[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 27 - Overclock.net - An Overclocking Community
post #261 of 512 (permalink) Old 10-15-2014, 06:20 PM - Thread Starter
Rep: 30 (Unique: 22)
47. Side Panel Cleanup
Today I focused on cleaning up the window cutout and priming the other side of the bumpout side panel.
FIrst I clamped it down on the workbench and got to work cleaning up the rough edges that the hole saw and jigsaw left. Already nearly sliced myself good on that edge. No fun a'tall.
Once clamped, I could get to srs bzns.
First up was the dremel. There were some spots where the hole saw wallowed out a groove but didn't cut through, so I used the cutoff disk to clean those up. The metal was very thin there, so it went quickly but I had to be careful to keep the curve smooth. Then I used a grinding disk on all the edges to debur, and finished up with some course sandpaper to remove any remaining rough edges.
Now outside to do a bit of priming! I had to sand off some flash-rust spots from handling the raw steel for several weeks first.
AppleMarkAppleMark
Nothing too exciting there, but it's definitely starting to look nice.
AppleMark
AppleMark
I also took the opportunity to sand and prime the backside of the bumpout side panel. It's really starting to look nice, other than that bit of epoxy dribble that I can't get off unless I sand everything down to bare metal. That is some tough stuff.
Tomorrow I plan on priming the other side of the window side panel and playing around with the foam board some more. I have to order some supplies for the interior modding tonight, too.
Jhereg10 is offline
post #262 of 512 (permalink) Old 10-15-2014, 06:23 PM
Nomadskid's Avatar
Rep: 21 (Unique: 17)
Do you need another red cathode?
Nomadskid is offline
post #263 of 512 (permalink) Old 10-15-2014, 06:37 PM - Thread Starter
Are you offering to sell me one, or asking me why I would want one? wink.gif
I have one purchased already that I'm considering using, but I haven't decided yet. It may be overkill. But then, what's a little overkill between friends. thumb.gif
Jhereg10 is offline
post #264 of 512 (permalink) Old 10-15-2014, 06:39 PM
Nomadskid's Avatar
post #265 of 512 (permalink) Old 10-15-2014, 09:59 PM - Thread Starter
Jhereg10 is offline
post #266 of 512 (permalink) Old 10-16-2014, 03:53 AM
Nomadskid's Avatar
This is a community, an eco-system of sorts. In order to survive, we have to take care of each other. It's my pleasure to help out another modder!
post #267 of 512 (permalink) Old 10-16-2014, 05:13 AM
AMD s939 LVL 99+
SwishaMane's Avatar
Rep: 106 (Unique: 88)
Looking good! Do you plan to use window molding for that extra contrast?
Personal best - 11,811 in 3DMark06 on 01/16/2016 socket 939 baby!
Proud elite member of the Socket 939 Appreciation Club.
SwishaMane is offline
post #268 of 512 (permalink) Old 10-16-2014, 10:58 AM - Thread Starter
I did learn today that that side panel is tough! A six-foot long piece of angle iron slid off a rack and speared it, believe it or not. After cursing and scrambling off the ladder I found this result.
'Twas but a scratch! Didn't crack any of my body filler work, or bend it either. I was amazed!
Jhereg10 is offline
post #269 of 512 (permalink) Old 10-16-2014, 04:35 PM - Thread Starter
Yo Swish, testing out that molding idea (I only had a small piece to play with). I think I like it!
Whatcha think?
Jhereg10 is offline
post #270 of 512 (permalink) Old 10-17-2014, 02:27 AM
Buehlar is offline
