[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 21 - Overclock.net - An Overclocking Community
post #201 of 512 (permalink) Old 07-01-2014, 12:12 PM - Thread Starter
Rep: 30 (Unique: 22)
38. NOBODY BUT ME AND JB (WELD)
So I've never really messed much with JB Weld. I played around with some half-used tubes that I found earlier in this project, and the stuff was like putty. But after asking around, I'm told that it was probably just old and that a new set of tubes would be much runnier. Which is what I want.
(I should preface this by saying I attempted to use solder to mate the surfaces. BIG FAIL. I couldn't get the panels hot enough with my torch without seeing the panels start to warp. So I cleaned off the solder and started over.)
AppleMark
Let's go mount that side panel!
First I made sure I had a stiff, flat surface UNDER the side panel, so I could be sure it would be completely flat when I added weight to the top. You can't see it in this photo, but I also slid an old grocery sack over the wood, in case the JB Weld ran:
AppleMark
Then I roughed up the mating surfaces with sandpaper and degreased them with isopropyl. The circle on the left is where I'll do my mixing, since I expect to use almost half a tube and I'm nervous about working time. I want room to move.
AppleMark
And here's the panel set in place.
LESSON LEARNED:
Apply the stuff to the bottom surface, not the top surface. It was much runnier than I expected (duh) and I got a lot of drips as I applied it. Better would have been to clearly mark the mating surfaces on the side-panel, and make a "bead" of it, then set the bumpout in place.
Still, it worked pretty well. Sorry no photos of me applying it. I ran out of hands, and it was a mess trying to keep the process under control. rolleyes.gif
AppleMark
Then I weighted that baby down with some scrap lumber.
AppleMark
After that, I used acetone to clean up some of the spillage.
And now... we wait.
After the JB Weld cures, I will sand down any high spots, and then I may apply another bead to the inside of the mating surface just to be safe. After that, I'll be using the Everglass to strengthen and sculpt the bumpout.
Jhereg10 is offline
post #202 of 512 (permalink) Old 07-01-2014, 12:29 PM
ron1389's Avatar
Rep: 3 (Unique: 3)
Current build logs (On Hold)
Current Case Mods
None
ron1389 is offline
post #203 of 512 (permalink) Old 07-01-2014, 01:26 PM
Covfefe
Wihglah's Avatar
Rep: 84 (Unique: 75)
Originally Posted by ron1389 View Post
patience!
Leave that sucka for 24 hours bro.
Ro'Ghaf II
Oldness
(14 items)
Intel 9900k
Some crappy 4 phase rubbish from Asus that was way overpriced.
EVGA 980ti ACX2 SC+
G.Skill Trident Z RGB 4266 16Gb
Samsung 970 Evo
Corsair AX860i
EK Supremacy Evo
Cooler Master Haf Stacker 935
Haf Stacker 915R
Operating System
Windows 10 Pro
Asus ROG Swift
Keyboard
DuckyShine 6 YOTR
Mouse
Logitech G502
IvyBridge 3770K
Asus P8Z77-V Pro
560Ti Direct CU II
Geil DDR3
Western Digital
Western Digital VelociRaptor 10K
Optical Drive
liteOn Bluray Burner
OCZ 1000W
EK Supreme HF Copper / Plexi & Vapochill Chiller
Lian Li
Operating System
Windows 7
LG 21"
Keyboard
Logitech G15
Mouse
Logitech
Wihglah is offline
post #204 of 512 (permalink) Old 07-01-2014, 01:34 PM - Thread Starter
Jhereg10 is offline
post #205 of 512 (permalink) Old 07-02-2014, 09:17 AM
Rep: 8 (Unique: 8)
Surely it's close enough to 24 hours now?!?!?!!!!
i5-3570K - [email protected] (24/7 OC [email protected]) | AsRock Z77 Extreme 4 | Crossfire Asus R9 290 DirectCU II | Custom Watercooling Loop | 8GB G Skill Ripjaws DDR3 | Samsung 850 Evo 120GB SSD | WD Blue 1TB HDD | EVGA Supernova G2 1000w | NZXT Phantom 410 | Qnix 27" Evolution II 1440p Monitor
Brian18741 is offline
post #206 of 512 (permalink) Old 07-02-2014, 09:27 AM - Thread Starter
Jhereg10 is offline
post #207 of 512 (permalink) Old 07-02-2014, 10:02 AM - Thread Starter
Originally Posted by Wihglah View Post
patience!
Okay okay, enough cruelty... I pulled the wood off and had a look!
AppleMark
First off, adding that bumpout really stiffened up that side panel. I mean before it had some serious torsion flex, but now it's straight and stiff. Very nice effect. Second, it seems like the panel is very solidly attached. I used a small amount of force, and didn't hear or see any cracking.
AppleMark
Interesting side-effect you can see here. There were some existing holes in the side panel and the JBWeld oozed into those. Bet the joint at those spots is quite strong. I'm glad I thought to put plastic down under that, or I'd be sanding wood off the back of the panel! rolleyes.gif
But that does give me the idea that next time I'll drill pinholes between the two pieces for extra bonding surface.
AppleMarkAppleMark
AppleMarkAppleMark
As you can see, some spots came out really clean, and others the JB Weld ran like nobody's business as I was trying to apply it. So I've got some serious cleanup to do.
So if you're thinking of doing something similar:
1) Make sure you set a very flat surface underneath the bottom piece to ensure you get a flat join.
2) Rough up both surfaces well. I used 80 grit, believe it or not.
3) Degrease it and let dry.
4) Apply the JB Weld to the top of the bottom piece to minimize runs and mess. If I'd thought of it, I'd have loaded it into some sort of syringe or squeeze tube like cake decorators use to get a nice bead.
5) Set the top part on and weight it down good. Don't touch or peek for 24 hours!
Looks like this got me a good strong joint.
Next steps;
1) Grind off some of the excess, which will be tricky because the metal is thin. Some spots, I won't even bother since it will be hidden inside the case.
2) Add body filler to sculpt the join. I've got an idea to use sandpaper wrapped around a piece of PVC to get a nice smooth curve. We'll see how that works out.
3) Prime and prepare to paint with the rest of the exterior.
Then I can start on the front-side panel window!
Jhereg10 is offline
post #208 of 512 (permalink) Old 07-02-2014, 10:25 AM
TheReciever's Avatar
Rep: 434 (Unique: 322)
lolwut, is that a cookie sheet?
Either way, its always nice to see a fresh approach to a mod, no matter how unconventional lol
Biased rPGA and MXM 3.0A/B Elitest.
TheReciever is offline
post #209 of 512 (permalink) Old 07-02-2014, 10:26 AM
ron1389's Avatar
Rep: 3 (Unique: 3)
That looks really solid! I wonder what it will looks like when it's painted.
Current Case Mods
None
ron1389 is offline
post #210 of 512 (permalink) Old 07-02-2014, 10:29 AM
Dortheleus's Avatar
Rep: 9 (Unique: 9)
Originally Posted by Jhereg10 View Post
Okay okay, enough cruelty... I pulled the wood off and had a look! Warning: Spoiler! (Click to show)
AppleMark
AppleMark
AppleMarkAppleMark
AppleMarkAppleMark
Next steps;
“Who’s the more foolish; the fool, or the fool who follows him?”
“That… is why you fail.”
“It’s worse.”
“That’s no moon.”
“Sorry about the mess.”
Dortheleus is offline
