[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 22 - Overclock.net - An Overclocking Community
post #211 of 512 (permalink) Old 07-02-2014, 10:29 AM
Linux Lobbyist
Wanou's Avatar
Rep: 30 (Unique: 21)
Looks nice.
Good idea for the syringe. I'm looking to use the same product and I'll try to get one to apply the product evenly.
Wanou is offline
post #212 of 512 (permalink) Old 07-02-2014, 10:42 AM
Rep: 8 (Unique: 8)
Can't wait to see how you blend it in with the body filler. Great work so far as always!
i5-3570K - [email protected] (24/7 OC [email protected]) | AsRock Z77 Extreme 4 | Crossfire Asus R9 290 DirectCU II | Custom Watercooling Loop | 8GB G Skill Ripjaws DDR3 | Samsung 850 Evo 120GB SSD | WD Blue 1TB HDD | EVGA Supernova G2 1000w | NZXT Phantom 410 | Qnix 27" Evolution II 1440p Monitor
Brian18741 is offline
post #213 of 512 (permalink) Old 07-02-2014, 11:21 AM - Thread Starter
Rep: 30 (Unique: 22)
Originally Posted by TheReciever View Post
lolwut, is that a cookie sheet?
Either way, its always nice to see a fresh approach to a mod, no matter how unconventional lol
Yup that's exactly what it is! Unconventional is my middle name, if you spell it s-l-i-g-h-t-l-y-a-d-d-l-e-d. wink.gif
Originally Posted by ron1389 View Post
That looks really solid! I wonder what it will looks like when it's painted.
Originally Posted by Dortheleus View Post
Thanky!
Originally Posted by Wanou View Post
Looks nice.
I'd assume you'll only get one use out of that syringe. Probably those cheap oral medication ones would be best?
Me too! Only thing, and fair warning, I'm going to have a busy two weeks coming up after this weekend. Expect little or no progress during that period. thumbsdownsmileyanim.gif
Jhereg10 is offline
post #214 of 512 (permalink) Old 07-02-2014, 11:30 AM
Linux Lobbyist
Wanou's Avatar
Well, I was thinking maybe a pastry bag would be handy here. It's easy to fill and apply with. Also you can cut the corner to the desired shape and width.
http://www.bonappetit.com/uncategorized/article/how-to-frost-cupcakes-with-a-homemade-pastry-bag
Wanou is offline
post #215 of 512 (permalink) Old 07-02-2014, 12:10 PM
Covfefe
Wihglah's Avatar
Rep: 84 (Unique: 75)
Couldn't you spread it on with a paintbrush?
Ro'Ghaf II
Oldness
(14 items)
Intel 9900k
Some crappy 4 phase rubbish from Asus that was way overpriced.
EVGA 980ti ACX2 SC+
G.Skill Trident Z RGB 4266 16Gb
Samsung 970 Evo
Corsair AX860i
EK Supremacy Evo
Cooler Master Haf Stacker 935
Haf Stacker 915R
Operating System
Windows 10 Pro
Asus ROG Swift
Keyboard
DuckyShine 6 YOTR
Mouse
Logitech G502
IvyBridge 3770K
Asus P8Z77-V Pro
560Ti Direct CU II
Geil DDR3
Western Digital
Western Digital VelociRaptor 10K
Optical Drive
liteOn Bluray Burner
OCZ 1000W
EK Supreme HF Copper / Plexi & Vapochill Chiller
Lian Li
Operating System
Windows 7
LG 21"
Keyboard
Logitech G15
Mouse
Logitech
Wihglah is offline
post #216 of 512 (permalink) Old 07-02-2014, 12:29 PM
PurdueBoy's Avatar
Rep: 70 (Unique: 63)
Next steps;
1) Grind off some of the excess, which will be tricky because the metal is thin. Some spots, I won't even bother since it will be hidden inside the case.
2) Add body filler to sculpt the join. I've got an idea to use sandpaper wrapped around a piece of PVC to get a nice smooth curve. We'll see how that works out.
3) Prime and prepare to paint with the rest of the exterior.
Then I can start on the front-side panel window!
Throw some 3M spray adhesive on the sandpaper and stick it to the pvc. Great for sanding awkward areas. I sometimes make my own foam sanding blocks with unusual shapes to sand tough spots and just glue some sand paper to them. Don't have to worry about uneven surfaces like you sometimes with when only using your fingers.
