unique: 75)
Welcome Back!
Awesome work turning a normal case into masterpiece.
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 2.5
Build Log: Hydra 3
Build Log: Mini-Hydra
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
Intel i7 3930k @[email protected]
Asrock X79 Fataility Champion
3xInno3d GTX 780 with Full Nickel EK Waterblocks
Gskill RipjawsX [email protected] 11-11-11-31
2xSamsung 830 256gb
Seasonic 1250 watt
Custom H2O - 3x XSPC RX360 with EK Blocks
Danger Den Double Wide 21
Surround Gaming [email protected] (X-Star)
Keyboard
Cooler Master Trigger Red Caps
Mouse
Roccat Kone+
Audio
Roccat Kave 5.1 Headphones
Audio
Creative ZX (Incoming)
4930k
Asus Extreme Black Edition
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Gskil TridentX 2400mhz
Samsung 830 256GB
Samsung 840 500GB
2x Seasonic 1250watt
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
BenQ 3201 32in 4k IPS
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Coolermaster Storm Trigger
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
Gigabyte Aorus Ultra
EVGA 1080 Ti
EVGA 1080 Ti
Ballistix Sport LT 32GB
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
post #9 of 49 (permalink) Old 07-19-2019, 05:08 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
v1.6 - Year 2016
v1.6 / MK6 - Year 2016
This was the her final form before going full custom loop
You can see I've also made a few key upgrades to the main component and of course, I sleeved more cable!
Upgraded CPU to G3258 and 4790K
Ungraded motherboard to Gigabyte Z97X-UD5H-BK Black Edition
Ungraded Video Card to EVGA GeForce GTX770 Classified 4GB GDDR5
post #10 of 49 (permalink) Old 07-19-2019, 05:25 PM - Thread Starter
GS
GSCustomz's Avatar
Rep: 1 (Unique: 1)
MK7 - 2017
The show has just gotten started, some back the buildlog pictures from 2017. Many of these pics can also be found on my IG @gscustomz for those who are interested
Tags
Casemod , Watercooling
