[Case Mod] [COMPLETE] December MOTM 2nd Place! - Relic: A BeigeMod First Case Mod - Page 29 - Overclock.net - An Overclocking Community
post #281 of 512 (permalink) Old 10-20-2014, 12:32 PM - Thread Starter
Rep: 30 (Unique: 22)
50. Holy Foam Board, Batman! - Wiring Hole Locations
Cutting window in the 5.25" drive cage for front panel wiring to pass through:
AppleMarkAppleMark
The white splattered background there is a piece of foamboard I stuck in there to protect the PSU and other stuff from metal dust as I was cutting. I really should have taken all that out...
Result:
[Disclaimer, the power switch is just stuck in there. I promise I'm not leaving it hacked up like that.]
AppleMark
I think that will work nicely. Need to get some grommet edging and line that hole. Honestly, I did a crap job making the cuts clean, as I didn't want to disassemble the entire thing (would have meant drilling out a half dozen rivets) and had to work some odd angles to get the cuts right. The edging will hide the imperfections a bit.
Cut a couple of template holes for the fan wiring and the light strip wiring too:
AppleMarkAppleMark
Ran the wiring for the cold cathode behind the motherboard:
AppleMark
View of the back. Needs wire management in a bad way, but at the least, this will all be hidden from view once the side panel is on:
AppleMark
And the rest of the cold cathode wiring will run across the front of the case, nicely hidden once the top is on:
AppleMark
Next Up:
Exterior: More sanding. More painting
Front: Making final panel for power and reset switches. Front accessory bay should come today.
Internal: Finish planning holes and start fabricating the final panels
Side note: Wire came loose on one of my Yate Loon fans. I'll need to resolder that. Yay! wink.gif
Jhereg10 is offline
post #282 of 512 (permalink) Old 10-20-2014, 10:44 PM
Linux Lobbyist
Buehlar's Avatar
Rep: 89 (Unique: 70)
Buehlar is offline
post #283 of 512 (permalink) Old 10-21-2014, 07:33 PM - Thread Starter
Originally Posted by Buehlar View Post
Mods are looking great! Once finished, you'll never even know this started as a generic case thumb.gif
As always, that's high praise coming from you, sir. Your bench was a wonder to follow, and the end result was incredible eye-candy.
Jhereg10 is offline
post #284 of 512 (permalink) Old 10-21-2014, 07:52 PM - Thread Starter
A quick update. I didn't get a lot done on this mod last two days, for various reasons. One of which was that someone gave me a nonfunctional Acer Aspire X1700 (wouldn't turn on and no HDD) and I just had to see if it was salvageable. In the end, it turned out the GPU (which was a GT100, believe it or not) was fried because the heatsink fan had seized up at some point. Found the same model on Ebay, bought it, and it arrived with... duh duh duhhhh... the heat sink fan seized up and nonfunctional as well. Well dang.
Popped a 320GB HDD I had laying around, ran to Fry's (The Happy Place) and picked up an R5450 low profile GPU for $35 - $15 mail in rebate = $20. Can't beat that with a stick. Have it up and running now on Linux Ubuntu 14.04 and considering keeping it in my workshop as a research / sketching system for my projects.
Regardless, I got a few goodies in the mail today. The carbon fiber vinyl was one. The others were:
AppleMarkAppleMark
That little tray will hold the SSD when the build is done. Thinking about a bit of accent painting on it as well.
AppleMarkAppleMark
And that grill will go over the radiator outlet. Gonna look schweet!
Jhereg10 is offline
post #285 of 512 (permalink) Old 10-22-2014, 03:00 PM
Rep: 5 (Unique: 4)
Ether way, I'm pretty excited for the final build. This is coming out sweet! especially the red accents!
vaatibal is offline
post #286 of 512 (permalink) Old 10-22-2014, 10:16 PM - Thread Starter
Thanks man. I've definitely turned into a Linux true-believer. In the last 6 months, I've transitioned from being a Windows user, to a dual-boot user, to a Linux with Windows in a Virtual Machine user. Basically, if I can hack it into working in Linux, I use Linux. If it refuses to, then I install it in a VM.
I spent some time today sanding, spot filling, and repainting the basecoat of the side panel. Have a look at the final result:
AppleMark
Jhereg10 is offline
post #287 of 512 (permalink) Old 10-22-2014, 10:28 PM
MR KROGOTH's Avatar
Rep: 500 (Unique: 416)
Did you not use Pinhole putty, self etch primer, and sandable primer to get it flat by blocking?
MR KROGOTH is offline
post #288 of 512 (permalink) Old 10-23-2014, 06:08 AM - Thread Starter
Actually I did all of those... badly, apparently. This was my first time using body fillers, primers, and actually trying to make something look good with rattlecans. There's a bit of trial and error learning curve there.
The biggest issue I'm finding is that it's hard to see imperfections in primer because it tends to be flat finish. You think you have it cleam, then you throw a coat of satin over it and.. wow look at all that...
Jhereg10 is offline
post #289 of 512 (permalink) Old 10-23-2014, 06:12 AM
AMD s939 LVL 99+
SwishaMane's Avatar
Rep: 106 (Unique: 88)
Sandpaper? Makes anything smooth...
Personal best - 11,811 in 3DMark06 on 01/16/2016 socket 939 baby!
Proud elite member of the Socket 939 Appreciation Club.
SwishaMane is offline
post #290 of 512 (permalink) Old 10-23-2014, 06:18 AM
MR KROGOTH's Avatar
quotet kinda of block are you using?
Are you blocking after each and every application of filler/primer?
Are you using a guide coat? (Best idea)