If you're worried about the strength of the joint you could always throw some pop rivets through the handle areas of the cookie sheet. Wouldn't be too hard to cover those up with the body filler.
Hmm are you going to be using that Everglass stuff you used on the front panel as the filler? I looked it up and supposedly it's flexible and has Kevlar strands in it, but I'd still be worried about flex cracks. Definitely going to want to be gentle with it after it's finished.
I can't think of any ideas to avoid any issue that might arise from that. Maybe get the joint to look decent with filler and sanding and then getting a large sheet of plastic and thermo-forming it over your side panel as a veneer, then attaching it with some kind of adhesive and trimming the excess.
PurdueBoy is offline
post #217 of 512 (permalink) Old 07-02-2014, 12:49 PM - Thread Starter
I think it would be a bit too gummy for that. It has the consistency of honey. Worth a try tho.
That's an excellent idea.
Thanks for the adhesive tip. Definitely will do that. Not sure I can fit a rivet in the handle section. Still pretty narrow but I'll take a look at it.
As far as the Everglass, yes that was the plan. I've been very impressed with its durability so far. And with how much the panel stiffened up, I'm going to run with it as a test and see if it holds up.
Jhereg10 is offline
post #218 of 512 (permalink) Old 07-03-2014, 02:44 PM - Thread Starter
39. TASTES HORRIBLE, MORE FILLING
Managed to sneak in some body work on the back side panel today. So let's start with another shot of the side panel.
AppleMark
First I had to grind down some of the excess JB Weld. That went pretty well.
AppleMark
Then I roughed it up with some 100 grit sandpaper.
AppleMarkAppleMarkAppleMark
Getting ready for the body filler. I used two pieces of wood to brace up the front edge to ensure it stayed completely flat during the body filler work. That's the longest edge and had the most risk of a deflection. My thought was, if it's as straight as possible during the filler work, maybe the filler will help keep it that way, and it will reduce the risk of cracking when I install it since it will already be flat.
I also braced underneath with some plywood to ensure the bottom of the work area was flat.
Degreased with isopropyl alcohol, of course.
First layer of body filler around the edge and the top. The top has a slight "lip" that I want to smooth out.
And then filing and sanding down the high spots.
AppleMarkAppleMark
TIL:  Leaving excess filler that has gone where you don't want it, with the idea that you'll just sand it down later, is silly. If you wait about 2-3 minutes after you apply it, then you can scrape it off with the filler spreader easy as pie.
And the second coat. This time I flexed the spreader slightly and managed to get a decent curved profile. I'm actually quite pleased with it. May not have to do much heavy sanding after this coat.
AppleMarkAppleMarkAppleMarkAppleMark
After this dries, I'll probably sand it down and switch to the glazing putty.
One thing to point out, I worked on this without handling it like it was fragile, and I didn't see any signs of joint failure. I think the filler, on top of the JB Weld, is going to give me a pretty stiff panel. Heck it's going to be stronger than it was originally I think.
PS: If you haven't already, please vote for my fellow beigemodder, BruceB 's Building a 20€ LAN PC for Mod of the Month! VOTE HERE!
Jhereg10 is offline
post #219 of 512 (permalink) Old 07-03-2014, 08:59 PM - Thread Starter
Managed to get the glazing putty on the side panel. On my second coat at the moment. Starting to look nice, though one of the corners needs built up a bit.
First coat, before sanding:
AppleMark
Second coat before sanding:
AppleMark
Jhereg10 is offline
post #220 of 512 (permalink) Old 07-03-2014, 11:03 PM
Covfefe
Wihglah's Avatar
This thread is full of awesome.
Ro'Ghaf II
Oldness
(14 items)
Intel 9900k
EVGA 980ti ACX2 SC+
Samsung 970 Evo
Corsair AX860i
EK Supremacy Evo
Haf Stacker 915R
Operating System
Windows 10 Pro
Asus ROG Swift
Keyboard
DuckyShine 6 YOTR
Mouse
Logitech G502
IvyBridge 3770K
Asus P8Z77-V Pro
560Ti Direct CU II
Geil DDR3
Western Digital
Optical Drive
OCZ 1000W
Lian Li
Operating System
Windows 7
LG 21"
Keyboard
Logitech G15
Mouse
Logitech
Wihglah is offline
